esp32 ulp timer
saruhan
esp32 ulp timer
Postby saruhan » Sat Mar 11, 2023 10:10 am
I use esp32 ulp example -> https://github.com/espressif/esp-idf/tr ... lp_fsm/ulp
I need to advance pulse count unit.
Pulse count :
 * SPDX-FileCopyrightText: 2022 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
/* ULP Example: pulse counting
   This file contains assembly code which runs on the ULP.
   ULP wakes up to run this code at a certain period, determined by the values
   in SENS_ULP_CP_SLEEP_CYCx_REG registers. On each wake up, the program checks
   the input on GPIO0. If the value is different from the previous one, the
   program "debounces" the input: on the next debounce_max_count wake ups,
   it expects to see the same value of input.
   If this condition holds true, the program increments edge_count and starts
   waiting for input signal polarity to change again.
   When the edge counter reaches certain value (set by the main program),
   this program running triggers a wake up from deep sleep.
/* ULP assembly files are passed through C preprocessor first, so include directives
   and C macros may be used in these files
#include "sdkconfig.h"
#include "soc/rtc_cntl_reg.h"
#include "soc/rtc_io_reg.h"
#include "soc/soc_ulp.h"
#include "soc/sens_reg.h"
	/* Define variables, which go into .bss section (zero-initialized data) */
	.bss
	/* Next input signal edge expected: 0 (negative) or 1 (positive) */
	.global next_edge
next_edge:
	.long 0
	/* Counter started when signal value changes.
	   Edge is "debounced" when the counter reaches zero. */
	.global debounce_counter
debounce_counter:
	.long 0
	/* Value to which debounce_counter gets reset.
	   Set by the main program. */
	.global debounce_max_count
debounce_max_count:
	.long 0
	/* Total number of signal edges acquired */
	.global edge_count
edge_count:
	.long 0
	/* Number of edges to acquire before waking up the SoC.
	.global edge_count_to_wake_up
edge_count_to_wake_up:
	.long 0
	/* RTC IO number used to sample the input signal.
	   Set by main program. */
	.global io_number
io_number:
	.long 0
	/* Code goes into .text section */
	.text
	.global entry
entry:
	/* Load io_number */
	move r3, io_number
	ld r3, r3, 0
#if CONFIG_IDF_TARGET_ESP32S2
    /* ESP32S2 powers down RTC periph when entering deep sleep and thus by association SENS_SAR_IO_MUX_CONF_REG */
	WRITE_RTC_FIELD(SENS_SAR_IO_MUX_CONF_REG, SENS_IOMUX_CLK_GATE_EN, 1)
#elif CONFIG_IDF_TARGET_ESP32S3
    /* ESP32S3 powers down RTC periph when entering deep sleep and thus by association SENS_SAR_PERI_CLK_GATE_CONF_REG */
    WRITE_RTC_FIELD(SENS_SAR_PERI_CLK_GATE_CONF_REG, SENS_IOMUX_CLK_EN, 1);
#endif
	/* Lower 16 IOs and higher need to be handled separately,
	 * because r0-r3 registers are 16 bit wide.
	 * Check which IO this is.
	move r0, r3
	jumpr read_io_high, 16, ge
	/* Read the value of lower 16 RTC IOs into R0 */
	READ_RTC_REG(RTC_GPIO_IN_REG, RTC_GPIO_IN_NEXT_S, 16)
	rsh r0, r0, r3
	jump read_done
	/* Read the value of RTC IOs 16-17, into R0 */
read_io_high:
	READ_RTC_REG(RTC_GPIO_IN_REG, RTC_GPIO_IN_NEXT_S + 16, 2)
	sub r3, r3, 16
	rsh r0, r0, r3
read_done:
	and r0, r0, 1
	/* State of input changed? */
	move r3, next_edge
	ld r3, r3, 0
	add r3, r0, r3
	and r3, r3, 1
	jump changed, eq
	/* Not changed */
	/* Reset debounce_counter to debounce_max_count */
	move r3, debounce_max_count
	move r2, debounce_counter
	ld r3, r3, 0
	st r3, r2, 0
	/* End program */
	halt
	.global changed
changed:
	/* Input state changed */
	/* Has debounce_counter reached zero? */
	move r3, debounce_counter
	ld r2, r3, 0
	add r2, r2, 0 /* dummy ADD to use "jump if ALU result is zero" */
	jump edge_detected, eq
	/* Not yet. Decrement debounce_counter */
	sub r2, r2, 1
	st r2, r3, 0
	/* End program */
	halt
	.global edge_detected
edge_detected:
	ld r3, r3, 0
	st r3, r2, 0
	/* Flip next_edge */
	move r3, next_edge
	ld r2, r3, 0
	add r2, r2, 1
	and r2, r2, 1
	st r2, r3, 0
	/* Increment edge_count */
	move r3, edge_count
	ld r2, r3, 0
	add r2, r2, 1
	st r2, r3, 0
	/* Compare edge_count to edge_count_to_wake_up */
	move r3, edge_count_to_wake_up
	ld r3, r3, 0
	sub r3, r3, r2
	jump wake_up, eq
	/* Not yet. End program */
	halt
I need save pulse count to variable every hour. it is about ulp_edge_count .
How can i save it to variable in every hour?
Thanks for advance.
Users browsing this forum: Bing [Bot] and 126 guests
