IDF V4.4.4 编译 ESP-BOX 的 factory_demo失败
ssssss
Postby ssssss » Wed Mar 29, 2023 2:28 am
报错如下:
PS E:\Espressif\frameworks\esp-idf-v4.4.4\esp-box\examples\factory_demo> idf.py build
Executing action: all (aliases: build)
Running cmake in directory e:\espressif\frameworks\esp-idf-v4.4.4\esp-box\examples\factory_demo\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s3 -DCCACHE_ENABLE=1 e:\espressif\frameworks\esp-idf-v4.4.4\esp-box\examples\factory_demo"...
-- Found Git: E:/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Found assembler: E:/Espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe
-- Check for working C compiler: E:/Espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped
-- Check for working CXX compiler: E:/Espressif/tools/xtensa-esp32s3-elf/esp-2021r2-patch5-8.4.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped
-- Building ESP-IDF components for target esp32s3
Skipping optional dependency: espressif/led_strip
Skipping optional dependency: espressif/qrcode
Solving dependencies requirements
............................................................................................................................................................................................................Skipping optional dependency: espressif/mdns
...........................CMake Error at E:/Espressif/frameworks/esp-idf-v4.4.4/tools/cmake/build.cmake:452 (message):
  HINT: Please check manifest file of the following component(s): main
  ERROR: Because chmorgan/esp-audio-player (1.0.4) depends on idf (>=5.0.0)
  which doesn't match any versions, chmorgan/esp-audio-player is forbidden.
  So, because project depends on chmorgan/esp-audio-player (1.0.4), version
  solving failed.
  E:/Espressif/frameworks/esp-idf-v4.4.4/tools/cmake/project.cmake:384 (idf_build_process)
  CMakeLists.txt:14 (project)
See also "E:/Espressif/frameworks/esp-idf-v4.4.4/esp-box/examples/factory_demo/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1
ESP_Xuxin
Re: IDF V4.4.4 编译 ESP-BOX 的 factory_demo失败
Postby ESP_Xuxin » Wed Mar 29, 2023 4:11 am
最新的仓库,应该不支持 4.4 的版本了,需要切换到 5.0 版本
Users browsing this forum: No registered users and 9 guests
