using vs code extension 1.6.3 with idf 5.0.1
i have one project which doesn't show errors
and another project which shows them , i've compared both settings and they are identical, not sure what's going on here
not seeing errors on editor
Re: not seeing errors on editor
This looks like a settings issue. Please make sure your compiler path and IntelliSense mode are set correctly in .vscode/c_cpp_properties.json
If they are indeed the same, maybe try to refresh your IntelliSense from VsCode Command Palette with "C/C++: Reset IntelliSense Database" or try to rebuild the project it my refresh any stale metadata which my be causing the issue.
hi.. so this IS a settings issues, some of it has been discussed here https://github.com/espressif/vscode-esp ... issues/672
and here https://github.com/espressif/vscode-esp ... issues/748
there are few problems with new project created with esp-idf, one is that it uses always uses a bad problem matcher in the buiild
task "^[^\\.](.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$"
"version": "2.0.0",
"tasks": [
"label": "Build - Build project",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py build",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py build",
"options": {
"env": {
"PATH": "${env:PATH};${config:idf.customExtraPaths}"
"options": {
"env": {
"PATH": "${env:PATH}:${config:idf.customExtraPaths}"
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"${workspaceFolder}"
"pattern": {
"regexp": "^\\.\\.(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"fileLocation": "absolute",
"pattern": {
"regexp": "^[^\\.](.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"group": {
"kind": "build",
"isDefault": true
"label": "Set ESP-IDF Target",
"type": "shell",
"command": "${command:espIdf.setTarget}",
"problemMatcher": {
"owner": "cpp",
"pattern": {
"regexp": "^(.*):(//d+):(//d+)://s+(warning|error)://s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "Clean - Clean the project",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py fullclean",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py fullclean",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "Flash - Flash the device",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py -p ${config:idf.port} -b ${config:idf.flashBaudRate} flash",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py flash -p ${config:idf.portWin} -b ${config:idf.flashBaudRate}",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "Monitor: Start the monitor",
"type": "shell",
"command": "${config:idf.pythonBinPath} ${config:idf.espIdfPath}/tools/idf.py -p ${config:idf.port} monitor",
"windows": {
"command": "${config:idf.pythonBinPathWin} ${config:idf.espIdfPathWin}\\tools\\idf.py -p ${config:idf.portWin} monitor",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": [
"owner": "cpp",
"fileLocation": [
"relative",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"owner": "cpp",
"pattern": {
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"dependsOn": "Flash - Flash the device"
"label": "OpenOCD: Start openOCD",
"type": "shell",
"presentation": {
"echo": true,
"reveal": "never",
"focus": false,
"panel": "new"
"command": "openocd -s ${command:espIdf.getOpenOcdScriptValue} ${command:espIdf.getOpenOcdConfigs}",
"windows": {
"command": "openocd.exe -s ${command:espIdf.getOpenOcdScriptValue} ${command:espIdf.getOpenOcdConfigs}",
"options": {
"env": {
"options": {
"env": {
"problemMatcher": {
"owner": "cpp",
"pattern": {
"regexp": "^(.*):(\\d+):(\\d+):\\s+(warning|error):\\s+(.*)$",
"file": 1,
"line": 2,
"column": 3,
"severity": 4,
"message": 5
"label": "adapter",
"type": "shell",
"command": "${config:idf.pythonBinPath}",
"isBackground": true,
"options": {
"env": {
"PATH": "${env:PATH}:${config:idf.customExtraPaths}",
"PYTHONPATH": "${command:espIdf.getExtensionPath}/esp_debug_adapter/debug_adapter"
"problemMatcher": {
"background": {
"beginsPattern": "\bDEBUG_ADAPTER_STARTED\b",
"endsPattern": "DEBUG_ADAPTER_READY2CONNECT",
"activeOnStart": true
"pattern": {
"regexp": "(\\d+)-(\\d+)-(\\d+)\\s(\\d+):(\\d+):(\\d+),(\\d+)\\s-(.+)\\s(ERROR)",
"file": 8,
"line": 2,
"column": 3,
"severity": 4,
"message": 9
"args": [
"${command:espIdf.getExtensionPath}/esp_debug_adapter/debug_adapter_main.py",
"-e",
"${workspaceFolder}/build/${command:espIdf.getProjectName}.elf",
"-s",
"${command:espIdf.getOpenOcdScriptValue}",
"-ip",
"localhost",
"-dn",
"${config:idf.adapterTargetName}",
"-om",
"connect_to_instance"
"windows": {
"command": "${config:idf.pythonBinPathWin}",
"options": {
"env": {
"PATH": "${env:PATH};${config:idf.customExtraPaths}",
Users browsing this forum: No registered users and 12 guests
