nvs_entry_find Getting ERROR:ESP_ERR_INVALID_ARG
Zeni241
Postby Zeni241 » Tue Aug 01, 2023 9:39 am
I am trying to use the bellow code to find an entry in my NVS storage but I am getting error: ESP_ERR_INVALID_ARG.
My partition table is:
# Name	   Type	 SubType	 Offset	   Size	 Flags
nvs	      data	 nvs		   0x6000
otadata	      data	    ota		   0x2000
ota_0	       app	  ota_0	   	   0x180000
ota_1	       app	  ota_1	   	   0x180000
storage	       data	  spiffs	   0x6000
Code:
const char *nswifi = "nswifi";
nvs_handle_t nwifi;
void mysearch()
    err = nvs_open(nswifi, NVS_READWRITE, &nwifi);
    if (err != ESP_OK)
        printf("Error (%s) opening NVS handle!\n", esp_err_to_name(err));
        return;
    else
        nvs_iterator_t it = NULL;
        esp_err_t res = nvs_entry_find(NULL, nswifi, 0x01, &it);
        while (res == ESP_OK)
            nvs_entry_info_t info;
            nvs_entry_info(it, &info); // Can omit error check if parameters are guaranteed to be non-NULL
            printf("key '%s', type '%d' \n", info.key, info.type);
            res = nvs_entry_next(&it);
        ESP_LOGE(TAG, "Error: %s", esp_err_to_name(res));
        nvs_release_iterator(it);
I keep on getting error: E (3607) scan: Error: ESP_ERR_INVALID_ARG
I couldn’t figure out which argument is invalid in the code.
MicroController
Re: nvs_entry_find Getting ERROR:ESP_ERR_INVALID_ARG
Postby MicroController » Tue Aug 01, 2023 10:49 am
nvs_entry_find(...):
esp_err_t nvs_entry_find(const char *part_name, const char *namespace_name, nvs_type_t type, nvs_iterator_t *output_iterator)
    if (part_name == nullptr || output_iterator == nullptr) {
        return ESP_ERR_INVALID_ARG;
You need to pass it a partition name, not NULL.
Zeni241
Postby Zeni241 » Tue Aug 01, 2023 12:22 pm
Thanks MicroController for your quick response.
In fact somewhere in ESP-IDF documentation its written that
part_name – [in] Partition name NVS in the partition table. If pass a NULL than will use NVS_DEFAULT_PART_NAME (“nvs”).
Anyway I changed the code as bellow and its working fine.
nvs_handle_t nwifi;
    if (err != ESP_OK)
        return;
    else
        esp_err_t res = nvs_entry_find(NVS_DEFAULT_PART_NAME, nswifi, NVS_TYPE_ANY, &it);
        if (res != ESP_OK)
        else
Thanks again.
Users browsing this forum: sage1234 and 209 guests
