Flash Download tool and combining bin for production
rjustice
Postby rjustice » Fri Nov 04, 2022 2:32 pm
On ESP32-C3 I have it setup as:
  • Single app not OTA
  • 0x8000 offset of partition table
  • flash encryption is set to release mode
When I use flash to v3.9.3 and set it up as follows:
...and press start, it appears to flash the device from the loading bar at the bottom, but it doesn't.
If I use the command prompt and use:
idf.py flash monitor -p COM11
The device is flashed and encrypted as expected.
Questions:
  • What have I setup incorrectly
  • what are the outputs in the build folder I should use
  • ultimately I would like to combine to a single bin to simplify the setup, is there a tutorial somewhere?
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 90 guests
