"ESP32-C3-WROOM-02" module no response to AT commands
nataut
Postby nataut » Fri Apr 14, 2023 1:16 pm
Hi all
I'm working on a project that use the "ESP32-C3-WROOM-02" module. I followed the "ESP-AT User Guide" (downloaded from ESPRESSIF web site) but I can't communicate with AT commands (the module doesn't answer).
If I well understand, there is no specific firmware for "ESP32-C3-WROOM-02" module but is possible to use the one for "ESP32-C3-MINI-1" module, is this correct?
I programmed the "ESP32-C3-WROOM-02" using the "ESP32-C3-MINI-1" firmware but I don't get any response when I send the AT commands.
On the "ESP32-C3-WROOM-02" module is mounted the "ESP32-C3" device, correct? Are GPIO6 (RX) and GPIO7 (TX) the pins to send AT commands to "ESP32-C3" device?
Many thanks
bidrohini
Re: "ESP32-C3-WROOM-02" module no response to AT commands
Postby bidrohini » Sat Apr 15, 2023 2:55 pm
Are you using any serial port terminal app or sending AT commands using Arduino IDE?
nataut
Postby nataut » Mon Apr 17, 2023 10:08 am
I used several serial port terminal apps but not Arduino IDE.
Based on the "ESP-AT User Guide", the default UART1 configuration should be
115200 bps
1 stop bit
none Parity
RTS and CTS, both enabled
is it right?
ESP32-C3-WROOM-02 module is mounted on a my customized hardware that doesn't manage the RTS and CTS control signals, so I shorted to GND the CTS pin of the ESP32-C3 device. Even with this trick, I don't get any response
esp-at
Postby esp-at » Mon Apr 17, 2023 12:11 pm
Here is the hardware connection layout, could you please take a look.
https://docs.espressif.com/projects/esp ... ction.html
if the issue still exists, please provide the logs of UART0 and UART1, and the hardware connection layout of yours, and the steps you did.
thanks.
Users browsing this forum: No registered users and 14 guests
