I downloaded the ESP32-PICO-D4-V2.4.0.0 and flashed it to the ESP32-PICO
The flashing worked and I can se the startup on the log port.
I connect the other serial port on 19 and 22 and after the reset of the ESP32-PICO i get the message 'ready' on the console output of the AT serial port. I try to send AT adding cr and lf but I do not get any response. The speed is correct since I receive the 'ready' message. I do not have any flow control in the terminal program since this is not nessecary according to your document.
Is the provided bin file incorrect or what is wrong ?
Best regards
AT command is not working
Re: AT command is not working
Hi,bmc@bc.dk wrote: ↑Mon Jan 02, 2023 5:58 pmHi,
Best regards
Receiving 'ready' can only prove that tx (GPIO22) is normal. You can check the connection of rx (GPIO19) again. The PICO AT v2.4 firmware communication I tested is normal. The hardware uses ESP32-PICO-KIT_V4. The detailed connection and log are shown in the following figure: Released Firmware: https://docs.espressif.com/projects/esp ... aries.html
Users browsing this forum: No registered users and 54 guests
