Change IDF_TARGET in VSCode
import11
Postby import11 » Tue Sep 13, 2022 10:00 pm
I'm trying to setup an example project in VSCode using the ESP-IDF Extension and am having issues with the target chip
When I run:
idf.py set-target esp32s3
I get this error:
IDF_TARGET in CMake cache does not match IDF_TARGET environment variable.
To change the target, clear the build directory and sdkconfig file,
and build the project again
I tried the deleting the build folder and sdkconfig file, but it always builds as ESP32.
When I run:
echo $IDF_TARGET
I get back:
esp32
The bottom banner of VSCode shows ESP32 as the target and if I click that it just sets to the directory, but I don't have an option to change it.
Where can I actually modify the IDF_TARGET? Please help me get this project up and running.
sukeshak
Contact:
Re: Change IDF_TARGET in VSCode
Postby sukeshak » Thu Sep 22, 2022 10:44 am
Try installing the correct support package of ESP-IDF from here. In your case esp32-s3
https://idf.espressif.com/
Users browsing this forum: Majestic-12 [Bot] and 378 guests
