idf5.1 esp32-c6 不断重启求助
ebaeab
Postby ebaeab » Sat Jun 17, 2023 10:50 am
ESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0x12 (LP_SWDT_SYS),boot:0x1c (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x4086c610,len:0x970
load:0x4086e610,len:0x21b4
load:0x40875718,len:0x186c
entry 0x4086c672
W (14) fpga: Project configuration is for internal FPGA use, not all functions will work
W (8) rtc_clk: rtc_clk_aI (8) boot: ESP-IDF v5.1-dev-1195-gfa5d0a3513-dirty 2nd stage bootloader
I (9) boot: compile time Jun 17 2023 18:29:03
I (9) boot: chip revision: V000
I (10) qio_mode: Enabling default flash chip QIO
I (11) boot.esp32c6: SPI Speed : 80MHz
I (12) boot.esp32c6: SPI Mode : QIO
I (13) boot.esp32c6: SPI Flash Size : 4MB
I (14) boot: Enabling RNG early entropy source...
W (16) rand: bootloader_random_enable non-functional for FPGA builds
I (18) boot: Partition Table:
I (18) boot: ## Label Usage Type ST Offset Length
I (20) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (22) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (24) boot: 2 factory factory app 00 00 00010000 00100000
I (26) boot: End of partition table
I (27) esp_image: segment 0: paddr=00010020 vaddr=42820020 size=06510h ( 25872) map
I (31) esp_image: segment 1: paddr=00016538 vaddr=40800000 size=0799ch ( 31132) load
I (35) esp_image: segment 2: paddr=0001dedc vaddr=40807a00 size=00bach ( 2988) load
I (36) esp_image: segment 3: paddr=0001ea90 vaddr=50000010 size=00010h ( 16) load
I (36) esp_image: segment 4: paddr=0001eaa8 vaddr=00000000 size=01570h ( 5488)
I (39) esp_image: segment 5: paddr=00020020 vaddr=42000020 size=100f0h ( 65776) map
I (48) boot: Loaded app from partition at offset 0x10000
I (48) boot: Disabling RNG early entropy source...
W (48) rand: bootloader_random_disable non-functional for FPGA builds
I (52) cpu_start: Pro cpu up.
W (52) fpga: Project configuration is for internal FPGA use, not all functions will work
W (53) rtc_time: rtc_time_get() has not been implemented yet
W (54) CACHE_ERR: esp_cache_err_int_init() has not been implemented yet
I (56) cpu_start: Pro cpu start user code
I (57) cpu_start: cpu freq: 160000000 Hz
I (58) cpu_start: Application information:
I (59) cpu_start: Project name: factory_test
I (61) cpu_start: App version: 2dd122b-dirty
I (62) cpu_start: Compile time: Jun 17 2023 18:28:13
I (64) cpu_start: ELF file SHA256: ba40e5e0e5545f08...
I (65) cpu_start: ESP-IDF: v5.1-dev-1195-gfa5d0a3513-dirty
I (67) heap_init: Initializing. RAM available for dynamic allocation:
I (69) heap_init: At 408094A0 len 00073170 (460 KiB): D/IRAM
I (70) heap_init: At 4087C610 len 00002F54 (11 KiB): STACK/DRAM
I (72) heap_init: At 50000020 len 00003FE0 (15 KiB): RTCRAM
W (73) rtc_time: rtc_time_get() has not been implemented yet
W (75) rtc_time: rtc_time_get() has not been implemented yet
I (77) spi_flash: detected chip: gd
I (78) spi_flash: flash io: qio
I (79) cpu_start: Starting scheduler.
I (80) main: hello esp
ESP_Penguin_Helper
Re: idf5.1 esp32-c6 不断重启求助
Postby ESP_Penguin_Helper » Tue Jul 18, 2023 9:22 am
你好,你方便用 Hello_world 或其他比较简单的代码试试吗?
Users browsing this forum: No registered users and 44 guests
