Why doesn't uart_read_bytes() return immediately when data is available?
william.ferguson.au
Postby william.ferguson.au » Fri Aug 04, 2023 2:19 am
The docs for uart_read_bytes() imply that if data is available it will return immediately, otherwise it will wait for ticks_to_wait. But this is not the behaviour I am seeing on ESPIDF v4.4.
Instead it always waits for (at least) ticks_to_wait before returning. And if more data is added to the buffer before ticks_to_wait expires, it resets the ticks_to_wait and start counting from zero again.
Is this expected behaviour?
If I set ticks_to_wait to portMAX_DELAY, it doesn't return until the RX buffer is full.
Is that expected behaviour?
#include <esp_log.h>
#include <esp_err.h>
#include <driver/gpio.h>
#include <driver/uart.h>
#include <hal/uart_types.h>
#define TAG "main"
#define UART        UART_NUM_2
#define TXD_PIN     (GPIO_NUM_17)
#define RXD_PIN     (GPIO_NUM_16)
#define RX_BUF_SIZE 256
static void rx_task(__attribute__((unused)) void *arg) {
    uint8_t* rx_buffer = (uint8_t*) malloc(RX_BUF_SIZE);
    const uint32_t rx_timeout_ms = 15000;
    ESP_LOGI(TAG, "Starting RX task - portTICK_PERIOD_MS :  %d\n", portTICK_PERIOD_MS); // NB Need CONFIG_FREERTOS_HZ=1000 (portTick_PERIOD_MS=1) to ensure that we wakeup with ms precision.
    while (true) {
        ESP_LOGD(TAG, "Waiting for RX message timeout_ms=%d", rx_timeout_ms);
        const int32_t rx_bytes = uart_read_bytes(UART, rx_buffer, RX_BUF_SIZE, rx_timeout_ms / portTICK_PERIOD_MS);
        const int64_t message_received_us = esp_timer_get_time();
        ESP_LOGD(TAG, "Read %d bytes at %lldus - bytes:", rx_bytes, message_received_us);
        ESP_LOG_BUFFER_HEXDUMP(TAG, rx_buffer, rx_bytes, ESP_LOG_INFO);
    free(rx_buffer);
    vTaskDelete(NULL);
void app_main(void) {
    ESP_LOGI(TAG, "Start up");
    ESP_ERROR_CHECK(gpio_install_isr_service(ESP_INTR_FLAG_LEVEL1));
    const uart_config_t uart_config = {
            .baud_rate = 1000000,
            .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
            .source_clk = UART_SCLK_APB,
    ESP_ERROR_CHECK(uart_driver_install(UART, RX_BUF_SIZE * 2, 0, 0, NULL, 0));
    ESP_ERROR_CHECK(uart_param_config(UART, &uart_config));
    ESP_ERROR_CHECK(uart_set_pin(UART, TXD_PIN, RXD_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
    xTaskCreate(rx_task, "uart_rx_task", 4096, NULL, configMAX_PRIORITIES-1, NULL);
william.ferguson.au
Re: Why doesn't uart_read_bytes() return immediately when data is available?
Postby william.ferguson.au » Fri Aug 04, 2023 2:39 am
Am I correct in thinking that the length param specifies the number of bytes that MUST be read before the function returns (if it doesn't time out)?
I had been reading it as the length of the buffer that could be filled.
MicroController
Postby MicroController » Fri Aug 04, 2023 9:53 pm
Correct.
It's maybe not very intuitive, but the intention seems to be for UART reading to be done in response to a UART event (c.f. https://github.com/espressif/esp-idf/bl ... main.c#L56), in which case the event tells you when and how much data is available.
william.ferguson.au
Postby william.ferguson.au » Sat Aug 05, 2023 2:55 am
Thanks for the confirm.
I had already switched to using the Events and that is working fine. But the API and doco makes it's use non obvious. I would have saved a lot of time. with just a bit of clarity in the doco.
Users browsing this forum: No registered users and 148 guests
