Problem with "Install the Required Python Packages" on Get Started
blqsa4ko
Postby blqsa4ko » Tue Oct 24, 2023 9:59 am
Hello, I got an ESP8266MOD D1 mini board. I managed to program it with the blink example using Arduino IDE, and now I want to use the native SDK. I am following the instructions of the Get Started page :
https://docs.espressif.com/projects/esp ... et-esp-idf
However, I am stuck at the last step - Install the Required Python Packages
When I run the command
python -m pip install --user -r $IDF_PATH/requirements.txt
, it fails.
The output is :
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/site-packages (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 4)) (40.8.0)
Collecting click>=5.0 (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 8))
  Using cached https://files.pythonhosted.org/packages/00/2e/d53fa4befbf2cfa713304affc7ca780ce4fc1fd8710527771b58311a3229/click-8.1.7-py3-none-any.whl
Collecting pyserial>=3.0 (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 9))
  Using cached https://files.pythonhosted.org/packages/07/bc/587a445451b253b285629263eb51c2d8e9bcea4fc97826266d186f96f558/pyserial-3.5-py2.py3-none-any.whl
Collecting future>=0.15.2 (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 10))
  Using cached https://files.pythonhosted.org/packages/8f/2e/cf6accf7415237d6faeeebdc7832023c90e0282aa16fd3263db0eb4715ec/future-0.18.3.tar.gz
Collecting cryptography<35,>=2.1.4 (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 11))
  Using cached https://files.pythonhosted.org/packages/cc/98/8a258ab4787e6f835d350639792527d2eb7946ff9fc0caca9c3f4cf5dcfe/cryptography-3.4.8.tar.gz
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
    Preparing wheel metadata ... done
Collecting pyparsing<2.4.0,>=2.0.3 (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 12))
  Using cached https://files.pythonhosted.org/packages/de/0a/001be530836743d8be6c2d85069f46fecf84ac6c18c7f5fb8125ee11d854/pyparsing-2.3.1-py2.py3-none-any.whl
Collecting pyelftools>=0.22 (from -r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 13))
  Using cached https://files.pythonhosted.org/packages/33/f9/281a411a5281b674b10830a2f312c64464b49916d097b8919f009de579e0/pyelftools-0.30-py2.py3-none-any.whl
Collecting importlib-metadata; python_version < "3.8" (from click>=5.0->-r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 8))
  Using cached https://files.pythonhosted.org/packages/ff/94/64287b38c7de4c90683630338cf28f129decbba0a44f0c6db35a873c73c4/importlib_metadata-6.7.0-py3-none-any.whl
Collecting cffi>=1.12 (from cryptography<35,>=2.1.4->-r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 11))
  Using cached https://files.pythonhosted.org/packages/c2/0b/3b09a755ddb977c167e6d209a7536f6ade43bb0654bad42e08df1406b8e4/cffi-1.15.1-cp37-cp37m-manylinux_2_12_i686.manylinux2010_i686.manylinux_2_17_i686.manylinux2014_i686.whl
Collecting typing-extensions>=3.6.4; python_version < "3.8" (from importlib-metadata; python_version < "3.8"->click>=5.0->-r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 8))
  Using cached https://files.pythonhosted.org/packages/ec/6b/63cc3df74987c36fe26157ee12e09e8f9db4de771e0f3404263117e75b95/typing_extensions-4.7.1-py3-none-any.whl
Collecting zipp>=0.5 (from importlib-metadata; python_version < "3.8"->click>=5.0->-r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 8))
  Using cached https://files.pythonhosted.org/packages/5b/fa/c9e82bbe1af6266adf08afb563905eb87cab83fde00a0a08963510621047/zipp-3.15.0-py3-none-any.whl
Collecting pycparser (from cffi>=1.12->cryptography<35,>=2.1.4->-r /home/koko/esp/ESP8266_RTOS_SDK/requirements.txt (line 11))
  Using cached https://files.pythonhosted.org/packages/62/d5/5f610ebe421e85889f2e55e33b7f9a6795bd982198517d912eb1c76e1a53/pycparser-2.21-py2.py3-none-any.whl
Building wheels for collected packages: cryptography
  Building wheel for cryptography (PEP 517) ... error
  Complete output from command /usr/local/bin/python3 /usr/local/lib/python3.7/site-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmpss27oir3:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-i686-cpython-37
  creating build/lib.linux-i686-cpython-37/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-i686-cpython-37/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-i686-cpython-37/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-i686-cpython-37/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-i686-cpython-37/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-i686-cpython-37/cryptography
  creating build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/x509
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat
  copying src/cryptography/hazmat/_types.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat
  copying src/cryptography/hazmat/_der.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/bindings
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/asymmetric
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/bindings/openssl
  creating build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-i686-cpython-37/cryptography/hazmat/backends/openssl
  running egg_info
  writing src/cryptography.egg-info/PKG-INFO
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  writing requirements to src/cryptography.egg-info/requires.txt
  writing top-level names to src/cryptography.egg-info/top_level.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files found matching 'vectors'
  warning: no previously-included files matching '*' found under directory 'vectors'
  warning: no previously-included files matching '*' found under directory '.github'
  warning: no previously-included files found matching 'release.py'
  warning: no previously-included files found matching '.coveragerc'
  warning: no previously-included files found matching 'codecov.yml'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching 'dev-requirements.txt'
  warning: no previously-included files found matching 'tox.ini'
  warning: no previously-included files found matching 'mypy.ini'
  warning: no previously-included files matching '*' found under directory '.zuul.d'
  warning: no previously-included files matching '*' found under directory '.zuul.playbooks'
  adding license file 'LICENSE'
  adding license file 'LICENSE.APACHE'
  adding license file 'LICENSE.BSD'
  adding license file 'LICENSE.PSF'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  copying src/cryptography/py.typed -> build/lib.linux-i686-cpython-37/cryptography
  running build_ext
  generating cffi module 'build/temp.linux-i686-cpython-37/_padding.c'
  creating build/temp.linux-i686-cpython-37
  generating cffi module 'build/temp.linux-i686-cpython-37/_openssl.c'
  running build_rust
      Updating crates.io index
  error: failed to get `pyo3` as a dependency of package `cryptography-rust v0.1.0 (/tmp/pip-install-6vju0hz1/cryptography/src/rust)`
  Caused by:
    failed to fetch `https://github.com/rust-lang/crates.io-index`
  Caused by:
    error reading from the zlib stream; class=Zlib (5)
      =============================DEBUG ASSISTANCE=============================
      If you are seeing a compilation error please try the following steps to
      successfully install cryptography:
      1) Upgrade to the latest pip and try again. This will fix errors for most
         users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      2) Read https://cryptography.io/en/latest/installation.html for specific
         instructions for your platform.
      3) Check our frequently asked questions for more information:
         https://cryptography.io/en/latest/faq.html
      4) Ensure you have a recent Rust toolchain installed:
         https://cryptography.io/en/latest/installation.html#rust
      5) If you are experiencing issues with Rust for *this release only* you may
         set the environment variable `CRYPTOGRAPHY_DONT_BUILD_RUST=1`.
  error: `cargo metadata --manifest-path src/rust/Cargo.toml --format-version 1` failed with code 101
  -- Output captured from stdout:
  Failed building wheel for cryptography
  Running setup.py clean for cryptography
Failed to build cryptography
Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
You are using pip version 19.0.3, however version 23.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
I guess the problem comes from Python and pip, but I do not manage to find a solution on the net.
I use Ubuntu 16.04 / 32-bit
It has Python 2.7.12 pre-installed, this was what
python --version
returned.
pip --version
returned pip 8.1.1 from /usr/lib/python2.7/dist-packages (python 2.7)
I modified .bashrc with:
alias python=python3
alias pip=pip3
I also installed Python 3.7.4 and pip so that now
python --version
returns
Python 3.7.4
, and
pip --version
returns
pip 19.0.3 from /usr/local/lib/python3.7/site-packages/pip (python 3.7)
But I still cannot manage the Python package installation under
https://docs.espressif.com/projects/esp ... n-packages
Could I ask for help on this step ?
Thanks in advance
Users browsing this forum: No registered users and 10 guests
