Hi All,
I am MacOS user and I have installed esp-idf with visual studio code. Both esp-idf and vscode versions are latest.
When I tried to create new project from templates nothing happend. It is not able to create project. When I looked at videos "create project ..." button is working.
Is there anyone has or solved same problem ?
Thanks in advanced
VSCode can not create project
Re: VSCode can not create project
I have solved problem.
Solution is first you need to select esp-idf for first time. If you go through create project from template you do not have any chance. You have to go through show example than plug-in will ask you which esp-idf. Then you can go with create new project.
Users browsing this forum: No registered users and 39 guests
