Repeated USB MSC operation
maldus
Postby maldus » Thu Jul 21, 2022 7:27 am
Hello everyone,
I'm successfully using an ESP32S2 module to read and write files from a FAT32 formatted USB drive. The mechanism works but only the first time (i.e. once I disconnect the drive there seems to be no way to detect it again before a reset).
As the API is in it's infancy there isn't much documentation about it and I've tried manipulating the available example with no results.
For reference, once I'm done I simply try to uninstall all software components and reinstall them, but I receive no new events. The code is very simple:
 * SPDX-FileCopyrightText: 2015-2022 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "freertos/semphr.h"
#include "esp_err.h"
#include "esp_log.h"
#include "usb/usb_host.h"
#include "msc_host.h"
#include "msc_host_vfs.h"
#include "ffconf.h"
#include "ff.h"
#include "esp_vfs.h"
#include "errno.h"
#include "hal/usb_hal.h"
static const char *TAG = "example";
static QueueHandle_t     app_queue;
static SemaphoreHandle_t ready_to_uninstall_usb;
static SemaphoreHandle_t usb_host_installed;
static void msc_event_cb(const msc_host_event_t *event, void *arg) {
    if (event->event == MSC_DEVICE_CONNECTED) {
        ESP_LOGI(TAG, "MSC device connected");
    } else if (event->event == MSC_DEVICE_DISCONNECTED) {
        ESP_LOGI(TAG, "MSC device disconnected");
        ESP_LOGI(TAG, "MSC event: %i", event->event);
    xQueueSend(app_queue, event, 10);
static void print_device_info(msc_host_device_info_t *info) {
    const size_t megabyte = 1024 * 1024;
    uint64_t     capacity = ((uint64_t)info->sector_size * info->sector_count) / megabyte;
    printf("Device info:\n");
    printf("\t Capacity: %llu MB\n", capacity);
    printf("\t Sector size: %u\n", info->sector_size);
    printf("\t Sector count: %u\n", info->sector_count);
    printf("\t PID: 0x%4X \n", info->idProduct);
    printf("\t VID: 0x%4X \n", info->idVendor);
    wprintf(L"\t iProduct: %S \n", info->iProduct);
    wprintf(L"\t iManufacturer: %S \n", info->iManufacturer);
    wprintf(L"\t iSerialNumber: %S \n", info->iSerialNumber);
static void file_operations(void) {
    const char *directory = "/usb/esp";
    const char *file_path = "/usb/esp/test.txt";
    struct stat s                = {0};
    bool        directory_exists = stat(directory, &s) == 0;
    if (!directory_exists) {
        if (mkdir(directory, 0775) != 0) {
            ESP_LOGE(TAG, "mkdir failed with errno: %s\n", strerror(errno));
    ESP_LOGI(TAG, "Writing file");
    FILE *f = fopen(file_path, "w");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for writing");
        return;
    fprintf(f, "Hello World!\n");
    fclose(f);
    ESP_LOGI(TAG, "Reading file");
    f = fopen(file_path, "r");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for reading");
        return;
    char line[64];
    fgets(line, sizeof(line), f);
    fclose(f);
    // strip newline
    char *pos = strchr(line, '\n');
    if (pos) {
        *pos = '\0';
    ESP_LOGI(TAG, "Read from file: '%s'", line);
// Handles common USB host library events
static void handle_usb_events(void *args) {
    while (1) {
        xSemaphoreTake(usb_host_installed, portMAX_DELAY);
        uint32_t event_flags;
        usb_host_lib_handle_events(portMAX_DELAY, &event_flags);
        // Release devices once all clients has deregistered
        if (event_flags & USB_HOST_LIB_EVENT_FLAGS_NO_CLIENTS) {
            usb_host_device_free_all();
        // Give ready_to_uninstall_usb semaphore to indicate that USB Host library
        // can be deinitialized, and terminate this task.
        if (event_flags & USB_HOST_LIB_EVENT_FLAGS_ALL_FREE) {
            xSemaphoreGive(ready_to_uninstall_usb);
        xSemaphoreGive(usb_host_installed);
    vTaskDelete(NULL);
static uint8_t wait_for_msc_device(void) {
    msc_host_event_t app_event;
    ESP_LOGI(TAG, "Waiting for USB stick to be connected");
    xQueueReceive(app_queue, &app_event, portMAX_DELAY);
    assert(app_event.event == MSC_DEVICE_CONNECTED);
    return app_event.device.address;
void app_main(void) {
    msc_host_device_handle_t msc_device;
    BaseType_t               task_created;
    ready_to_uninstall_usb = xSemaphoreCreateBinary();
    usb_host_installed     = xSemaphoreCreateBinary();
    app_queue = xQueueCreate(3, sizeof(msc_host_event_t));
    assert(app_queue);
    const usb_host_config_t host_config = {
        .skip_phy_setup = false,
        .intr_flags     = ESP_INTR_FLAG_LEVEL1,
    task_created = xTaskCreate(handle_usb_events, "usb_events", 2048, NULL, 2, NULL);
    assert(task_created);
    const msc_host_driver_config_t msc_config = {
        .create_backround_task = true,
        .task_priority         = 5,
        .stack_size            = 2048,
        .callback              = msc_event_cb,
    for (;;) {
        ESP_ERROR_CHECK(usb_host_install(&host_config));
        ESP_ERROR_CHECK(msc_host_install(&msc_config));
        uint8_t device_address = wait_for_msc_device();
        ESP_ERROR_CHECK(msc_host_install_device(device_address, &msc_device));
        msc_host_print_descriptors(msc_device);
        msc_host_device_info_t info;
        ESP_ERROR_CHECK(msc_host_get_device_info(msc_device, &info));
        print_device_info(&info);
        msc_host_vfs_handle_t            vfs_handle;
        const esp_vfs_fat_mount_config_t mount_config = {
            .format_if_mount_failed = false,
            .max_files              = 3,
            .allocation_unit_size   = 1024,
        ESP_ERROR_CHECK(msc_host_vfs_register(msc_device, "/usb", &mount_config, &vfs_handle));
        file_operations();
        ESP_ERROR_CHECK(msc_host_vfs_unregister(vfs_handle));
        ESP_ERROR_CHECK(msc_host_uninstall_device(msc_device));
        ESP_ERROR_CHECK(msc_host_uninstall());
        xSemaphoreTake(ready_to_uninstall_usb, portMAX_DELAY);
        ESP_ERROR_CHECK(usb_host_uninstall());
        ESP_LOGI(TAG, "Done");
Resetting the device once the drive has been disconnected is a decent workaround, but I'd like to know if I'm missing something. Can anyone help me?
Jamawa
Re: Repeated USB MSC operation
Postby Jamawa » Fri Jul 22, 2022 7:30 pm
I toyed with the MSD implementation a while ago and also had that experience.
Do you get the expected uninstall messages when you unplug the device?
That was what wasn’t working in my case. Somewhere deepdown a task is still running, I think, where it should have ended and deleted itself when unplugging. I have not investigated it yet however so it might be something else. However, when I handle the tasks and calls similarly to the communications class driver (which works flawlessly), and then force all non-closing tasks to close, an inserted MSD is recognised again. It even works as long as the same disk is re-inserted. Any other disk resulted in a crash. As I did not really need MSD support I left it at that.
Anyway, you could have a look at the disconnecting events for a clue.
lmielick
Postby lmielick » Wed Oct 11, 2023 7:10 am
I have encountered the same issue and was able to resolve it.
Since device once enumerated will hold it's address one must keep the usb host lib installed at all times and also remove the call to usb_host_device_free_all from the usb lib task (handle_usb_events in this case). This is because after the client unregistered we still need to keep device context in the library so subsequent client can reach the device at it's already assigned address.
Otherwise device reset will be required.
Seems usb_host_device_free_all is meant there to handle the case of surprise device removal where the client unregisters on device gone even, but it will break communication with device until it's reset.
Note in the code sample you call msc_host_uninstall twice.
Users browsing this forum: Baldhead and 72 guests
