High Priority Task Appearing Not to Preempt Low Priority Task???
gfvalvo
Postby gfvalvo » Mon Aug 28, 2023 12:20 pm
Hello.
In the MRE below, the Consumer Task has a higher priority than the Producer Task. So, when the Producer sets the Event Group bit, I would expect the Consumer Task to preempt it, do its printing, and then block itself again BEFORE the (lower priority) Producer Task resumes executing. Therefore, it seems that the printing sequence should be:
[338536][I][sketch_aug28a.ino:24] producerFunction(): Producer Function: Setting Event Bits
[338537][I][sketch_aug28a.ino:34] consumerFunction(): Consumer Task Received Event Bit
[338536][I][sketch_aug28a.ino:26] producerFunction(): Producer Function: Event Bits Set
However, what I'm seeing is this:
Hope someone can explain where I went wrong. BTW, this is with Core 2.0.11 on an ESP32 Dev Board.
Thanks.
Code:
#include "Arduino.h"
void producerFunction(void *pvParameters);
void consumerFunction(void *pvParameters);
EventGroupHandle_t controlGroupHandle;
  vTaskDelay(2000);
  log_i("Starting");
  controlGroupHandle = xEventGroupCreate();
  xTaskCreatePinnedToCore(consumerFunction, "Consumer Task 1", 2000, NULL, 6, NULL, CONFIG_ARDUINO_RUNNING_CORE);
  vTaskDelay(500);
  xTaskCreatePinnedToCore(producerFunction, "Producer Task", 2000, NULL, 2, NULL, CONFIG_ARDUINO_RUNNING_CORE);
void producerFunction(void *pvParameters) {
  log_i("Producer Task Started\n");
  for (;;) {
    vTaskDelay(2000);
    log_i("Producer Function: Setting Event Bits");
    xEventGroupSetBits(controlGroupHandle, 1);
    log_i("Producer Function: Event Bits Set");
void consumerFunction(void *pvParameters) {
  log_i("Consumer Task Started");
  for (;;) {
    xEventGroupWaitBits(controlGroupHandle, 1, pdTRUE, pdFALSE, portMAX_DELAY);
    log_i("Consumer Task Received Event Bit");
gfvalvo
Re: High Priority Task Appearing Not to Preempt Low Priority Task???
Postby gfvalvo » Mon Aug 28, 2023 1:52 pm
Interestingly, it works as expected when using a Task Notification. So perhaps unblocking tasks using Event Groups doesn't happen immediately (regardless of the task's priority), but on the FreeRTOS tick boundaries???
TaskHandle_t consumerTaskHandle;
  vTaskDelay(2000);
  log_i("Starting");
  xTaskCreatePinnedToCore(consumerFunction, "Consumer Task 1", 2000, NULL, 6, &consumerTaskHandle, CONFIG_ARDUINO_RUNNING_CORE);
  vTaskDelay(500);
  for (;;) {
    vTaskDelay(2000);
    log_i("Producer Function: Sending Notification");
    xTaskNotifyGive(consumerTaskHandle);
  for (;;) {
    ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
    log_i("Consumer Task: Received Notification");
Output:
[  4545][I][sketch_aug28a.ino:23] producerFunction(): Producer Function: Sending Notification
[  4545][I][sketch_aug28a.ino:33] consumerFunction(): Consumer Task: Received Notification
[  4550][I][sketch_aug28a.ino:25] producerFunction(): Producer Function: Notification Sent
ESP_Sprite
Postby ESP_Sprite » Tue Aug 29, 2023 12:31 am
That is odd. As far as I can see from the documentation, event groups are supposed to be pre-emptive as well, so I can't explain this behaviour. I'm thinking that this may be some weird behaviour in the log_i function rather than the event groups, but I don't have a theory for how that could work.
gfvalvo
Postby gfvalvo » Tue Aug 29, 2023 10:23 am
Yes, I'd be hard pressed to explain that. Especially when it works as expected if I use a Task Notification rather than an Event Group bit.
gfvalvo
Postby gfvalvo » Tue Aug 29, 2023 11:46 am
Also, it behaves the same way with Serial.print(). FYI, see the code below using Task Notifications. Note the relative priority of the 3 tasks (1 Producer + 2 Consumers). You'll see that reflected in the order of the printouts. Exactly what would be expected when a higher-priority task preempts.
TaskHandle_t consumer0TaskHandle;
TaskHandle_t consumer1TaskHandle;
	vTaskDelay(2000);
	Serial.println("Starting");
	uint32_t ConsumerTaskNumber = 0;
	xTaskCreatePinnedToCore(consumerFunction, "Consumer Task 0", 2000, &ConsumerTaskNumber, 2, &consumer0TaskHandle, CONFIG_ARDUINO_RUNNING_CORE);
	vTaskDelay(500);
	ConsumerTaskNumber = 1;
	xTaskCreatePinnedToCore(consumerFunction, "Consumer Task 1", 2000, &ConsumerTaskNumber, 6, &consumer1TaskHandle, CONFIG_ARDUINO_RUNNING_CORE);
	vTaskDelay(500);
	xTaskCreatePinnedToCore(producerFunction, "Producer Task", 2000, NULL, 4, NULL, CONFIG_ARDUINO_RUNNING_CORE);
	Serial.println("Starting Producer Task");
	vTaskDelay(2000);
	Serial.printf("\nProducer Task: Sending Notifications\n");
	xTaskNotifyGive(consumer0TaskHandle);
	xTaskNotifyGive(consumer1TaskHandle);
	Serial.printf("Producer Task: Notifications Sent\n");
	for (;;) {
		vTaskDelay(1000);
	uint32_t taskNumber = *reinterpret_cast<uint32_t*>(pvParameters);
	Serial.printf("Starting Consumer Task # %d\n", taskNumber);
	for (;;) {
		Serial.printf("Consumer Task %d Received Notification\n", taskNumber);
Output:
Consumer Task 1 Received Notification
Consumer Task 0 Received Notification
ESP_Sprite
Postby ESP_Sprite » Wed Aug 30, 2023 2:54 am
What particular chip is this on, btw? (As in ESP32, ESP32-S2, ESP32-C3, ...)
gfvalvo
Postby gfvalvo » Wed Aug 30, 2023 2:37 pm
Confirmed the same behavior on:
Adafruit ESP32 Feather Huzzah: ESP-WROOM-32
ESP32 CAM: ESP32-S
ESP_Sprite
Postby ESP_Sprite » Thu Aug 31, 2023 9:10 am
Okay, checked this. I can also replicate this under ESP-IDF:
- This is not a logging oddity; checked this by setting/reading an atomic variable.
- This is an Espressif freertos port issue; changing over to the Amazon kernel fixes the behaviour.
- It seems to be Xtensa-specific, and/or happens only when FreeRTOS runs on both cores (I don't have a dual-core RiscV chip, so can't test on that).
I'll file this internally as an issue so my colleagues can take a look at this.
Users browsing this forum: No registered users and 67 guests
