crash in dhcp_recv function in dhcp.c
jesper
Postby jesper » Thu Nov 09, 2017 5:00 pm
I have an Ethernet and Wifi board out on some sites.
At one place it would crash everytime Ethernet got at IP, on others it was ok.
This started to pop up with one of the lastest ESP-IDF versions, presumably because of changes to the ethernet and tcpip_adapter code.
I assign a static address to Ethernet and turn off DHCP.
Nailed this down to an issue in dhcp recv:
At the start of the function:
  /* Caught DHCP message from netif that does not have DHCP enabled? -> not interested */
  if((dhcp == NULL) || (dhcp->pcb_allocated == 0)) {
    goto free_pbuf_and_return;
And at the end:
free_pbuf_and_return:
  dhcp->msg_in = NULL;
  pbuf_free(p);
The
dhcp->msg_in = NULL
would cause a StoreProhibited error as dhcp was NULL.
The fix is simple:
  if (dhcp)
  pbuf_free(p);
/Jesper
MagicMicros Co., Ltd. - Rayong, Thailand
Electronics design, PCB layout & programming.
WiFive
Re: crash in dhcp_recv function in dhcp.c
Postby WiFive » Fri Nov 10, 2017 2:25 am
Can you do pull request on GitHub?
jesper
Postby jesper » Sat Nov 11, 2017 5:28 am
If I knew how to do that, I would have, LOL
Guess it's something I'll have to learn anyway, I'll see if I can find some information on how to do it.
Users browsing this forum: No registered users and 19 guests
