Hi all,
thanks for help.
Adam
esp32 not recognize by win 11, how to fix
Re: esp32 not recognize by win 11, how to fix
Kindly provide (a lot) more details about what you are trying to achieve.
Exactly which board are you using? Is there any picture or link? Most probably a driver software is missing.
I assume you mean you have an ESP32 development module that has a USB port that, when connected to your PC, Windows 11 Device Manager doesn't recognize it?
If that's the case, your ESP32 module uses a particular USB to UART bridge chip and Windows 11 may not have a native driver for it. Check your device manager for an unknown device when you plug it in and search for the driver. In my case, I use the ESP32 Pico Devkit and it uses CP210x USB to UART Bridge so Windows 11 needs a driver for that particular chip. That may or may not be the one your module uses. You need to check.
Users browsing this forum: No registered users and 70 guests
