Need clarity in ESP-ADF equalizer
_jasim_
Postby _jasim_ » Fri Apr 28, 2023 6:44 am
I'm doing an audio recording program using I2S PDM mic. I need to amplify and record the audio in vocal range of frequencies. For this I'm using the equalizer pipeline. Here I'm having some confusions in the configuration. As per the documentation (https://espressif-docs.readthedocs-host ... lizer.html) equalizer has 10 bands. But in macro DEFAULT_EQUALIZER_CONFIG() definition, gain is being set for 20 bands. It is initialized as
int set_value_gain[NUMBER_BAND * 2] = { -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13};
In equalizer example, the equalizer is configured as follows
 equalizer_cfg_t eq_cfg = DEFAULT_EQUALIZER_CONFIG();
int set_gain[] = { -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13, -13};
eq_cfg.set_gain = set_gain; // The size of gain array should be the multiplication of NUMBER_BAND and number channels of audio stream data. The minimum of gain is -13 dB.
equalizer = equalizer_init(&eq_cfg);
As per the comment in set gain "The size of gain array should be the multiplication of NUMBER_BAND and number channels of audio stream data". But in DEFAULT_EQUALIZER_CONFIG() the number of channels is 1. So the The size of gain array should be NUMBER_BAND*1 that is 10. Then why there are 20 elements in the array.
Please give clarity on this.
Users browsing this forum: No registered users and 7 guests
