ESP32 as a SDIO device issues.
TheSAM32
Postby TheSAM32 » Sun Feb 19, 2023 9:40 pm
Hello!
I am attempting to use the SDIO device on an ESP32 WROVER module in connection with an STM32 and have had some issues seeing any action on the ESP32s side. I believe the hardware has been checked out, and pull-up resistors are present, so an issue must be in my software.
At the current moment, I am doing nothing but using the terminal to send CMD 52 6 == 8, part of the initialization specified by Esprecssif . Instead of getting a response, it times out. Looking at the oscilloscope the signal matches what I would expect on the CMD line with no seen response from the ESP32.
I have tried every timing mode, and there are no issues printed in the console about any failure to initialize SDIO. Here is my code so far, mostly built from the SDIO example for testing.
Initialization:
	esp_err_t ret;
	 * Initialize SDIO
	sdio_slave_config_t sdioConfig = {
			.timing = SDIO_SLAVE_TIMING_NSEND_NSAMPLE,
			.sending_mode = SDIO_SLAVE_SEND_PACKET,
			.send_queue_size = TEABUSCLIENT_QUE_SIZE,
			.recv_buffer_size = TEABUSCLIENT_BUFFER_SIZE,
			.event_cb = TeaBusClient_SDIOCallback,
			.flags = 0,
	ret = sdio_slave_initialize(&sdioConfig);
	if(ret != ESP_OK){
		printf("Error initializing SDIO. Error %d!\n", ret);
		return;
	 * Initialize SDIO registers
	for(uint8_t i = 0; i < TEABUSCLIENT_BUFFER_NUMBER; i++){
		sdio_slave_buf_handle_t handle = sdio_slave_recv_register_buf(TeaBusClient_Buffer[i]);
		ret = sdio_slave_recv_load_buf(handle);
		if(ret != ESP_OK){
			printf("Error adding SDIO buffer %d. Error %d!\n", i, ret);
			return;
	sdio_slave_set_host_intena(SDIO_SLAVE_HOSTINT_SEND_NEW_PACKET |
			SDIO_SLAVE_HOSTINT_BIT0 | SDIO_SLAVE_HOSTINT_BIT1 |
			SDIO_SLAVE_HOSTINT_BIT2 | SDIO_SLAVE_HOSTINT_BIT3 |
			SDIO_SLAVE_HOSTINT_BIT4 | SDIO_SLAVE_HOSTINT_BIT5 |
			SDIO_SLAVE_HOSTINT_BIT6 | SDIO_SLAVE_HOSTINT_BIT7);
	sdio_slave_start();
	printf("SDIO interface started!\n");
Update:
	esp_err_t ret;
	uint16_t packetSize = 0;
	sdio_slave_buf_handle_t handle;
	ret = sdio_slave_recv_packet(&handle, 0);
	if(ret != ESP_ERR_TIMEOUT){
		printf("SDIO receive begin. code %d!\n", ret);
		// Receive all possible data
		TeaBusClient_Static.recvQueue[packetSize++] = handle;
		while (ret == ESP_ERR_NOT_FINISHED) {
			ret = sdio_slave_recv_packet(&handle, portMAX_DELAY);
			printf("SDIO extended packed %d!\n", packetSize);
		if(ret != ESP_OK){
			printf("SDIO Error %d!\n", ret);
			return;
		// Calculate full packet size
		uint16_t packetLen = 0;
		for (uint16_t i = 0; i < packetSize; i++) {
			size_t buf_len;
			sdio_slave_recv_get_buf(TeaBusClient_Static.recvQueue[i], &buf_len);
			packetLen += buf_len;
		printf("Packet Received. Length: %d!\n", packetLen);
The code for the event_cb is empty right now.
For any curiosity about what initialization looks like on the STM32 side, here is its current state. Note most its taken from HAL:
	if(TeaBus_Ready){
		Terminal_PrintF(&RootTerminal_Static, "Warning, TeaBus already initialized.\n");
	    return;
	__HAL_RCC_SDIO_CLK_ENABLE();
	__HAL_RCC_GPIOC_CLK_ENABLE();
	__HAL_RCC_GPIOD_CLK_ENABLE();
	GPIO_InitTypeDef GPIO_InitStruct = {0};
	GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11
	                          |GPIO_PIN_12;
	GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
	GPIO_InitStruct.Pull = GPIO_PULLUP;
	GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
	GPIO_InitStruct.Alternate = GPIO_AF12_SDIO;
	HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
	GPIO_InitStruct.Pin = GPIO_PIN_2;
	HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
	//Initalzie SDIO Hardware
	HAL_StatusTypeDef status;
	SD_InitTypeDef Init;
	/* Default SDIO peripheral configuration for SD card initialization */
	Init.ClockEdge           = SDIO_CLOCK_EDGE_RISING;
	Init.ClockBypass         = SDIO_CLOCK_EDGE_FALLING;
	Init.ClockPowerSave      = SDIO_CLOCK_POWER_SAVE_DISABLE;
	Init.BusWide             = SDIO_BUS_WIDE_1B;
	Init.HardwareFlowControl = SDIO_HARDWARE_FLOW_CONTROL_DISABLE;
	Init.ClockDiv            = SDIO_INIT_CLK_DIV;
	/* Initialize SDIO peripheral interface with default configuration */
	status = SDIO_Init(SDIO, Init);
	if(status != HAL_OK)
	    Terminal_PrintF(&RootTerminal_Static, "Failed to initialize SDIO. Error: %d\n", status);
	    return;
	__SDIO_DISABLE(SDIO);
	SDIO_PowerState_ON(SDIO);
	__SDIO_ENABLE(SDIO);
	TeaBus_Ready = 1;
	Terminal_PrintF(&RootTerminal_Static, "SDIO OK\n", status);
I have also attached an image of the CMD signal generated by the STM32. I am probing the module pins themselves with CMD on GPIO15, CLK on GPIO14, and DAT 0-4 is 2, 4, 12, 13.
Oscilloscope decoded goes as follows:
S D CMDINX R FFF A S ADDRESS           S DATA     CRC7    E
0 1 110100 1 000 1 0 00000000000000110 0 00001000 1010111 1
Any help in resolving this is greatly appreciated. This is my first time using SDIO like this, and my first time using an ESP32 in quite a while.
Users browsing this forum: No registered users and 97 guests
