About the timestamp accuracy in wifi packet acceptance
salieri
Postby salieri » Sun Aug 27, 2023 6:32 am
I call the function esp_cpu_get_cycle_count() in the wifi sniffer's interrupt function wifi_sniffer_packet_handler() and record the current CPU cycle count. Can I assume that this CPU cycle count corresponds to the local timestamp when a wifi packet arrives at the receiving end, and that the precision of this timestamp is the same as the CPU clock precision?
ESP_Sprite
Re: About the timestamp accuracy in wifi packet acceptance
Postby ESP_Sprite » Sun Aug 27, 2023 9:47 am
No, you cannot assume that as there may be an undeterminable amount of latency between the packet coming in and the handler being triggered.
salieri
Postby salieri » Sun Aug 27, 2023 11:04 am
But the process of receiving the two wifi packets is the same. I can assume that the cpu count difference between the two wifi packets is correct, right?
MicroController
Postby MicroController » Mon Aug 28, 2023 12:25 am
No. As Sprite said, there are several effects which can cause varying latencies (jitter) between the time a hardware event happens and the time your code gets to handle it, e.g. critical sections (also inside FreeRTOS itself) or higher-priority interrupts.
ESP_Sprite
Postby ESP_Sprite » Mon Aug 28, 2023 12:40 am
Aside from software things, you can also have hardware things like cache misses or pipeline stalls because something is talking to a slow peripheral (e.g. slow rtc memory)
salieri
Postby salieri » Mon Aug 28, 2023 5:45 am
Thanks for the answers, I probably understand what you guys are saying. I learned from a paper that you can use cpu cycle to record wifi packet arrival times as shown in the figure. Is there any way I can record the cpu cycle of wifi packet arrival?
Excerpts from the paper
ESP_Sprite
Postby ESP_Sprite » Mon Aug 28, 2023 6:41 am
It's not possible to do this on production firmware, in a way that will not have jitter, period. Perhaps the people making the paper were OK with jitter because they had a point to prove ('this is theoretically possible' vs 'this can be implemented in a practical sense'). You can try this if you want, but we as Espressif do not guarantee this will work, or that the timings won't change with a software or hardware change.
Users browsing this forum: klaatu2 and 132 guests
