I'm running idf5 and vscode extension. When I run the config gui I can not find the options to change log output baud and monitor baud. If I edit the sdkconfig file directly my changes get overwritten the next time I build. I thought the sdkconfig was the source of truth for a project but it seems this is not true for the vscode extension.
Where are these settings saved for a esp32-vscode project?
Thanks,
Felix
VSCODE extension - Can not change monitor baud
Re: VSCODE extension - Can not change monitor baud
I have a further related question... How can I define configINCLUDE_FREERTOS_TASK_C_ADDITIONS_H? Can I add this option to the SDKCONFIG somehow without modifying the kconfig for the freertos component?
If the option is not visible in menuconfig is probably because it depends on another configuration that hides this value. When the build happens there is a configuration validation that will use a default value if another configuration is disabled.
@ESP_bignacio why would the monitor baud depend on another value and be hidden? Perhaps my project has corrupted config somewhere. Is there a good overview of how this works with the VSCODE plugin anywhere? I can not find where the "source of truth" for the config is stored. As I said, if I manually change the config values they get overwritten when I build. Where are the values coming from?
Users browsing this forum: No registered users and 13 guests
