ESP ADF : Pipe (SDCard - MP3Decoder - I2S) => Wrong Sample Rate
ThomasESP32
Postby ThomasESP32 » Tue Feb 14, 2023 2:23 pm
Good afternoon,
I have tried to implement a pipe in order to decode a MP3 file on a SDCard and to sent it to an audio amplifier using I2S.
The program compiles normally, using an oscilloscope, I can see datas on the I2S_Out, so I think that the MP3 file is decoded and sent.
However, the LR_CLK and the BIT_CLK are not OK.
I would like to have a LR_CLK = 16KHz (Equal to the sample rate) but I have a LR_CLK = 1,3KHz.
The BIT_CLK is 96Khz.
So I do not ear anything on my amplifier.
Here is my config :
i2s_stream_cfg_t i2s_cfg;
i2s_cfg.type = AUDIO_STREAM_WRITER;
i2s_cfg.i2s_config.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX);
i2s_cfg.i2s_config.sample_rate = 16000;
i2s_cfg.i2s_config.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT;
i2s_cfg.i2s_config.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT;
i2s_cfg.i2s_config.communication_format = I2S_COMM_FORMAT_STAND_I2S;
i2s_cfg.i2s_config.intr_alloc_flags = ESP_INTR_FLAG_LEVEL2 | ESP_INTR_FLAG_IRAM;
i2s_cfg.i2s_config.dma_buf_count = 3;
i2s_cfg.i2s_config.dma_buf_len = 300;
i2s_cfg.i2s_config.use_apll = false;
i2s_cfg.i2s_config.tx_desc_auto_clear = true;
i2s_cfg.i2s_config.fixed_mclk = 0;
i2s_cfg.i2s_config.mclk_multiple = I2S_MCLK_MULTIPLE_384;
i2s_cfg.i2s_port = I2S_NUM_0;
i2s_cfg.use_alc = false;
i2s_cfg.volume = 0;
i2s_cfg.out_rb_size = I2S_STREAM_RINGBUFFER_SIZE;
i2s_cfg .task_stack = I2S_STREAM_TASK_STACK;
i2s_cfg.task_core = I2S_STREAM_TASK_CORE;
i2s_cfg.task_prio = I2S_STREAM_TASK_PRIO;
i2s_cfg.stack_in_ext = false;
i2s_cfg.multi_out_num = 0;
i2s_cfg.uninstall_drv = true;
i2s_cfg.need_expand = false;
i2s_cfg.expand_src_bits = I2S_BITS_PER_SAMPLE_16BIT;
i2s_stream_writer = i2s_stream_init(&i2s_cfg);
Could you please help me on the subject ?
Best regards,
Thomas TRUILHE.
AndiRo
Re: ESP ADF : Pipe (SDCard - MP3Decoder - I2S) => Wrong Sample Rate
Postby AndiRo » Tue Feb 14, 2023 3:26 pm
Hello ThomasESP32
at first it is recommended to initialise your config with
i2s_stream_cfg_t i2s_cfg = I2S_STREAM_CFG_DEFAULT();
and then override the default config values
If you have no i2s to DAC chip you have to use the internal one
for this you have to define
SOC_I2S_SUPPORTS_ADC_DAC
you also can use
i2s_stream_set_clk(audio_element_handle_ti2s_stream, int rate, int bits, int ch)
to set the clock and bit rate
Best regards
AndiRo
Postby AndiRo » Wed Feb 15, 2023 7:25 am
Hello Thomas
at first it is recomended to initialise your struct like this:
and then override the default values
like in the samples
if you do not have an i2s to dac then you need to define
you can also try this function to set the clock
esp_err_t i2s_stream_set_clk(audio_element_handle_ti2s_stream, int rate, int bits, int ch)
there are also a lot of examples in esp-adf
https://github.com/espressif/esp-adf/tr ... p3_control
best regards
Users browsing this forum: No registered users and 20 guests
