I have use rainmaker GPIO example in other projects so what should I do ? and what are the components I have to add in other project like common folder and all?
thank you
Trupal
Rainmaker components
Re: Rainmaker components
You will have to explicitly include all components from esp-rainmaker/examples/common and the ones from esp-rainmaker/components. The latter can be skipped if you just include the esp_rainmaker component from component manager which will pull in all dependencies. However, the ones from examples/common will still be required to be included explicitly.
An easy option is to just set RMAKER_PATH to point to esp-rainmaker folder and the default CMakeLists.txt will pick up all required components.
Users browsing this forum: No registered users and 14 guests
