Hello to the forum,
this is my first topic. I am new to ESP32 and especially ESP32S3. I am have successfully installed ESP-IDF in VSCode.
I did successfully run "blink" and "hello world" examples.
But when I run "i2c_self_test" example, I get a stack overflow.
Needless to say that I did not change any line in the code. I did connect the pins as shown in readme file.
I got ESP-IDF v5 installed.
How can I solve my issue?
ESP32S3-DEVKITC-1 I2C Example error
Re: ESP32S3-DEVKITC-1 I2C Example error
Have you configure the target for ESP32S3 ?
1. Delete existing build folder
2. Use the ESP-IDF: Set Espressif device target command
3. Use the ESP-IDF: Select OpenOCD Board Configuration command to choose openOCD board or interface to use.
You can also look at the troubleshooting guide to understand your setup and share the build output to see what went wrong.
Users browsing this forum: No registered users and 19 guests
