I have an ESP32-LyraT v4.3 dev board and I've attached an ESP-PROG to it for JTAG debugging on VSCode using ESP-IDF extension (v1.5.0) and installed ESP-ADF. I have enabled the JTAG on the LyraT board via the dip switches (1-2 off, 3-7 on, 8 n/a). I am currently trying to set up the debugger and using the pipeline_a2dp_sink_and_hfp example. When I start the debug session in VSCode, I get the following error:
Error: FreeRTOS maximum used priority is unreasonably big, not proceeding: 240
Log is shown below:
I have not modified any code nor build scripts. Can someone give me an idea of what could be causing this?
Thanks.
ESP32-LyraT v4.3 and ESP-PROG - can't start debug session in VSCode
Re: ESP32-LyraT v4.3 and ESP-PROG - can't start debug session in VSCode
The JTAG debugging issues I was having when using VSCode, ESP-IDF Extension, and ESP-PROG *may* have been caused by the ESP-OpenOCD v0.11.0-esp32-20220411. When I replaced it with ESP-OpenOCD v0.11.0-esp32-20220706, I was able to flash via JTAG and Start/Stop debug session without seeing any errors.
Users browsing this forum: No registered users and 122 guests
