Timer and PWM issue
MitchSF
Timer and PWM issue
Postby MitchSF » Sun Oct 08, 2017 7:08 pm
This works perfectly the first time toneOn() is executed, after that the ISR is never called. I tried disabling all the ledc* functions to see if there was a conflict, with the same result. Is it ok to call timerAlarmDisable() from within the ISR? Thanks in advance.
byte buzzerPin = 12;
hw_timer_t * toneTimer = NULL;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
  toneOff() ISR
void IRAM_ATTR toneOff()  {
  timerAlarmDisable(toneTimer);
  ledcWriteTone(4, 0);
  Serial.println("OFF");
  while (!Serial);
  toneTimer = timerBegin(1, 80, true); // initialize timer - timer_id = 1; divider=80; countUp = true;
  timerAttachInterrupt(toneTimer, &toneOff, true); // edge = true
  ledcAttachPin(buzzerPin, 4);
  ledcSetup(4, 2000, 8);
  toneOn(50, 40, 1000); // for testing
  delay(2000);
void toneOn(byte volume, int dur, int frequency) {
  ledcWriteTone(4, frequency);
  ledcWrite(4, volume);
  timerAlarmWrite(toneTimer, dur * 1000, true); // 1000 per ms
  timerAlarmEnable(toneTimer);
  Serial.println("ON");
Users browsing this forum: No registered users and 36 guests
