Help with esp rainmaker 4 relays temperature and variable pwm led
I am having an extremely difficult time with this it might be because I’m busy but could anyone help me with creating code for esp rainmaker I need 4 relays that I can turn off and on, I need a temperature sensor ds18b20 to be able to read it and I need a variable pwm led slider, I need to be able to control all of these threw the app
Re: Help with esp rainmaker 4 relays temperature and variable pwm led
Can you specify what all you have tried first? That would help better understand the issue and help with it.
im am just having trouble with the code everytime i try to merge an led code i found on youtube with the relay code and same with the temperature code i am very new to coding and all i gotta do i get these things working and then im done much appreciated if you could write the code for me if you have the timeESP_Piyush wrote: ↑Mon Oct 16, 2023 6:49 amCan you specify what all you have tried first? That would help better understand the issue and help with it.
The 4 relay code works perfectly by itself but anytime i try to add the led or temperature it never works it would be much appreciated if you could make the code if you have free time. :ps i am a total noob and just needing to get this done
Users browsing this forum: AntonKozlenko and 16 guests
