Hi
I've spent quite a few years on different embedded platforms, but I am new to the ESP32 platform.
I am trying to get CAN/TWAI running on my esp32 device. I have tried using both an ESP32C6 and ESP32S3, but cannot get the TX line to communicate. It remains high. The same goes for the RX line. I pretty much have tried everything I can think of.
I have verified that my CAN transceiver is operational. I am using the TWAI example project provided by the IDF in vsCode.
Any assistance would be appreciated!
Regards
Ezra
ESP32 CAN/TWAI using IDF V5.1.1
Re: ESP32 CAN/TWAI using IDF V5.1.1
Seems to work fine here on both chips. Perhaps an incompatibility with your transceiver? Which one are you using?
@Ezra_Krause A couple of pointers
- Double check which GPIOs you are using and whether they are Input and/or output capable (see Datasheet for list of GPIOs and their capabilities/restrictions)
- Try running the self-test example without the transceiver to see if it's an issue with the GPIOs
Users browsing this forum: No registered users and 67 guests
