Hi everyone,
Hopefully I've got the right sub-forum for this, so here goes.
I'm taking my first steps into ESP32 from Arduino, and I'm failing in setting up my toolchain. What I'm trying to do...
- I want to be able to use some of the Arduino libraries to help with I2C peripherals
- I need to be able to edit the component config in order to enable the external XTAL 32khz clock input
- Must be Windows based.
The fact I'm failing to find this in Googling suggests I'm missing something obvious here, but any help will be hugely appreciated. Thanks.
Arduino IDE, ESP-IDF, Make menuconfig
Re: Arduino IDE, ESP-IDF, Make menuconfig
Try platformIO. Its the simplest way to get started for ESP32.
Thank you, making some progress with PIO .
Users browsing this forum: Baidu [Spider] and 73 guests
