What is the proper way to deinit BluFi(want to release memory and resource after connect to WiFi)
specialvict
Postby specialvict » Thu Oct 26, 2017 4:00 pm
Dears,
I'm trying to use BluFi to implement the WiFi connection, which is a great way to do it.
However, when Bluetooth and WiFi coexist, it takes too much resource and the WiFi somehow keep disconnect after few seconds.
So I want to deinitialize the BluFi after connecting the WiFi successfully.
I saw the call back, but didn't see the API for call deinit manually.
static void example_event_callback(esp_blufi_cb_event_t event, esp_blufi_cb_param_t *param)
    /* actually, should post to blufi_task handle the procedure,
     * now, as a example, we do it more simply */
    switch (event) {
    case ESP_BLUFI_EVENT_INIT_FINISH:
        BLUFI_INFO("BLUFI init finish\n");
        esp_ble_gap_set_device_name(BLUFI_DEVICE_NAME);
        esp_ble_gap_config_adv_data(&example_adv_data);
    case ESP_BLUFI_EVENT_DEINIT_FINISH:
        BLUFI_INFO("BLUFI deinit finish\n");
Can anyone help me to do it?
Thanks in advance,
Victor
d1_jaime
Re: What is the proper way to deinit BluFi(want to release memory and resource after connect to WiFi)
Postby d1_jaime » Thu Nov 16, 2017 3:25 pm
Hey,
I was already looking at the source code so I may have found the API call for you.
 * @brief           This function is called to de-initialize blufi_profile
 * @return          ESP_OK - success, other - failed
esp_err_t esp_blufi_profile_deinit(void);
Users browsing this forum: Bing [Bot] and 104 guests
