This tutorial shows how to put the ESP32 into deep sleep mode and then wake it up with a timer after a predetermined period. With the Arduino IDE, the ESP32 will be programmed.
Writing a Deep Sleep Sketch
To put your ESP32 into deep sleep mode and then wake it up, you need to write a sketch.
Configure the wake-up sources first. Configuring what will wake up the ESP32 is what this means. Use one wake-up source alone or mix many. We'll show you how to set a timer to wake you up in this post.
During deep sleep, you get to choose which peripherals to keep on or shut down. However, by default, the ESP32 powers down any peripherals that are not in use with the wake-up source you provide.
Finally, you use the esp_deep_sleep_start() function to put your ESP32 into deep sleep mode.
Timer Wake Up
The ESP32 may enter deep sleep mode and then wake up at predefined times. This functionality is very useful if you are running projects that require time stamping or daily tasks while using little electricity.
Read the full article: https://lededitpro.com/esp32-timer-wake ... duino-ide/
ESP32 Timer Wake Up from Deep Sleep Mode with Arduino IDE
- LEDEdit PRO
We have more than 100 ESP32 projects, tutorials, and a Premium course. Learn ESP32. Using the next quick links, you’ll find all our ESP32 Guides with easy-to-follow instructions, source code, circuit schematics, videos, and images.
Re: ESP32 Timer Wake Up from Deep Sleep Mode with Arduino IDE
Thanks for sharing. These are really good references for those who wish to use ESP32 in low power modes.
Users browsing this forum: ESP_Sprite, Majestic-12 [Bot] and 73 guests
