Issues with JTAG Debugging Tool Chain
mingesp256
Postby mingesp256 » Thu Jul 28, 2022 8:14 pm
Hi all, I'm having issues getting debugging over JTAG using esp prog board to work using VS Code, GBD and OpenOCD.
I have followed all the steps from the Espressif docs and tried this tutorial https://www.youtube.com/watch?v=uq93H7T7cOQ
I am getting the following error when I try to run the debugger
gbd error.PNG (6.89 KiB) Viewed 1314 times
I am able to run openOCD with the command line and have been able to connect to the esp prog board successfully however I am unable to get the entire tool chain working in VS Code. So my guess is that there is something wrong with OpenOCD or GBD, not the esp prog hardware.
Any suggestions or potential fixes would be greatly appreciated.
Here are the launch.json and tasks.json files that I am trying to run in VS Code
Tasks.json
    "version": "2.0.0",
    "tasks": [
            "label": "preRun",
            "type": "shell",
            "windows":{
                "command": [
                    "C:/Espressif/tools/openocd-esp32/v0.11.0-esp32-20211220/openocd-esp32/bin/openocd.exe -f C:/Espressif/tools/openocd-esp32/v0.11.0-esp32-20211220/openocd-esp32/share/openocd/scripts/board/esp32s2-kaluga-1.cfg"
Launch.json
    "version": "0.2.0",
    "configurations": [
            "name" : "ESP32 OpenOCD",
            "type" : "cppdbg",
            "request": "launch",
            "cwd": "${workspaceFolder}/build",
            "program": "${workspaceFolder}/build/debugtest.elf",
            "miDebuggerPath": "C:\\Espressif\\tools\\xtensa-esp32s2-elf\\esp-2021r2-patch2-8.4.0\\xtensa-esp32s2-elf\\bin\\xtensa-esp32s2-elf-gdb.exe",
            "setupCommands": [
                {"text": "target remote 127.0.0.1:3333"},
                {"text": "set remote hardware-watchpoint-limit 2"},
                {"text": "monitor reset halt"},
                {"text": "flushregs"}
ESP_bignacio
Re: Issues with JTAG Debugging Tool Chain
Postby ESP_bignacio » Thu Aug 04, 2022 11:14 am
Could you change the cwd in launch.json to "cwd": "${workspaceFolder}" Also what is the output of the openOCD task ?
You could also try our Visual Studio Code extension for ESP-IDF
Users browsing this forum: No registered users and 71 guests
