Code linting using SonarLint VSCode extension
zazas321
Postby zazas321 » Tue Jul 25, 2023 8:13 am
Hello. To make projects look more clean we use SolarLint extension that helps us prevent silly mistakes.
One of the issues I notice is that I am getting frequent warnings such as:
	 "call to undeclared function 'gpio_set_level'; ISO C99 and later do not support implicit function declarations",
Even though I have include:
 #include "driver/gpio.h"
Can someone help me understand what could be the issue and why it is not working properly?
ESP_igrr
Re: Code linting using SonarLint VSCode extension
Postby ESP_igrr » Tue Jul 25, 2023 11:18 am
Just to check, have you specified sonarlint.pathToCompileCommands setting? If you run the linter from the CLI, do you get the same error reported?
zazas321
Postby zazas321 » Wed Jul 26, 2023 4:26 am
After downloading SonarLint extension, I havent configured anything, I was under impression it should work right out of the box.
Regarding the CLI, after a quick google search I havent found a way to run it from the CLI.
It is very strange because for example it does not complain about esp_deep_sleep_start() function so it seems to detect something. But I cannot wrap my head around why it wouldnt detect gpio functions
ESP_igrr
Postby ESP_igrr » Wed Jul 26, 2023 6:22 am
In that case, please try configuring that option. Otherwise sonarLint can't find the paths where to search for the header files.
compile_commands.json file should be generated in build/ directory of your project.
zazas321
Postby zazas321 » Wed Jul 26, 2023 8:25 am
You were right. That was totally the issue.
I have went into SolarLint settings and noticed that it is refering to wrong compile_commands.json file:
${workspaceFolder}\build\bootloader\compile_commands.json
instead, I have replaced it with
${workspaceFolder}\build\compile_commands.json
And now it is working properly. Thanks for helping me out. Just out of curiosity though - what are the differences between build/bootloader/compile_commands.json and build/compile_commands.json?
Users browsing this forum: No registered users and 12 guests
