Can I use Eclipse and VScode concurrent on the same machine
may be for use of different IDF versions and what do I have to take care of if that is possible
Re: Can I use Eclipse and VScode concurrent on the same machine
Yes, it should be possible!
If you are using Eclipse for multiple esp-idf versions, please make sure you use a seperate workspace for each IDF version as eclipse allow one IDF version at the global workspace level.
If you have a usecase where you wanted to switch to a different version for the same project, please refer to the below article
https://medium.com/@kondal.kolipaka/swi ... 5d0ad9f7a0
I hope that helps!
I hope that helps!
Users browsing this forum: No registered users and 33 guests
