I compile and download this gatt_server_service_table example I check form my mobile with BLE Tester
I can see all the services and characteristics:
Service 000000ff-000-1000-8000-008059b34fb
And the following characteristics:
0000FF001-000-1000-8000-008059b34fb
0000FF003-000-1000-8000-008059b34fb
0000FF004-000-1000-8000-008059b34fb
0000FF005-000-1000-8000-008059b34fb
Now I need two change the service UUID I found a solution on internet and I change the table in this way
//I create a New service UUID
static uint8_t CustomService_uuid[16] = {0x36, 0xa2, 0x14, 0xe0, 0x0f, 0x68, 0x11, 0xeb, 0xad, 0xc1, 0x02, 0x42, 0xac, 0x12, 0x00, x02,};// (020012ac-4202-c1ad-eb11-680fe014a236)
than
I change this
[IDX_SVC] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ,
sizeof(uint16_t), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
with
sizeof(uint16_t), sizeof(CustomService_uuid), (uint8_t *)&CustomService_uuid}},
I change also the device Name to be sure.
I download and run the program the name is changed but I see always the same service and characteristics.
So I try do modified all the characteristics
static const uint16_t GATTS_CHAR_UUID_TEST_A = 0xFF11;//0xFF01;
static const uint16_t GATTS_CHAR_UUID_TEST_B = 0xFF12;//0xFF02;
static const uint16_t GATTS_CHAR_UUID_TEST_C = 0xFF13;//0xFF03;
static const uint16_t GATTS_CHAR_UUID_TEST_D = 0xFF14;//0xFF04;
I rebuild and download but nothing changed. From BLE Tester I see always the old value.
Is like I cannot overwrite the configuration table.
Thanks for any help
RogerJF
gatt_server_service_table cannot change Service And charatteristics
Re: gatt_server_service_table cannot change Service And charatteristics
Could you paste the whole code here, it will be much helpRogerJF wrote: ↑Mon Jul 25, 2022 10:20 amI compile and download this gatt_server_service_table example I check form my mobile with BLE Tester
than
I change this
with
Thanks for any help
RogerJF
Ankit Bansal
* This demo showcases creating a GATT database using a predefined attribute table.
* It acts as a GATT server and can send adv data, be connected by client.
* Run the gatt_client demo, the client demo will automatically connect to the gatt_server_service_table demo.
* Client demo will enable GATT server's notify after connection. The two devices will then exchange
* data.
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gatts_api.h"
#include "esp_bt_main.h"
#include "gatts_table_creat_demo.h"
#include "esp_gatt_common_api.h"
#define GATTS_TABLE_TAG "GATTS_TABLE_SRV"
#define PROFILE_NUM 1
#define PROFILE_APP_IDX 0
#define ESP_APP_ID 0x55
#define SAMPLE_DEVICE_NAME "X007_AB12C7" //"X007_AB12C4"
#define SVC_INST_ID 0
/* The max length of characteristic value. When the GATT client performs a write or prepare write operation,
* the data length must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
#define GATTS_DEMO_CHAR_VAL_LEN_MAX 500
#define PREPARE_BUF_MAX_SIZE 1024
#define CHAR_DECLARATION_SIZE (sizeof(uint8_t))
#define ADV_CONFIG_FLAG (1 << 0)
#define SCAN_RSP_CONFIG_FLAG (1 << 1)
static uint8_t adv_config_done = 0;
uint16_t gatt_db_handle_table[HRS_IDX_NB];
typedef struct {
uint8_t *prepare_buf;
int prepare_len;
} prepare_type_env_t;
static prepare_type_env_t prepare_write_env;
//#define CONFIG_SET_RAW_ADV_DATA
#ifdef CONFIG_SET_RAW_ADV_DATA
static uint8_t raw_adv_data[] = {
/* flags */
0x02, 0x01, 0x06,
/* tx power*/
0x02, 0x0a, 0xeb,
/* service uuid */
0x03, 0x03, 0xFF, 0x00,
/* device name */
0x0f, 0x09, 'E', 'S', 'P', '_', 'G', 'A', 'T', 'T', 'S', '_', 'D','E', 'M', 'O'
static uint8_t raw_scan_rsp_data[] = {
/* flags */
0x02, 0x01, 0x06,
/* tx power */
0x02, 0x0a, 0xeb,
/* service uuid */
0x03, 0x03, 0xFF,0x00
#else
static uint8_t service_uuid[16] = {
/* LSB <--------------------------------------------------------------------------------> MSB */
//first uuid, 16bit, [12],[13] is the value
//0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00,
0x36, 0xa2, 0x14, 0xe0, 0x0f, 0x68, 0x11, 0xeb, 0xad, 0xc1, 0x02, 0x42, 0xac, 0x12, 0x00, 0x02,
#define TEST_MANUFACTURER_DATA_LEN 17
static uint8_t test_manufacturer[TEST_MANUFACTURER_DATA_LEN] = {0x30, 0x31, 0x32, 0x33 , 0x33, 0x33, 0x33};
/* The length of adv data must be less than 31 bytes */
static esp_ble_adv_data_t adv_data = {
.set_scan_rsp = false,
.include_name = true,
.include_txpower = true,
.min_interval = 0x0006, //slave connection min interval, Time = min_interval * 1.25 msec
.max_interval = 0x0010, //slave connection max interval, Time = max_interval * 1.25 msec
.appearance = 0x00,
.manufacturer_len = 0, //TEST_MANUFACTURER_DATA_LEN,
.p_manufacturer_data = NULL, //test_manufacturer,
.service_data_len = 0,
.p_service_data = NULL,
.service_uuid_len = sizeof(service_uuid),
.p_service_uuid = service_uuid,
.flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT),
// scan response data
static esp_ble_adv_data_t scan_rsp_data = {
.set_scan_rsp = true,
.appearance = 0x00,
//.manufacturer_len = 0,TEST_MANUFACTURER_DATA_LEN,
.p_manufacturer_data = NULL, //&test_manufacturer[0],
//.p_manufacturer_data = &test_manufacturer[0],
#endif /* CONFIG_SET_RAW_ADV_DATA */
static esp_ble_adv_params_t adv_params = {
.adv_int_min = 0x20,
.adv_int_max = 0x40,
.adv_type = ADV_TYPE_IND,
.own_addr_type = BLE_ADDR_TYPE_PUBLIC,
.channel_map = ADV_CHNL_ALL,
.adv_filter_policy = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
struct gatts_profile_inst {
esp_gatts_cb_t gatts_cb;
uint16_t gatts_if;
uint16_t app_id;
uint16_t conn_id;
uint16_t service_handle;
esp_gatt_srvc_id_t service_id;
uint16_t char_handle;
esp_bt_uuid_t char_uuid;
esp_gatt_perm_t perm;
esp_gatt_char_prop_t property;
uint16_t descr_handle;
esp_bt_uuid_t descr_uuid;
static void gatts_profile_event_handler(esp_gatts_cb_event_t event,
esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param);
/* One gatt-based profile one app_id and one gatts_if, this array will store the gatts_if returned by ESP_GATTS_REG_EVT */
static struct gatts_profile_inst heart_rate_profile_tab[PROFILE_NUM] = {
[PROFILE_APP_IDX] = {
.gatts_cb = gatts_profile_event_handler,
.gatts_if = ESP_GATT_IF_NONE, /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
#pragma GCC diagnostic ignored "-Wunused-const-variable"
/* Service */
//static const uint16_t GATTS_SERVICE_UUID_TEST = 0x00FF;
static const uint16_t primary_service_uuid = ESP_GATT_UUID_PRI_SERVICE;
static const uint16_t character_declaration_uuid = ESP_GATT_UUID_CHAR_DECLARE;
static const uint16_t character_client_config_uuid = ESP_GATT_UUID_CHAR_CLIENT_CONFIG;
static const uint8_t char_prop_read = ESP_GATT_CHAR_PROP_BIT_READ;
static const uint8_t char_prop_write = ESP_GATT_CHAR_PROP_BIT_WRITE;
static const uint8_t char_prop_read_write_notify = ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_NOTIFY;
static const uint8_t heart_measurement_ccc[2] = {0x00, 0x00};
static const uint8_t char_value[4] = {0x11, 0x22, 0x33, 0x44};
static const uint8_t char_valueD[4] = {0x1, 0x2, 0x3, 0x4};
};// (020012ac-4202-c1ad-eb11-680fe014a236)?
//(uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ, sizeof(uint16_t), sizeof(service_uuid), (uint8_t *)&service_uuid}},
/* Full Database Description - Used to add attributes into the database */
static const esp_gatts_attr_db_t gatt_db[HRS_IDX_NB] =
// Service Declaration
[IDX_SVC] =
500, sizeof(CustomService_uuid), (uint8_t *)&CustomService_uuid}},
// sizeof(uint16_t), sizeof(CustomService_uuid), (uint8_t *)&CustomService_uuid}},
// sizeof(uint16_t), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
/* Characteristic Declaration */
[IDX_CHAR_A] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ,
CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_write_notify}},
/* Characteristic Value */
[IDX_CHAR_VAL_A] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_A, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
/* Client Characteristic Configuration Descriptor */
[IDX_CHAR_CFG_A] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
sizeof(uint16_t), sizeof(heart_measurement_ccc), (uint8_t *)heart_measurement_ccc}},
[IDX_CHAR_D] =
CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_write}},
[IDX_CHAR_VAL_D] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_D, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_valueD), (uint8_t *)char_valueD}},
[IDX_CHAR_B] =
CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read}},
[IDX_CHAR_VAL_B] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_B, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
[IDX_CHAR_C] =
[IDX_CHAR_VAL_C] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_C, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
static void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param)
switch (event) {
case ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT:
adv_config_done &= (~ADV_CONFIG_FLAG);
if (adv_config_done == 0){
esp_ble_gap_start_advertising(&adv_params);
case ESP_GAP_BLE_SCAN_RSP_DATA_RAW_SET_COMPLETE_EVT:
adv_config_done &= (~SCAN_RSP_CONFIG_FLAG);
#else
case ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT:
case ESP_GAP_BLE_SCAN_RSP_DATA_SET_COMPLETE_EVT:
#endif
case ESP_GAP_BLE_ADV_START_COMPLETE_EVT:
/* advertising start complete event to indicate advertising start successfully or failed */
if (param->adv_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
ESP_LOGE(GATTS_TABLE_TAG, "advertising start failed");
}else{
ESP_LOGI(GATTS_TABLE_TAG, "advertising start successfully");
case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS) {
ESP_LOGE(GATTS_TABLE_TAG, "Advertising stop failed");
else {
ESP_LOGI(GATTS_TABLE_TAG, "Stop adv successfully\n");
case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
param->update_conn_params.status,
param->update_conn_params.min_int,
param->update_conn_params.max_int,
param->update_conn_params.conn_int,
param->update_conn_params.latency,
param->update_conn_params.timeout);
default:
void example_prepare_write_event_env(esp_gatt_if_t gatts_if, prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param)
ESP_LOGI(GATTS_TABLE_TAG, "prepare write, handle = %d, value len = %d", param->write.handle, param->write.len);
esp_gatt_status_t status = ESP_GATT_OK;
if (prepare_write_env->prepare_buf == NULL) {
prepare_write_env->prepare_buf = (uint8_t *)malloc(PREPARE_BUF_MAX_SIZE * sizeof(uint8_t));
prepare_write_env->prepare_len = 0;
ESP_LOGE(GATTS_TABLE_TAG, "%s, Gatt_server prep no mem", __func__);
status = ESP_GATT_NO_RESOURCES;
if(param->write.offset > PREPARE_BUF_MAX_SIZE) {
status = ESP_GATT_INVALID_OFFSET;
} else if ((param->write.offset + param->write.len) > PREPARE_BUF_MAX_SIZE) {
status = ESP_GATT_INVALID_ATTR_LEN;
/*send response when param->write.need_rsp is true */
if (param->write.need_rsp){
esp_gatt_rsp_t *gatt_rsp = (esp_gatt_rsp_t *)malloc(sizeof(esp_gatt_rsp_t));
if (gatt_rsp != NULL){
gatt_rsp->attr_value.len = param->write.len;
gatt_rsp->attr_value.handle = param->write.handle;
gatt_rsp->attr_value.offset = param->write.offset;
gatt_rsp->attr_value.auth_req = ESP_GATT_AUTH_REQ_NONE;
memcpy(gatt_rsp->attr_value.value, param->write.value, param->write.len);
esp_err_t response_err = esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, status, gatt_rsp);
if (response_err != ESP_OK){
ESP_LOGE(GATTS_TABLE_TAG, "Send response error");
free(gatt_rsp);
}else{
ESP_LOGE(GATTS_TABLE_TAG, "%s, malloc failed", __func__);
if (status != ESP_GATT_OK){
return;
memcpy(prepare_write_env->prepare_buf + param->write.offset,
param->write.value,
param->write.len);
prepare_write_env->prepare_len += param->write.len;
void example_exec_write_event_env(prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param){
if (param->exec_write.exec_write_flag == ESP_GATT_PREP_WRITE_EXEC && prepare_write_env->prepare_buf){
esp_log_buffer_hex(GATTS_TABLE_TAG, prepare_write_env->prepare_buf, prepare_write_env->prepare_len);
}else{
ESP_LOGI(GATTS_TABLE_TAG,"ESP_GATT_PREP_WRITE_CANCEL");
if (prepare_write_env->prepare_buf) {
free(prepare_write_env->prepare_buf);
prepare_write_env->prepare_buf = NULL;
static void gatts_profile_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
switch (event) {
case ESP_GATTS_REG_EVT:{
esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(SAMPLE_DEVICE_NAME);
if (set_dev_name_ret){
ESP_LOGE(GATTS_TABLE_TAG, "set device name failed, error code = %x", set_dev_name_ret);
esp_err_t raw_adv_ret = esp_ble_gap_config_adv_data_raw(raw_adv_data, sizeof(raw_adv_data));
if (raw_adv_ret){
ESP_LOGE(GATTS_TABLE_TAG, "config raw adv data failed, error code = %x ", raw_adv_ret);
adv_config_done |= ADV_CONFIG_FLAG;
esp_err_t raw_scan_ret = esp_ble_gap_config_scan_rsp_data_raw(raw_scan_rsp_data, sizeof(raw_scan_rsp_data));
if (raw_scan_ret){
ESP_LOGE(GATTS_TABLE_TAG, "config raw scan rsp data failed, error code = %x", raw_scan_ret);
adv_config_done |= SCAN_RSP_CONFIG_FLAG;
#else
//config adv data
esp_err_t ret = esp_ble_gap_config_adv_data(&adv_data);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "config adv data failed, error code = %x", ret);
//config scan response data
ret = esp_ble_gap_config_adv_data(&scan_rsp_data);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "config scan response data failed, error code = %x", ret);
#endif
ESP_LOGI(GATTS_TABLE_TAG,"esp_ble_gatts_create_attr_tab");
esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(gatt_db, gatts_if, HRS_IDX_NB, SVC_INST_ID);
if (create_attr_ret){
ESP_LOGE(GATTS_TABLE_TAG, "create attr table failed, error code = %x", create_attr_ret);
case ESP_GATTS_READ_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_READ_EVT");
case ESP_GATTS_WRITE_EVT:
if (!param->write.is_prep){
// the data length of gattc write must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
ESP_LOGI(GATTS_TABLE_TAG, "GATT_WRITE_EVT, handle = %d, value len = %d, value :", param->write.handle, param->write.len);
esp_log_buffer_hex(GATTS_TABLE_TAG, param->write.value, param->write.len);
#ifdef TOLTO
if (heart_rate_handle_table[IDX_CHAR_CFG_A] == param->write.handle && param->write.len == 2){
uint16_t descr_value = param->write.value[1]<<8 | param->write.value[0];
if (descr_value == 0x0001){
ESP_LOGI(GATTS_TABLE_TAG, "notify enable");
uint8_t notify_data[15];
for (int i = 0; i < sizeof(notify_data); ++i)
notify_data = i % 0xff;
//the size of notify_data[] need less than MTU size
esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id, heart_rate_handle_table[IDX_CHAR_VAL_A],
sizeof(notify_data), notify_data, false);
}else if (descr_value == 0x0002){
ESP_LOGI(GATTS_TABLE_TAG, "indicate enable");
uint8_t indicate_data[15];
for (int i = 0; i < sizeof(indicate_data); ++i)
indicate_data = i % 0xff;
//the size of indicate_data[] need less than MTU size
sizeof(indicate_data), indicate_data, true);
else if (descr_value == 0x0000){
ESP_LOGI(GATTS_TABLE_TAG, "notify/indicate disable ");
}else{
ESP_LOGE(GATTS_TABLE_TAG, "unknown descr value");
/* send response when param->write.need_rsp is true*/
esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, ESP_GATT_OK, NULL);
#endif
}else{
/* handle prepare write */
example_prepare_write_event_env(gatts_if, &prepare_write_env, param);
case ESP_GATTS_EXEC_WRITE_EVT:
// the length of gattc prepare write data must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_EXEC_WRITE_EVT");
example_exec_write_event_env(&prepare_write_env, param);
case ESP_GATTS_MTU_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_MTU_EVT, MTU %d", param->mtu.mtu);
case ESP_GATTS_CONF_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_CONF_EVT, status = %d, attr_handle %d", param->conf.status, param->conf.handle);
case ESP_GATTS_START_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "SERVICE_START_EVT, status %d, service_handle %d", param->start.status, param->start.service_handle);
case ESP_GATTS_CONNECT_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_CONNECT_EVT, conn_id = %d", param->connect.conn_id);
esp_log_buffer_hex(GATTS_TABLE_TAG, param->connect.remote_bda, 6);
esp_ble_conn_update_params_t conn_params = {0};
memcpy(conn_params.bda, param->connect.remote_bda, sizeof(esp_bd_addr_t));
/* For the iOS system, please refer to Apple official documents about the BLE connection parameters restrictions. */
conn_params.latency = 0;
conn_params.max_int = 0x20; // max_int = 0x20*1.25ms = 40ms
conn_params.min_int = 0x10; // min_int = 0x10*1.25ms = 20ms
conn_params.timeout = 400; // timeout = 400*10ms = 4000ms
//start sent the update connection parameters to the peer device.
esp_ble_gap_update_conn_params(&conn_params);
case ESP_GATTS_DISCONNECT_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_DISCONNECT_EVT, reason = 0x%x", param->disconnect.reason);
case ESP_GATTS_CREAT_ATTR_TAB_EVT:{
if (param->add_attr_tab.status != ESP_GATT_OK){
ESP_LOGE(GATTS_TABLE_TAG, "create attribute table failed, error code=0x%x", param->add_attr_tab.status);
else if (param->add_attr_tab.num_handle != HRS_IDX_NB){
ESP_LOGE(GATTS_TABLE_TAG, "create attribute table abnormally, num_handle (%d) \
doesn't equal to HRS_IDX_NB(%d)", param->add_attr_tab.num_handle, HRS_IDX_NB);
else {
ESP_LOGI(GATTS_TABLE_TAG, "TOLTO create attribute table successfully, the number handle = %d\n",param->add_attr_tab.num_handle);
//memcpy(heart_rate_handle_table, param->add_attr_tab.handles, sizeof(heart_rate_handle_table));
//esp_ble_gatts_start_service(heart_rate_handle_table[IDX_SVC]);
memcpy(gatt_db_handle_table, param->add_attr_tab.handles, sizeof(gatt_db_handle_table));
esp_ble_gatts_start_service(gatt_db_handle_table[IDX_SVC]);
case ESP_GATTS_STOP_EVT:
case ESP_GATTS_OPEN_EVT:
case ESP_GATTS_CANCEL_OPEN_EVT:
case ESP_GATTS_CLOSE_EVT:
case ESP_GATTS_LISTEN_EVT:
case ESP_GATTS_CONGEST_EVT:
case ESP_GATTS_UNREG_EVT:
case ESP_GATTS_DELETE_EVT:
default:
static void gatts_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
/* If event is register event, store the gatts_if for each profile */
if (event == ESP_GATTS_REG_EVT) {
if (param->reg.status == ESP_GATT_OK) {
heart_rate_profile_tab[PROFILE_APP_IDX].gatts_if = gatts_if;
ESP_LOGE(GATTS_TABLE_TAG, "reg app failed, app_id %04x, status %d",
param->reg.app_id,
param->reg.status);
return;
do {
int idx;
for (idx = 0; idx < PROFILE_NUM; idx++) {
/* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
if (gatts_if == ESP_GATT_IF_NONE || gatts_if == heart_rate_profile_tab[idx].gatts_if) {
if (heart_rate_profile_tab[idx].gatts_cb) {
heart_rate_profile_tab[idx].gatts_cb(event, gatts_if, param);
} while (0);
void app_main(void)
esp_err_t ret;
/* Initialize NVS. */
ret = nvs_flash_init();
ESP_ERROR_CHECK( ret );
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
ret = esp_bt_controller_init(&bt_cfg);
if (ret) {
ESP_LOGE(GATTS_TABLE_TAG, "%s enable controller failed: %s", __func__, esp_err_to_name(ret));
return;
ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
if (ret) {
return;
ret = esp_bluedroid_init();
if (ret) {
ESP_LOGE(GATTS_TABLE_TAG, "%s init bluetooth failed: %s", __func__, esp_err_to_name(ret));
return;
ret = esp_bluedroid_enable();
if (ret) {
ESP_LOGE(GATTS_TABLE_TAG, "%s enable bluetooth failed: %s", __func__, esp_err_to_name(ret));
return;
ret = esp_ble_gatts_register_callback(gatts_event_handler);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "gatts register error, error code = %x", ret);
return;
ret = esp_ble_gap_register_callback(gap_event_handler);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "gap register error, error code = %x", ret);
return;
ret = esp_ble_gatts_app_register(ESP_APP_ID);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "gatts app register error, error code = %x", ret);
return;
esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
if (local_mtu_ret){
ESP_LOGE(GATTS_TABLE_TAG, "set local MTU failed, error code = %x", local_mtu_ret);
//console output
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376657
0x40376657: _xt_user_exc at C:/Espressif/frameworks/esp-idf-v4.4/components/freertos/port/xtensa/xtensa_vectors.S:624
pro cpu reset by JTAG
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x1650
load:0x403b6000,len:0xb7c
load:0x403ba000,len:0x2f58
entry 0x403b6248
I (31) boot: ESP-IDF v4.4-dirty 2nd stage bootloader
I (31) boot: compile time 12:27:48
I (31) boot: chip revision: 0
I (33) boot.esp32s3: Boot SPI Speed : 80MHz
I (38) boot.esp32s3: SPI Mode : DIO
I (43) boot.esp32s3: SPI Flash Size : 2MB
I (47) boot: Enabling RNG early entropy source...
I (53) boot: Partition Table:
I (56) boot: ## Label Usage Type ST Offset Length
I (64) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (71) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (79) boot: 2 factory factory app 00 00 00010000 00100000
I (86) boot: End of partition table
I (90) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=1cda4h (118180) map
I (120) esp_image: segment 1: paddr=0002cdcc vaddr=3fc93e00 size=0324ch ( 12876) load
I (123) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=713b8h (463800) map
I (209) esp_image: segment 3: paddr=000a13e0 vaddr=3fc9704c size=00618h ( 1560) load
I (210) esp_image: segment 4: paddr=000a1a00 vaddr=40374000 size=0fdf4h ( 65012) load
I (229) esp_image: segment 5: paddr=000b17fc vaddr=50000000 size=00010h ( 16) load
I (236) boot: Loaded app from partition at offset 0x10000
I (236) boot: Disabling RNG early entropy source...
I (249) cpu_start: Pro cpu up.
I (249) cpu_start: Starting app cpu, entry point is 0x40375164
0x40375164: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156
I (0) cpu_start: App cpu up.
I (263) cpu_start: Pro cpu start user code
I (263) cpu_start: cpu freq: 160000000
I (264) cpu_start: Application information:
I (266) cpu_start: Project name: gatt_server_service_table
I (273) cpu_start: App version: 1
I (277) cpu_start: Compile time: Jul 25 2022 12:26:51
I (283) cpu_start: ELF file SHA256: e688351dc1093ee6...
I (289) cpu_start: ESP-IDF: v4.4-dirty
I (295) heap_init: Initializing. RAM available for dynamic allocation:
I (302) heap_init: At 3FC9B4D0 len 00044B30 (274 KiB): D/IRAM
I (308) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM
I (315) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (322) spi_flash: detected chip: generic
I (326) spi_flash: flash io: dio
W (330) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (343) sleep: Configure to isolate all GPIO pins in sleep state
I (350) sleep: Enable automatic switching of GPIO sleep configuration
I (357) coexist: coexist rom version e7ae62f
I (362) cpu_start: Starting scheduler on PRO CPU.
W (406) BT_INIT: esp_bt_controller_mem_release not implemented, return OK
I (406) BT_INIT: BT controller compile version [6881869]
I (406) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12
I (466) system_api: Base MAC address is not set
I (466) system_api: read default base MAC address from EFUSE
I (466) BT_INIT: Bluetooth MAC: 7c:df:a1:e2:85:d6
I (496) GATTS_TABLE_SRV: esp_ble_gatts_create_attr_tab
W (496) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADV
W (496) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
I (506) GATTS_TABLE_SRV: TOLTO create attribute table successfully, the number handle = 10
I (516) GATTS_TABLE_SRV: SERVICE_START_EVT, status 0, service_handle 40
I (516) GATTS_TABLE_SRV: advertising start successfully
Build:Mar 27 2021
Saved PC:0x40376657
SPIWP:0xee
entry 0x403b6248
W (8308) BT_INIT: esp_bt_controller_mem_release not implemented, return OK
I (8308) BT_INIT: BT controller compile version [6881869]
I (8308) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12
I (8368) system_api: Base MAC address is not set
I (8368) system_api: read default base MAC address from EFUSE
I (8368) BT_INIT: Bluetooth MAC: 7c:df:a1:e2:85:d6
I (8398) GATTS_TABLE_SRV: esp_ble_gatts_create_attr_tab
W (8398) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADV
W (8398) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
I (13318) GATTS_TABLE_SRV: TOLTO create attribute table successfully, the number handle = 10
I (13318) GATTS_TABLE_SRV: SERVICE_START_EVT, status 0, service_handle 40
I (13318) GATTS_TABLE_SRV: advertising start successfully
I (24548) GATTS_TABLE_SRV: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (24558) GATTS_TABLE_SRV: 71 bf 5a 08 e9 47
I (25368) GATTS_TABLE_SRV: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
//Attached the screen shot of my BLE TEster App
* data.
#include "esp_bt.h"
typedef struct {
int prepare_len;
/* flags */
0x02, 0x01, 0x06,
/* tx power*/
0x02, 0x0a, 0xeb,
/* service uuid */
/* device name */
/* flags */
0x02, 0x01, 0x06,
/* tx power */
0x02, 0x0a, 0xeb,
/* service uuid */
#else
.appearance = 0x00,
.appearance = 0x00,
uint16_t gatts_if;
uint16_t app_id;
uint16_t conn_id;
/* Service */
[IDX_SVC] =
[IDX_CHAR_A] =
[IDX_CHAR_VAL_A] =
[IDX_CHAR_CFG_A] =
[IDX_CHAR_D] =
[IDX_CHAR_VAL_D] =
[IDX_CHAR_B] =
[IDX_CHAR_VAL_B] =
[IDX_CHAR_C] =
[IDX_CHAR_VAL_C] =
switch (event) {
#else
#endif
}else{
else {
default:
free(gatt_rsp);
}else{
return;
param->write.value,
param->write.len);
}else{
switch (event) {
if (raw_adv_ret){
if (raw_scan_ret){
#else
//config adv data
if (ret){
if (ret){
#endif
#ifdef TOLTO
}else{
#endif
}else{
else {
default:
param->reg.app_id,
param->reg.status);
return;
do {
int idx;
} while (0);
void app_main(void)
esp_err_t ret;
if (ret) {
return;
if (ret) {
return;
if (ret) {
return;
if (ret) {
return;
if (ret){
return;
if (ret){
return;
if (ret){
return;
if (local_mtu_ret){
//console output
Build:Mar 27 2021
Saved PC:0x40376657
SPIWP:0xee
entry 0x403b6248
Build:Mar 27 2021
Saved PC:0x40376657
SPIWP:0xee
entry 0x403b6248
- Screenshot_2022-07-25-15-38-23-200_com.zhctwh.ble_tester.jpg (387.09 KiB) Viewed 1952 times
Users browsing this forum: No registered users and 90 guests
