ESP-AT LAN8710A Error
wojlej
Postby wojlej » Mon Sep 12, 2022 8:32 pm
I am trying run AT-commands firmware for my ESP32-WROOM-32U with eth LAN8710A chip.
In the attachment I am sending the connection diagram:
esp32_eth.pdf
(122.77 KiB) Downloaded 304 times
I reconfigured the UART for AT commands to pins compatible with the schematic. AT communication works. I configured the RMII interface with an external clock on pin 17. In the attachment (zip) I am sending the sdconfig and binaries. I am using newest version of idf.py.
This is segment of eth config:
  1. #
  2. # Ethernet
  3. #
  4. CONFIG_ETH_ENABLED=y
  5. CONFIG_ETH_USE_ESP32_EMAC=y
  6. CONFIG_ETH_PHY_INTERFACE_RMII=y
  7. # CONFIG_ETH_PHY_INTERFACE_MII is not set
  8. # CONFIG_ETH_RMII_CLK_INPUT is not set
  9. CONFIG_ETH_RMII_CLK_OUTPUT=y
  10. # CONFIG_ETH_RMII_CLK_OUTPUT_GPIO0 is not set
  11. CONFIG_ETH_RMII_CLK_OUT_GPIO=17
  12. CONFIG_ETH_DMA_BUFFER_SIZE=512
  13. CONFIG_ETH_DMA_RX_BUFFER_NUM=10
  14. CONFIG_ETH_DMA_TX_BUFFER_NUM=10
  15. # CONFIG_ETH_USE_SPI_ETHERNET is not set
  16. # CONFIG_ETH_USE_OPENETH is not set
  17. # end of Ethernet
When i send command: AT+CIPETHMAC? i receive ERROR msg. Other commands: AT, AT+DRVPWMINIT etc works.
Please, tell me what i shoud change in sdkonfig file.
esp_eth.7z
(147.85 KiB) Downloaded 213 times
ESP_Sun
Re: ESP-AT LAN8710A Error
Postby ESP_Sun » Mon Sep 19, 2022 10:05 am
ESP32 AT supports to four Ethernet PHY: LAN8720, IP101, DP83848 and RTL8201.
You can first test according to the IDF demo to see if PHY LAN8710 is supported. If it works, you can test AT again.
IDF ethernet dome: https://github.com/espressif/esp-idf/tr ... s/ethernet
ESP_ondrej
Postby ESP_ondrej » Tue Sep 20, 2022 8:32 am
I would start with confirming that Ethernet works on your board. I would try to flash it with \ethernet\basic example and try to ping it. I briefly checked your schematics and the pull-ups on RXD0/1 look suspicious to me. Does this comes from some reference design?
Users browsing this forum: No registered users and 27 guests
