ESP32+SIM800C=cannot connect to internet
dmitrij999
Postby dmitrij999 » Wed Jul 20, 2022 5:50 pm
Hello everyone!
I'm using ESP32 board Lilygo T-Call with AXP192 PMIC and I'm trying to connect it to Internet using firmware based on ESP-IDF.
I can get information from the modem but I can't connect to the network.
I tried to change auth params, APN, username and password but no result. NETLIGHT doesn't blink frequently even.
Code to connect to Internet
//extern "C" {
#include <stdio.h>
#include "esp_log.h"
#include "driver/i2c.h"
#include "mqtt_client.h"
#include "esp_modem.h"
#include "esp_modem_netif.h"
//#include "esp_modem_config.h"
#include "sim800.h"
#include "sdkconfig.h"
#include "axp20x.h"
#include "esp_netif.h"
#include "esp_netif_ppp.h"
static const char *TAG = "AXP20x";
#define _I2C_NUMBER(num)            I2C_NUM_##num
#define I2C_NUMBER(num)             _I2C_NUMBER(num)
#define AXP_ISR_GPIO                (gpio_num_t)CONFIG_AXPxxx_INTERRUPT_PIN  /*!< axp power chip interrupt Pin*/
#define GPIO_INPUT_PIN_SEL          (1ULL<<AXP_ISR_GPIO)
#define I2C_MASTER_SCL_IO           CONFIG_I2C_MASTER_SCL                   /*!< gpio number for I2C master clock */
#define I2C_MASTER_SDA_IO           CONFIG_I2C_MASTER_SDA                   /*!< gpio number for I2C master data  */
#define I2C_MASTER_NUM              I2C_NUMBER(CONFIG_I2C_MASTER_PORT_NUM)  /*!< I2C port number for master dev */
#define I2C_MASTER_FREQ_HZ          CONFIG_I2C_MASTER_FREQUENCY             /*!< I2C master clock frequency */
#define I2C_MASTER_TX_BUF_DISABLE   0                                       /*!< I2C master doesn't need buffer */
#define I2C_MASTER_RX_BUF_DISABLE   0                                       /*!< I2C master doesn't need buffer */
#define WRITE_BIT                   I2C_MASTER_WRITE                        /*!< I2C master write */
#define READ_BIT                    I2C_MASTER_READ                         /*!< I2C master read */
#define ACK_CHECK_EN                0x1                                     /*!< I2C master will check ack from slave*/
#define ACK_CHECK_DIS               0x0                                     /*!< I2C master will not check ack from slave */
#define ACK_VAL                     (i2c_ack_type_t)0x0                     /*!< I2C ack value */
#define NACK_VAL                    (i2c_ack_type_t)0x1                     /*!< I2C nack value */
//#define MODEM_RST                   (gpio_num_t)5
#define MODEM_PWRKEY                (gpio_num_t)4
#define MODEM_POWER_ON              (gpio_num_t)25
#define MODEM_DTR                   (gpio_num_t)32
#define MODEM_RI                    (gpio_num_t)33
#define BROKER_URL "mqtt://mqtt.eclipseprojects.io"
//static const char *TAG = "pppos_example";
static EventGroupHandle_t event_group = NULL;
static const int CONNECT_BIT = BIT0;
static const int STOP_BIT = BIT1;
static const int GOT_DATA_BIT = BIT2;
AXP20X_Class axp;
static xQueueHandle gpio_evt_queue = NULL;
static void IRAM_ATTR axp_isr_handler(void *arg)
    uint32_t gpio_num = (uint32_t) arg;
    xQueueSendFromISR(gpio_evt_queue, &gpio_num, NULL);
static void axp_irq_init()
    gpio_config_t io_conf;
    //enable interrupt
    io_conf.intr_type = GPIO_INTR_NEGEDGE;
    //set as input mode
    io_conf.mode = GPIO_MODE_INPUT;
    //bit mask of the pins that you want to set
    io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
    //disable pull-down mode
    io_conf.pull_down_en = GPIO_PULLDOWN_DISABLE;
    //enable pull-up mode
    io_conf.pull_up_en = GPIO_PULLUP_ENABLE;
    //configure GPIO with the given settings
    gpio_config(&io_conf);
    //change gpio intrrupt type for one pin
    gpio_set_intr_type(AXP_ISR_GPIO, GPIO_INTR_NEGEDGE);
    //install gpio isr service
    gpio_install_isr_service(0);
    //hook isr handler for specific gpio pin
    gpio_isr_handler_add(AXP_ISR_GPIO, axp_isr_handler, (void *) AXP_ISR_GPIO);
    //create a queue to handle gpio event from isr
    gpio_evt_queue = xQueueCreate(10, sizeof(uint32_t));
 * @brief i2c master initialization
static esp_err_t i2c_master_init(void)
    int i2c_master_port = I2C_MASTER_NUM;
    i2c_config_t conf;
    conf.mode = I2C_MODE_MASTER;
    conf.sda_io_num = I2C_MASTER_SDA_IO;
    conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
    conf.scl_io_num = I2C_MASTER_SCL_IO;
    conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
    conf.master.clk_speed = I2C_MASTER_FREQ_HZ;
    i2c_param_config(i2c_master_port, &conf);
    return i2c_driver_install(i2c_master_port, conf.mode, I2C_MASTER_RX_BUF_DISABLE, I2C_MASTER_TX_BUF_DISABLE, 0);
 * @brief apx library i2c read callblack
uint8_t twi_read(uint8_t dev_addr, uint8_t reg_addr, uint8_t *data, uint8_t len)
    if (len == 0) {
        return ESP_OK;
    if (data == NULL) {
        return ESP_FAIL;
    i2c_cmd_handle_t cmd;
    cmd = i2c_cmd_link_create();
    i2c_master_start(cmd);
    i2c_master_write_byte(cmd, (dev_addr << 1) | WRITE_BIT, ACK_CHECK_EN);
    i2c_master_write_byte(cmd, reg_addr, ACK_CHECK_EN);
    i2c_master_stop(cmd);
    esp_err_t ret =  i2c_master_cmd_begin(I2C_MASTER_NUM, cmd, 1000 / portTICK_RATE_MS);
    i2c_cmd_link_delete(cmd);
    if (ret != ESP_OK) {
        return ESP_FAIL;
    i2c_master_write_byte(cmd, (dev_addr << 1) | READ_BIT, ACK_CHECK_EN);
    if (len > 1) {
        i2c_master_read(cmd, data, len - 1, ACK_VAL);
    i2c_master_read_byte(cmd, &data[len - 1], NACK_VAL);
    return ret;
 * @brief apx library i2c write callblack
uint8_t twi_write(uint8_t dev_addr, uint8_t reg_addr, uint8_t *data, uint8_t len)
    if (data == NULL) {
        return ESP_FAIL;
    i2c_cmd_handle_t cmd = i2c_cmd_link_create();
    i2c_master_write(cmd, data, len, ACK_CHECK_EN);
    return ret;
void setupModem()
    gpio_reset_pin(MODEM_PWRKEY);
    gpio_reset_pin(MODEM_POWER_ON);
#ifdef MODEM_RST
    // Keep reset high
    // pinMode(MODEM_RST, OUTPUT);
    // digitalWrite(MODEM_RST, HIGH);
    gpio_reset_pin(MODEM_RST);
    gpio_set_direction(MODEM_RST, GPIO_MODE_OUTPUT);
    gpio_set_level(MODEM_RST, 1);
#endif
    // pinMode(MODEM_PWRKEY, OUTPUT);
    // pinMode(MODEM_POWER_ON, OUTPUT);
    gpio_set_direction(MODEM_PWRKEY, GPIO_MODE_OUTPUT);
    gpio_set_direction(MODEM_POWER_ON, GPIO_MODE_OUTPUT);
    // Turn on the Modem power first
    // digitalWrite(MODEM_POWER_ON, HIGH);
    gpio_set_level(MODEM_POWER_ON, 1);
    // Pull down PWRKEY for more than 1 second according to manual requirements
    // digitalWrite(MODEM_PWRKEY, HIGH);
    // delay(100);
    // digitalWrite(MODEM_PWRKEY, LOW);
    // delay(1000);
    gpio_set_level(MODEM_PWRKEY, 1);
    vTaskDelay(100 / portTICK_PERIOD_MS);
    gpio_set_level(MODEM_PWRKEY, 0);
    // Initialize the indicator as an output
    // pinMode(LED_GPIO, OUTPUT);
    // digitalWrite(LED_GPIO, LED_OFF);
    ESP_LOGI(TAG, "Modem power has been setup");
static void modem_event_handler(void *event_handler_arg, esp_event_base_t event_base, int32_t event_id, void *event_data)
    switch (event_id) {
    case ESP_MODEM_EVENT_PPP_START:
        ESP_LOGI(TAG, "Modem PPP Started");
    case ESP_MODEM_EVENT_PPP_STOP:
        ESP_LOGI(TAG, "Modem PPP Stopped");
        xEventGroupSetBits(event_group, STOP_BIT);
    case ESP_MODEM_EVENT_UNKNOWN:
        ESP_LOGW(TAG, "Unknown line received: %s", (char *)event_data);
    default:
static esp_err_t mqtt_event_handler(esp_mqtt_event_handle_t event)
    esp_mqtt_client_handle_t client = event->client;
    int msg_id;
    switch (event->event_id) {
    case MQTT_EVENT_CONNECTED:
        ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
        msg_id = esp_mqtt_client_subscribe(client, "/topic/esp-pppos", 0);
        ESP_LOGI(TAG, "sent subscribe successful, msg_id=%d", msg_id);
    case MQTT_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
    case MQTT_EVENT_SUBSCRIBED:
        ESP_LOGI(TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
        msg_id = esp_mqtt_client_publish(client, "/topic/esp-pppos", "esp32-pppos", 0, 0, 0);
        ESP_LOGI(TAG, "sent publish successful, msg_id=%d", msg_id);
    case MQTT_EVENT_UNSUBSCRIBED:
        ESP_LOGI(TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
    case MQTT_EVENT_PUBLISHED:
        ESP_LOGI(TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
    case MQTT_EVENT_DATA:
        ESP_LOGI(TAG, "MQTT_EVENT_DATA");
        printf("TOPIC=%.*s\r\n", event->topic_len, event->topic);
        printf("DATA=%.*s\r\n", event->data_len, event->data);
        xEventGroupSetBits(event_group, GOT_DATA_BIT);
    case MQTT_EVENT_ERROR:
        ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
    default:
        ESP_LOGI(TAG, "MQTT other event id: %d", event->event_id);
    return ESP_OK;
static void on_ppp_changed(void *arg, esp_event_base_t event_base,
    ESP_LOGI(TAG, "PPP state changed event %d", event_id);
    if (event_id == NETIF_PPP_ERRORUSER) {
        /* User interrupted event from esp-netif */
        esp_netif_t *netif = *(esp_netif_t**)event_data;
        ESP_LOGI(TAG, "User interrupted event from netif:%p", netif);
    if (event_id == NETIF_PPP_PHASE_DEAD) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_DEAD");
    if (event_id == NETIF_PPP_PHASE_MASTER) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_MASTER");
    if (event_id == NETIF_PPP_PHASE_HOLDOFF) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_HOLDOFF");
    if (event_id == NETIF_PPP_PHASE_INITIALIZE) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_INITIALIZE");
    if (event_id == NETIF_PPP_PHASE_SERIALCONN) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_SERIALCONN");
    if (event_id == NETIF_PPP_PHASE_DORMANT) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_DORMANT");
    if (event_id == NETIF_PPP_PHASE_ESTABLISH) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_ESTABLISH");
    if (event_id == NETIF_PPP_PHASE_AUTHENTICATE) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_AUTHENTICATE");
    if (event_id == NETIF_PPP_PHASE_CALLBACK) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_CALLBACK");
    if (event_id == NETIF_PPP_PHASE_NETWORK) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_NETWORK");
    if (event_id == NETIF_PPP_PHASE_RUNNING) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_RUNNING");
    if (event_id == NETIF_PPP_PHASE_TERMINATE) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_TERMINATE");
    if (event_id == NETIF_PPP_PHASE_DISCONNECT) {
        ESP_LOGI(TAG, "NETIF_PPP_PHASE_DISCONNECT");
    if (event_id == NETIF_PPP_CONNECT_FAILED) {
        ESP_LOGI(TAG, "NETIF_PPP_CONNECT_FAILED");
static void on_ip_event(void *arg, esp_event_base_t event_base,
    ESP_LOGD(TAG, "IP event! %d", event_id);
    if (event_id == IP_EVENT_PPP_GOT_IP) {
        esp_netif_dns_info_t dns_info;
        ip_event_got_ip_t *event = (ip_event_got_ip_t *)event_data;
        esp_netif_t *netif = event->esp_netif;
        ESP_LOGI(TAG, "Modem Connect to PPP Server");
        ESP_LOGI(TAG, "~~~~~~~~~~~~~~");
        ESP_LOGI(TAG, "IP          : " IPSTR, IP2STR(&event->ip_info.ip));
        ESP_LOGI(TAG, "Netmask     : " IPSTR, IP2STR(&event->ip_info.netmask));
        ESP_LOGI(TAG, "Gateway     : " IPSTR, IP2STR(&event->ip_info.gw));
        esp_netif_get_dns_info(netif, (esp_netif_dns_type_t)0, &dns_info);
        ESP_LOGI(TAG, "Name Server1: " IPSTR, IP2STR(&dns_info.ip.u_addr.ip4));
        esp_netif_get_dns_info(netif, (esp_netif_dns_type_t)1, &dns_info);
        ESP_LOGI(TAG, "Name Server2: " IPSTR, IP2STR(&dns_info.ip.u_addr.ip4));
        xEventGroupSetBits(event_group, CONNECT_BIT);
        ESP_LOGI(TAG, "GOT ip event!!!");
    } else if (event_id == IP_EVENT_PPP_LOST_IP) {
        ESP_LOGI(TAG, "Modem Disconnect from PPP Server");
    } else if (event_id == IP_EVENT_GOT_IP6) {
        ESP_LOGI(TAG, "GOT IPv6 event!");
        ip_event_got_ip6_t *event = (ip_event_got_ip6_t *)event_data;
        ESP_LOGI(TAG, "Got IPv6 address " IPV6STR, IPV62STR(event->ip6_info.ip));
extern "C" void app_main(void)
    printf("System start\n");
    vTaskDelay(500 / portTICK_PERIOD_MS);
    ESP_ERROR_CHECK(i2c_master_init());
    axp_irq_init();
    if (axp.begin((axp_com_fptr_t)twi_read, (axp_com_fptr_t)twi_write, AXP192_SLAVE_ADDRESS)) {
        ESP_LOGE(TAG, "Error init axp20x !!!");
        while (1);
    ESP_LOGI(TAG, "Success init axp20x !!!");
    axp.setPowerOutPut(AXP202_DCDC3, AXP202_ON);
    axp.setPowerOutPut(AXP202_EXTEN, AXP202_ON);
    axp.setPowerOutPut(AXP202_LDO2, AXP202_ON);
    axp.setPowerOutPut(AXP202_LDO4, AXP202_ON);
    axp.setPowerOutPut(AXP202_DCDC2, AXP202_ON);
    axp.setLDO4Voltage(AXP202_LDO4_1800MV);
    axp.setLDO3Voltage(3500);
    axp.setPowerOutPut(AXP202_LDO3, AXP202_ON);
    if ( axp.isDCDC2Enable()) {
        ESP_LOGI(TAG, "DC2: %u mV", axp.getDCDC2Voltage());
        ESP_LOGI(TAG, "DC2: DISABLE");
    if (axp.isDCDC3Enable()) {
        ESP_LOGI(TAG, "DC3: %u mV", axp.getDCDC3Voltage());
        ESP_LOGI(TAG, "DC3: DISABLE");
    if (axp.isLDO2Enable()) {
        ESP_LOGI(TAG, "LDO2: %u mV", axp.getLDO2Voltage());
        ESP_LOGI(TAG, "LDO2: DISABLE");
    if (axp.isLDO3Enable()) {
        ESP_LOGI(TAG, "LDO3: %u mV", axp.getLDO3Voltage());
        ESP_LOGI(TAG, "LDO3: DISABLE");
    if (axp.isLDO4Enable()) {
        ESP_LOGI(TAG, "LDO4: %u mV", axp.getLDO4Voltage());
        ESP_LOGI(TAG, "LDO4: DISABLE");
    if (axp.isExtenEnable()) {
        ESP_LOGI(TAG, "Exten: ENABLE");
        ESP_LOGI(TAG, "Exten: DISABLE");
    //When the chip is axp192 / 173, the allowed values are 0 ~ 15,
    //corresponding to the axp1xx_charge_current_t enumeration
    // axp.setChargeControlCur(AXP1XX_CHARGE_CUR_550MA);
    //axp202 allows maximum charging current of 1800mA, minimum 300mA
    axp.setChargeControlCur(300);
    ESP_LOGI(TAG, "setChargeControlCur:%u", axp.getChargeControlCur());
    //! Enable all irq channel
    axp.enableIRQ(AXP202_ALL_IRQ, true);
    axp.clearIRQ();
    //! Turn off unused power
    // axp.setPowerOutPut(AXP192_DCDC1, AXP202_OFF);
    // axp.setPowerOutPut(AXP192_LDO2, AXP202_OFF);
    // axp.setPowerOutPut(AXP192_LDO3, AXP202_OFF);
    // axp.setPowerOutPut(AXP192_DCDC2, AXP202_OFF);
    // axp.setPowerOutPut(AXP192_EXTEN, AXP202_OFF);
    //! Do not turn off DC3, it is powered by esp32
    // axp.setPowerOutPut(AXP192_DCDC3, AXP202_ON);
    // Set the charging indicator to turn off
    // Turn it off to save current consumption
    // axp.setChgLEDMode(AXP20X_LED_OFF);
    // Set the charging indicator to flash once per second
    // axp.setChgLEDMode(AXP20X_LED_BLINK_1HZ);
    //! Use axp192 adc get voltage info
    axp.adc1Enable(AXP202_VBUS_VOL_ADC1 | AXP202_VBUS_CUR_ADC1 | AXP202_BATT_CUR_ADC1 | AXP202_BATT_VOL_ADC1, true);
    // float vbus_v = axp.getVbusVoltage();
    // float vbus_c = axp.getVbusCurrent();
    // float batt_v = axp.getBattVoltage();
    // axp.getBattPercentage();   // axp192 is not support percentage
    //Serial.printf("VBUS:%.2f mV %.2f mA ,BATTERY: %.2f\n", vbus_v, vbus_c, batt_v);
    setupModem();
    vTaskDelay(10000 / portTICK_PERIOD_MS);
#if CONFIG_LWIP_PPP_PAP_SUPPORT
    esp_netif_auth_type_t auth_type = NETIF_PPP_AUTHTYPE_PAP;
#elif CONFIG_LWIP_PPP_CHAP_SUPPORT
    esp_netif_auth_type_t auth_type = NETIF_PPP_AUTHTYPE_CHAP;
#elif !defined(CONFIG_EXAMPLE_MODEM_PPP_AUTH_NONE)
#error "Unsupported AUTH Negotiation"
#endif
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, ESP_EVENT_ANY_ID, &on_ip_event, NULL));
    ESP_ERROR_CHECK(esp_event_handler_register(NETIF_PPP_STATUS, ESP_EVENT_ANY_ID, &on_ppp_changed, NULL));
    event_group = xEventGroupCreate();
    /* create dte object */
    //esp_modem_dte_config_t config = ESP_MODEM_DTE_DEFAULT_CONFIG();
    esp_modem_dte_config_t config = {0};
    /* setup UART specific configuration based on kconfig options */
    config.port_num = UART_NUM_1;
    config.data_bits = UART_DATA_8_BITS;
    config.stop_bits = UART_STOP_BITS_1;
    config.parity = UART_PARITY_DISABLE;
    config.baud_rate = 115200;
    config.flow_control = MODEM_FLOW_CONTROL_NONE;
    config.tx_io_num = CONFIG_EXAMPLE_MODEM_UART_TX_PIN;
    config.rx_io_num = CONFIG_EXAMPLE_MODEM_UART_RX_PIN;
    config.rts_io_num = CONFIG_EXAMPLE_MODEM_UART_RTS_PIN;
    config.cts_io_num = CONFIG_EXAMPLE_MODEM_UART_CTS_PIN;
    config.rx_buffer_size = CONFIG_EXAMPLE_MODEM_UART_RX_BUFFER_SIZE;
    config.tx_buffer_size = CONFIG_EXAMPLE_MODEM_UART_TX_BUFFER_SIZE;
    config.event_queue_size = CONFIG_EXAMPLE_MODEM_UART_EVENT_QUEUE_SIZE;
    config.event_task_stack_size = CONFIG_EXAMPLE_MODEM_UART_EVENT_TASK_STACK_SIZE;
    config.event_task_priority = CONFIG_EXAMPLE_MODEM_UART_EVENT_TASK_PRIORITY;
    config.dte_buffer_size = CONFIG_EXAMPLE_MODEM_UART_RX_BUFFER_SIZE / 2;
    modem_dte_t *dte = esp_modem_dte_init(&config);
    /* Register event handler */
    ESP_ERROR_CHECK(esp_modem_set_event_handler(dte, modem_event_handler, ESP_EVENT_ANY_ID, NULL));
    // Init netif object
    esp_netif_config_t cfg = ESP_NETIF_DEFAULT_PPP();
    esp_netif_t *esp_netif = esp_netif_new(&cfg);
    assert(esp_netif);
    void *modem_netif_adapter = esp_modem_netif_setup(dte);
    esp_modem_netif_set_default_handlers(modem_netif_adapter, esp_netif);
    modem_dce_t *dce = NULL;
    /* create dce object */
#if CONFIG_EXAMPLE_MODEM_DEVICE_SIM800
    dce = sim800_init(dte);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_BG96
    dce = bg96_init(dte);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_SIM7600
    dce = sim7600_init(dte);
#else
#error "Unsupported DCE"
#endif
    assert(dce != NULL);
    ESP_ERROR_CHECK(dce->set_flow_ctrl(dce, MODEM_FLOW_CONTROL_NONE));
    ESP_ERROR_CHECK(dce->store_profile(dce));
#if !defined(CONFIG_EXAMPLE_MODEM_PPP_AUTH_NONE) && (defined(CONFIG_LWIP_PPP_PAP_SUPPORT) || defined(CONFIG_LWIP_PPP_CHAP_SUPPORT))
    esp_netif_ppp_set_auth(esp_netif, auth_type, CONFIG_EXAMPLE_MODEM_PPP_AUTH_USERNAME, CONFIG_EXAMPLE_MODEM_PPP_AUTH_PASSWORD);
#endif
    /* attach the modem to the network interface */
    esp_netif_attach(esp_netif, modem_netif_adapter);
    /* Wait for IP address */
    xEventGroupWaitBits(event_group, CONNECT_BIT, pdTRUE, pdTRUE, portMAX_DELAY);
    /* Config MQTT */
    esp_mqtt_client_config_t mqtt_config = {0};
    mqtt_config.uri = BROKER_URL;
    mqtt_config.event_handle = mqtt_event_handler;
    esp_mqtt_client_handle_t mqtt_client = esp_mqtt_client_init(&mqtt_config);
    esp_mqtt_client_start(mqtt_client);
    uint32_t io_num;
    for (;;) {
        ESP_LOGI(TAG, "VBUS:%.2f mV %.2f mA ,BATTERY: %.2f", vbus_v, vbus_c, batt_v);
        ESP_ERROR_CHECK(dce->get_operator_name(dce));
        /* Print Module ID, Operator, IMEI, IMSI */
        ESP_LOGI(TAG, "Module: %s", dce->name);
        ESP_LOGI(TAG, "Operator: %s", dce->oper);
        ESP_LOGI(TAG, "IMEI: %s", dce->imei);
        ESP_LOGI(TAG, "IMSI: %s", dce->imsi);
        /* Get signal quality */
        uint32_t rssi = 0, ber = 0;
        ESP_ERROR_CHECK(dce->get_signal_quality(dce, &rssi, &ber));
        ESP_LOGI(TAG, "rssi: %d, ber: %d", rssi, ber);
        if (xQueueReceive(gpio_evt_queue, &io_num, 2000 / portTICK_PERIOD_MS)) {
            if (io_num == AXP_ISR_GPIO) {
                axp.readIRQ();
                if (axp.isPEKShortPressIRQ()) {
                    ESP_LOGI(TAG, "AXP202 PEK key Click");
                if(axp.isChargingIRQ()) {
                    ESP_LOGI(TAG, "AXP202 Battery charging in progress");
                if(axp.isChargingDoneIRQ()) {
                    ESP_LOGI(TAG, "AXP202 Battery charged");
                axp.clearIRQ();
        vTaskDelay(10);
Output:
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6608
load:0x40078000,len:14788
ho 0 tail 12 room 4
load:0x40080400,len:3792
entry 0x40080694
I (29) boot: ESP-IDF v4.4.1 2nd stage bootloader
I (29) boot: compile time 14:42:03
I (29) boot: chip revision: 1
I (31) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot.esp32: SPI Speed      : 40MHz
I (43) boot.esp32: SPI Mode       : DIO
I (48) boot.esp32: SPI Flash Size : 2MB
I (52) boot: Enabling RNG early entropy source...
I (58) boot: Partition Table:
I (61) boot: ## Label            Usage          Type ST Offset   Length
I (69) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (76) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (83) boot:  2 factory          factory app      00 00 00010000 00100000
I (91) boot: End of partition table
I (95) boot_comm: chip revision: 1, min. application chip revision: 0
I (102) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=1aec0h (110272)        map
I (151) esp_image: segment 1: paddr=0002aee8 vaddr=3ffb0000 size=02470h (  9328)        load
I (155) esp_image: segment 2: paddr=0002d360 vaddr=40080000 size=02cb8h ( 11448)        load
I (161) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=6d0b8h (446648)        map
I (327) esp_image: segment 4: paddr=0009d0e0 vaddr=40082cb8 size=0a750h ( 42832)        load
I (344) esp_image: segment 5: paddr=000a7838 vaddr=50000000 size=00010h (    16)        load
I (351) boot: Loaded app from partition at offset 0x10000
I (351) boot: Disabling RNG early entropy source...
I (365) cpu_start: Pro cpu up.
I (365) cpu_start: Starting app cpu, entry point is 0x4008126c
I (0) cpu_start: App cpu up.
I (379) cpu_start: Pro cpu start user code
I (379) cpu_start: cpu freq: 160000000
I (379) cpu_start: Application information:
I (383) cpu_start: Project name:     esp32-modem-project
I (389) cpu_start: App version:      1
I (394) cpu_start: Compile time:     Jul 20 2022 18:49:36
I (400) cpu_start: ELF file SHA256:  031c9a5f7ea18317...
I (406) cpu_start: ESP-IDF:          v4.4.1
I (411) heap_init: Initializing. RAM available for dynamic allocation:
I (418) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (424) heap_init: At 3FFB3E60 len 0002C1A0 (176 KiB): DRAM
I (430) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (437) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (443) heap_init: At 4008D408 len 00012BF8 (74 KiB): IRAM
I (451) spi_flash: detected chip: generic
I (454) spi_flash: flash io: dio
W (458) spi_flash: Detected size(4096k) larger than the size in the binary image        header(2048k). Using the size in the binary image header.
I (472) cpu_start: Starting scheduler on PRO CPU.
System start
I (1478) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulld        own: 0| Intr:2
I (1478) AXP20x: Success init axp20x !!!
I (1488) AXP20x: DC2: 1800 mV
I (1488) AXP20x: DC3: 3300 mV
I (1488) AXP20x: LDO2: 3300 mV
I (1488) AXP20x: LDO3: 3300 mV
I (1498) AXP20x: LDO4: DISABLE
I (1498) AXP20x: Exten: ENABLE
I (1498) AXP20x: setChargeControlCur:15
I (1518) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldo        wn: 0| Intr:0
I (1518) gpio: GPIO[25]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulld        own: 0| Intr:0
I (2628) AXP20x: Modem power has been setup
I (12628) uart: queue free spaces: 30
E (12648) esp-modem: handle line failed
W (12658) AXP20x: Unknown line received: +COPS: 0
I (12808) AXP20x: Modem PPP Started
I (12808) AXP20x: PPP state changed event 259
I (12808) AXP20x: NETIF_PPP_PHASE_INITIALIZE
I (12808) AXP20x: PPP state changed event 262
I (12808) AXP20x: NETIF_PPP_PHASE_ESTABLISH
I (12828) AXP20x: PPP state changed event 263
I (12828) AXP20x: NETIF_PPP_PHASE_AUTHENTICATE
I (12838) AXP20x: PPP state changed event 265
I (12838) AXP20x: NETIF_PPP_PHASE_NETWORK
I (12858) AXP20x: PPP state changed event 262
I (12858) AXP20x: NETIF_PPP_PHASE_ESTABLISH
I (18858) AXP20x: PPP state changed event 268
I (18858) AXP20x: NETIF_PPP_PHASE_DISCONNECT
I (18858) AXP20x: PPP state changed event 256
I (18858) AXP20x: NETIF_PPP_PHASE_DEAD
I (18858) esp-netif_lwip-ppp: Connection lost
I (18868) AXP20x: Modem Disconnect from PPP Server
Output with modem network disabled
ho 0 tail 12 room 4
entry 0x40080694
I (28) boot: ESP-IDF v4.4.1 2nd stage bootloader
I (38) boot.esp32: SPI Speed      : 40MHz
I (68) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (102) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=12c78h ( 76920)        map
I (139) esp_image: segment 1: paddr=00022ca0 vaddr=3ffb0000 size=023cch (  9164)        load
I (142) esp_image: segment 2: paddr=00025074 vaddr=40080000 size=0afa4h ( 44964)        load
I (163) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=45b2ch (285484)        map
I (266) esp_image: segment 4: paddr=00075b54 vaddr=4008afa4 size=0215ch (  8540)        load
I (270) esp_image: segment 5: paddr=00077cb8 vaddr=50000000 size=00010h (    16)        load
I (279) boot: Loaded app from partition at offset 0x10000
I (279) boot: Disabling RNG early entropy source...
I (295) cpu_start: Pro cpu up.
I (295) cpu_start: Starting app cpu, entry point is 0x40081240
I (309) cpu_start: Pro cpu start user code
I (309) cpu_start: cpu freq: 160000000
I (310) cpu_start: Application information:
I (314) cpu_start: Project name:     esp32-modem-project
I (320) cpu_start: App version:      1
I (324) cpu_start: Compile time:     Jul 20 2022 18:49:36
I (330) cpu_start: ELF file SHA256:  6e95eb54ca398127...
I (336) cpu_start: ESP-IDF:          v4.4.1
I (342) heap_init: Initializing. RAM available for dynamic allocation:
I (349) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (355) heap_init: At 3FFB3C90 len 0002C370 (176 KiB): DRAM
I (361) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (367) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (374) heap_init: At 4008D100 len 00012F00 (75 KiB): IRAM
I (381) spi_flash: detected chip: generic
I (385) spi_flash: flash io: dio
W (388) spi_flash: Detected size(4096k) larger than the size in the binary image        header(2048k). Using the size in the binary image header.
I (403) cpu_start: Starting scheduler on PRO CPU.
System start
I (1408) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulld        own: 0| Intr:2
I (1408) AXP20x: Success init axp20x !!!
I (1418) AXP20x: DC2: 1800 mV
I (1418) AXP20x: DC3: 3300 mV
I (1418) AXP20x: LDO2: 3300 mV
I (1418) AXP20x: LDO3: 3300 mV
I (1428) AXP20x: LDO4: DISABLE
I (1428) AXP20x: Exten: ENABLE
I (1428) AXP20x: setChargeControlCur:15
I (1448) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldo        wn: 0| Intr:0
I (1448) gpio: GPIO[25]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulld        own: 0| Intr:0
I (2558) AXP20x: Modem power has been setup
I (12558) uart: queue free spaces: 30
E (12578) esp-modem: handle line failed
W (12578) AXP20x: Unknown line received: +COPS: 0
I (12588) AXP20x: VBUS:5028.60 mV 0.00 mA ,BATTERY: 4195.40
E (12588) esp-modem: handle line failed
W (12588) AXP20x: Unknown line received: +COPS: 0
I (12598) AXP20x: Module: SIMCOM_SIM800C
I (12598) AXP20x: Operator:
I (12608) AXP20x: IMEI: 862205152863801
I (12608) AXP20x: IMSI: 250991639436458
E (12618) esp-modem: handle line failed
W (12618) AXP20x: Unknown line received: SMS Ready
I (12628) AXP20x: rssi: 0, ber: 0
I (14728) AXP20x: VBUS:5030.30 mV 0.00 mA ,BATTERY: 4195.40
E (14728) esp-modem: handle line failed
W (14728) AXP20x: Unknown line received: +COPS: 0
I (14728) AXP20x: Module: SIMCOM_SIM800C
I (14738) AXP20x: Operator:
I (14738) AXP20x: IMEI: 862205152863801
I (14748) AXP20x: IMSI: 250991639436458
I (14758) AXP20x: rssi: 31, ber: 0
I (16858) AXP20x: VBUS:5006.50 mV 14.62 mA ,BATTERY: 4195.40
I (16868) AXP20x: Module: SIMCOM_SIM800C
I (16868) AXP20x: Operator: "Bee Line GSM"
I (16868) AXP20x: IMEI: 862205152863801
I (16868) AXP20x: IMSI: 250991639436458
I (16878) AXP20x: rssi: 31, ber: 5
I (18978) AXP20x: VBUS:5032.00 mV 0.00 mA ,BATTERY: 4195.40
I (18988) AXP20x: Module: SIMCOM_SIM800C
I (18988) AXP20x: Operator: "Bee Line GSM"
I (18988) AXP20x: IMEI: 862205152863801
I (18988) AXP20x: IMSI: 250991639436458
I (18998) AXP20x: rssi: 31, ber: 5
I (21098) AXP20x: VBUS:5033.70 mV 0.00 mA ,BATTERY: 4195.40
I (21108) AXP20x: Module: SIMCOM_SIM800C
I (21108) AXP20x: Operator: "Bee Line GSM"
I (21108) AXP20x: IMEI: 862205152863801
I (21108) AXP20x: IMSI: 250991639436458
I (21118) AXP20x: rssi: 31, ber: 5
I (23218) AXP20x: VBUS:5030.30 mV 0.00 mA ,BATTERY: 4195.40
I (23228) AXP20x: Module: SIMCOM_SIM800C
I (23228) AXP20x: Operator: "Bee Line GSM"
I (23228) AXP20x: IMEI: 862205152863801
I (23228) AXP20x: IMSI: 250991639436458
I (23238) AXP20x: rssi: 31, ber: 5
I (25338) AXP20x: VBUS:5025.20 mV 0.00 mA ,BATTERY: 4195.40
I (25348) AXP20x: Module: SIMCOM_SIM800C
I (25348) AXP20x: Operator: "Bee Line GSM"
I (25348) AXP20x: IMEI: 862205152863801
I (25348) AXP20x: IMSI: 250991639436458
I (25358) AXP20x: rssi: 31, ber: 5
I (27458) AXP20x: VBUS:5035.40 mV 0.00 mA ,BATTERY: 4195.40
I (27468) AXP20x: Module: SIMCOM_SIM800C
I (27468) AXP20x: Operator: "Bee Line GSM"
I (27468) AXP20x: IMEI: 862205152863801
I (27468) AXP20x: IMSI: 250991639436458
I (27478) AXP20x: rssi: 31, ber: 5
I (29578) AXP20x: VBUS:5026.90 mV 0.00 mA ,BATTERY: 4195.40
I (29588) AXP20x: Module: SIMCOM_SIM800C
I (29588) AXP20x: Operator: "Bee Line GSM"
I (29588) AXP20x: IMEI: 862205152863801
I (29588) AXP20x: IMSI: 250991639436458
I (29598) AXP20x: rssi: 31, ber: 0
Parameters used:
APN internet.beeline.ru
user beeline
password beeline
dmitrij999
Re: ESP32+SIM800C=cannot connect to internet
Postby dmitrij999 » Sun Apr 28, 2024 1:07 pm
For now, I need to connect to Internet from ESP32 using SIM800C again, using LilyGO T-Call based on AXP192 PMIC.
I use ESP-IDF 5.2.1 and esp-modem v1.1.0 component, and use simple_cmux_client as a base.
But all I see that AT commands are working, PDP context is setting up, but connection to *99# establishes and interrupts even without connection to Internet. Even with setting the PAP authentication.
Now I'm using MTS sim card and I see the same effect as with Beeline.
As well, I provide auth credentials, but there is no effect.
Here is my code:
 * SPDX-FileCopyrightText: 2022-2023 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Unlicense OR CC0-1.0
/* PPPoS Client Example
#include <cstring>
#include <iostream>
#include "esp_event.h"
#include "cxx_include/esp_modem_dte.hpp"
#include "cxx_include/esp_modem_api.hpp"
#include "simple_mqtt_client.hpp"
#include "esp_vfs_dev.h"        // For optional VFS support
#include "esp_https_ota.h"      // For potential OTA configuration
#include "vfs_resource/vfs_create.hpp"
#include "SIM7070_gnss.hpp"
#include "driver/gpio.h"
#include "axp20x.h"
#if defined(CONFIG_EXAMPLE_FLOW_CONTROL_NONE)
#define EXAMPLE_FLOW_CONTROL ESP_MODEM_FLOW_CONTROL_NONE
#elif defined(CONFIG_EXAMPLE_FLOW_CONTROL_SW)
#define EXAMPLE_FLOW_CONTROL ESP_MODEM_FLOW_CONTROL_SW
#elif defined(CONFIG_EXAMPLE_FLOW_CONTROL_HW)
#define EXAMPLE_FLOW_CONTROL ESP_MODEM_FLOW_CONTROL_HW
#endif
#define BROKER_URL CONFIG_BROKER_URI
using namespace esp_modem;
static const char *TAG = "cmux_example";
AXP20X_Class axp;
static QueueHandle_t gpio_evt_queue = NULL;
    //enable interrupt
    //set as input mode
    i2c_port_t i2c_master_port = (i2c_port_t)I2C_MASTER_NUM;
    i2c_config_t conf;
    conf.clk_flags = 0;
    if (len == 0) {
        return ESP_OK;
    if (data == NULL) {
        return ESP_FAIL;
    esp_err_t ret =  i2c_master_cmd_begin(I2C_MASTER_NUM, cmd, pdMS_TO_TICKS(1000));
        return ESP_FAIL;
    if (len > 1) {
    return ret;
    if (data == NULL) {
        return ESP_FAIL;
    return ret;
void setupModem()
#ifdef MODEM_RST
    // Keep reset high
#endif
    // delay(100);
    // delay(1000);
    vTaskDelay(pdMS_TO_TICKS(100));
class StatusHandler {
public:
    static constexpr auto IP_Event      = SignalGroup::bit0;
    static constexpr auto MQTT_Connect  = SignalGroup::bit1;
    static constexpr auto MQTT_Data     = SignalGroup::bit2;
    StatusHandler()
        ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, ESP_EVENT_ANY_ID, on_event, this));
    ~StatusHandler()
        esp_event_handler_unregister(IP_EVENT, ESP_EVENT_ANY_ID, on_event);
    void handle_mqtt(MqttClient *client)
        mqtt_client = client;
        client->register_handler(ESP_EVENT_ANY_ID, on_event, this);
    esp_err_t wait_for(decltype(IP_Event) event, int milliseconds)
        return signal.wait_any(event, milliseconds);
    ip_event_t get_ip_event_type()
        return ip_event_type;
private:
    static void on_event(void *arg, esp_event_base_t base, int32_t event, void *data)
        auto *handler = static_cast<StatusHandler *>(arg);
        if (base == IP_EVENT) {
            handler->ip_event(event, data);
            handler->mqtt_event(event, data);
    void ip_event(int32_t id, void *data)
        if (id == IP_EVENT_PPP_GOT_IP) {
            auto *event = (ip_event_got_ip_t *)data;
            signal.set(IP_Event);
        } else if (id == IP_EVENT_PPP_LOST_IP) {
        ip_event_type = static_cast<ip_event_t>(id);
    void mqtt_event(int32_t event, void *data)
        if (mqtt_client && event == mqtt_client->get_event(MqttClient::Event::CONNECT)) {
            signal.set(MQTT_Connect);
        } else if (mqtt_client && event == mqtt_client->get_event(MqttClient::Event::DATA)) {
            ESP_LOGI(TAG, " TOPIC: %s", mqtt_client->get_topic(data).c_str());
            ESP_LOGI(TAG, " DATA: %s", mqtt_client->get_data(data).c_str());
            signal.set(MQTT_Data);
    esp_modem::SignalGroup signal{};
    MqttClient *mqtt_client{nullptr};
    ip_event_t ip_event_type;
    axp_irq_init();
        while (1);
    axp.clearIRQ();
    setupModem();
    /* Init and register system/core components */
    /* Configure and create the DTE */
    esp_modem_dte_config_t dte_config = ESP_MODEM_DTE_DEFAULT_CONFIG();
    dte_config.uart_config.tx_io_num = CONFIG_EXAMPLE_MODEM_UART_TX_PIN;
    dte_config.uart_config.rx_io_num = CONFIG_EXAMPLE_MODEM_UART_RX_PIN;
    dte_config.uart_config.rts_io_num = CONFIG_EXAMPLE_MODEM_UART_RTS_PIN;
    dte_config.uart_config.cts_io_num = CONFIG_EXAMPLE_MODEM_UART_CTS_PIN;
    dte_config.uart_config.flow_control = EXAMPLE_FLOW_CONTROL;
#if CONFIG_EXAMPLE_USE_VFS_TERM == 1
    /* The VFS terminal is just a demonstration of using an abstract file descriptor
     * which implements non-block reads, writes and selects to communicate with esp-modem.
     * This configuration uses the same UART driver as the terminal created by `create_uart_dte()`,
     * so doesn't give any practical benefit besides the FD use demonstration and a placeholder
     * to use FD terminal for other devices
    struct esp_modem_vfs_uart_creator uart_config = ESP_MODEM_VFS_DEFAULT_UART_CONFIG("/dev/uart/1");
    assert(vfs_create_uart(&uart_config, &dte_config.vfs_config) == true);
    auto dte = create_vfs_dte(&dte_config);
    esp_vfs_dev_uart_use_driver(uart_config.uart.port_num);
#else
    auto dte = create_uart_dte(&dte_config);
#endif // CONFIG_EXAMPLE_USE_VFS_TERM
    assert(dte);
    /* Configure the DCE */
    esp_modem_dce_config_t dce_config = ESP_MODEM_DCE_DEFAULT_CONFIG(CONFIG_EXAMPLE_MODEM_PPP_APN);
    /* Configure the PPP netif */
    esp_netif_config_t netif_ppp_config = ESP_NETIF_DEFAULT_PPP();
    /* Create the PPP and DCE objects */
    esp_netif_t *esp_netif = esp_netif_new(&netif_ppp_config);
    assert(esp_netif);
    if (esp_netif_ppp_set_auth(esp_netif, esp_netif_auth_type_t::NETIF_PPP_AUTHTYPE_PAP,
        CONFIG_EXAMPLE_MODEM_PPP_AUTH_USERNAME, CONFIG_EXAMPLE_MODEM_PPP_AUTH_PASSWORD) == ESP_OK)
        ESP_LOGI(TAG, "PPP auth set");
    else
        ESP_LOGE(TAG, "PPP auth failed");
#if CONFIG_EXAMPLE_MODEM_DEVICE_BG96 == 1
    auto dce = create_BG96_dce(&dce_config, dte, esp_netif);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_SIM800 == 1
    auto dce = create_SIM800_dce(&dce_config, dte, esp_netif);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_SIM7000 == 1
    auto dce = create_SIM7000_dce(&dce_config, dte, esp_netif);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_SIM7070 == 1
    auto dce = create_SIM7070_dce(&dce_config, dte, esp_netif);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_SIM7070_GNSS == 1
    auto dce = create_SIM7070_GNSS_dce(&dce_config, dte, esp_netif);
#elif CONFIG_EXAMPLE_MODEM_DEVICE_SIM7600 == 1
    auto dce = create_SIM7600_dce(&dce_config, dte, esp_netif);
#else
#error "Unsupported device"
#endif
    assert(dce);
    /* Try to connect to the network and publish an mqtt topic */
    StatusHandler handler;
    if (dte_config.uart_config.flow_control == ESP_MODEM_FLOW_CONTROL_HW) {
        if (command_result::OK != dce->set_flow_control(2, 2)) {
            ESP_LOGE(TAG, "Failed to set the set_flow_control mode");
            return;
        ESP_LOGI(TAG, "set_flow_control OK");
        ESP_LOGI(TAG, "not set_flow_control, because 2-wire mode active.");
    /* Setup basic operation mode for the DCE (pin if used, CMUX mode) */
#if CONFIG_EXAMPLE_NEED_SIM_PIN == 1
    bool pin_ok = true;
    if (dce->read_pin(pin_ok) == command_result::OK && !pin_ok) {
        ESP_MODEM_THROW_IF_FALSE(dce->set_pin(CONFIG_EXAMPLE_SIM_PIN) == command_result::OK, "Cannot set PIN!");
        vTaskDelay(pdMS_TO_TICKS(1000)); // Need to wait for some time after unlocking the SIM
#endif
    // Trigger PPP
    esp_err_t err1 = dce->set_mode(esp_modem::modem_mode::DATA_MODE);
    if (err1 != ESP_OK) {
        ESP_LOGE(TAG, "esp_modem_set_mode(ESP_MODEM_MODE_DATA) failed with %d", err1);
        return;
    } else
        ESP_LOGI(TAG, "esp_modem_set_mode(ESP_MODEM_MODE_DATA) ok");
    vTaskDelay(pdMS_TO_TICKS(30000));
    if (dce->set_mode(esp_modem::modem_mode::CMUX_MODE)) {
        std::cout << "Modem has correctly entered multiplexed command/data mode" << std::endl;
        ESP_LOGE(TAG, "Failed to configure multiplexed command mode... exiting");
        return;
    //vTaskDelay(pdMS_TO_TICKS(30000));
    /* Read some data from the modem */
    std::string str;
    while (dce->get_operator_name(str) != esp_modem::command_result::OK) {
        // Getting operator name could fail... retry after 500 ms
        vTaskDelay(pdMS_TO_TICKS(500));
    std::cout << "Operator name:" << str << std::endl;
#if CONFIG_EXAMPLE_MODEM_DEVICE_SIM7070_GNSS == 1
    if (dce->set_gnss_power_mode(1) == esp_modem::command_result::OK) {
        std::cout << "Modem set_gnss_power_mode: OK" << std::endl;
#endif
    if (!handler.wait_for(StatusHandler::IP_Event, 60000)) {
        ESP_LOGE(TAG, "Cannot get IP within specified timeout... exiting");
        return;
    } else if (handler.get_ip_event_type() == IP_EVENT_PPP_GOT_IP) {
        std::cout << "Got IP address" << std::endl;
        /* When connected to network, subscribe and publish some MQTT data */
        MqttClient mqtt(BROKER_URL);
        handler.handle_mqtt(&mqtt);
        mqtt.connect();
        if (!handler.wait_for(StatusHandler::MQTT_Connect, 60000)) {
            ESP_LOGE(TAG, "Cannot connect to %s within specified timeout... exiting", BROKER_URL);
            return;
        std::cout << "Connected" << std::endl;
        mqtt.subscribe("/topic/esp-modem");
        mqtt.publish("/topic/esp-modem", "Hello modem");
        if (!handler.wait_for(StatusHandler::MQTT_Data, 60000)) {
            ESP_LOGE(TAG, "Didn't receive published data within specified timeout... exiting");
            return;
        std::cout << "Received MQTT data" << std::endl;
    } else if (handler.get_ip_event_type() == IP_EVENT_PPP_LOST_IP) {
        ESP_LOGE(TAG, "PPP client has lost connection... exiting");
        return;
    /* Again reading some data from the modem */
    if (dce->get_imsi(str) == esp_modem::command_result::OK) {
        std::cout << "Modem IMSI number:" << str << std::endl;
    esp_modem_gps_t gps;
    for (int i = 0; i < 200; ++i) {
        if (dce->get_gnss_information_sim70xx(gps) == esp_modem::command_result::OK) {
            ESP_LOGI(TAG, "gps.run  %i",
                     gps.run);
            ESP_LOGI(TAG, "gps.fix  %i",
                     gps.fix);
            ESP_LOGI(TAG, "gps.date.year %i gps.date.month %i gps.date.day %i",
                     gps.date.year,   gps.date.month,   gps.date.day);
            ESP_LOGI(TAG, "gps.tim.hour %i gps.tim.minute %i   gps.tim.second %i   gps.tim.thousand %i",
                     gps.tim.hour,   gps.tim.minute,     gps.tim.second,     gps.tim.thousand);
            ESP_LOGI(TAG, "gps.latitude %f gps.longitude %f ",
                     gps.latitude,   gps.longitude );
            ESP_LOGI(TAG, "gps.altitude  %f",
                     gps.altitude);
            ESP_LOGI(TAG, "gps.speed  %f",
                     gps.speed);
            ESP_LOGI(TAG, "gps.cog  %f",
                     gps.cog);
            ESP_LOGI(TAG, "gps.fix_mode  %i",
                     gps.fix_mode);
            ESP_LOGI(TAG, "gps.dop_h %f gps.dop_p %f gps.dop_v %f ",
                     gps.dop_h,   gps.dop_p,   gps.dop_v );
            ESP_LOGI(TAG, "gps.sats_in_view  %i",
                     gps.sats_in_view);
            ESP_LOGI(TAG, "gps.hpa  %f gps.vpa  %f",
                     gps.hpa, gps.vpa);
        vTaskDelay(pdMS_TO_TICKS(1000)); //Wait
#endif  // CONFIG_EXAMPLE_MODEM_DEVICE_SIM7070_GNSS
#if CONFIG_EXAMPLE_PERFORM_OTA == 1
    esp_http_client_config_t config = { };
    config.skip_cert_common_name_check = true;
    config.url = CONFIG_EXAMPLE_PERFORM_OTA_URI;
    esp_err_t ret = esp_https_ota(&config);
    if (ret == ESP_OK) {
        esp_restart();
        ESP_LOGE(TAG, "Firmware upgrade failed");
        return;
#endif // CONFIG_EXAMPLE_PERFORM_OTA
    /* Close multiplexed command/data mode */
#if CONFIG_EXAMPLE_CLOSE_CMUX_AT_END == 1
    if (dce->set_mode(esp_modem::modem_mode::COMMAND_MODE)) {
        std::cout << "Modem has correctly entered command mode" << std::endl;
        ESP_LOGE(TAG, "Failed to configure desired mode... exiting");
        return;
#endif
And verbose connection logs:
load:0x3fff0030,len:7172
load:0x40078000,len:15540
load:0x40080400,len:4
0x40080400: _init at ??:?
ho 8 tail 4 room 4
load:0x40080404,len:3904
entry 0x40080640
I (31) boot: ESP-IDF v5.2.1 2nd stage bootloader
I (31) boot: compile time Apr 28 2024 16:00:47
I (31) boot: Multicore bootloader
I (35) boot: chip revision: v1.0
I (48) boot.esp32: SPI Flash Size : 4MB
I (69) boot:  0 nvs              WiFi data        01 02 00010000 00006000
I (76) boot:  1 phy_init         RF data          01 01 00016000 00001000
I (83) boot:  2 factory          factory app      00 00 00020000 00100000
I (95) esp_image: segment 0: paddr=00020020 vaddr=3f400020 size=3f9c4h (260548) map
I (157) esp_image: segment 1: paddr=0005f9ec vaddr=3ffb0000 size=0062ch (  1580) load
I (158) esp_image: segment 2: paddr=00060020 vaddr=400d0020 size=9d954h (645460) map
I (296) esp_image: segment 3: paddr=000fd97c vaddr=3ffb062c size=02148h (  8520) load
I (298) esp_image: segment 4: paddr=000ffacc vaddr=40080000 size=0f9e4h ( 63972) load
I (326) boot: Loaded app from partition at offset 0x20000
I (326) boot: Disabling RNG early entropy source...
I (337) cpu_start: Multicore app
V (338) mmap: after coalescing, 3 regions are left
D (338) cpu_start: Pro cpu up
D (338) cpu_start: Starting app cpu, entry point is 0x400812fc
0x400812fc: call_start_cpu1 at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_system/port/cpu_start.c:183
D (0) cpu_start: App cpu up
D (352) clk: RTC_SLOW_CLK calibration value: 3329344
I (364) cpu_start: Pro cpu start user code
I (364) cpu_start: cpu freq: 160000000 Hz
I (364) cpu_start: Application information:
I (368) cpu_start: Project name:     simple_cmux_client
I (374) cpu_start: App version:      1
I (379) cpu_start: Compile time:     Apr 28 2024 16:00:50
I (385) cpu_start: ELF file SHA256:  3e57be039...
I (390) cpu_start: ESP-IDF:          v5.2.1
I (395) cpu_start: Min chip rev:     v0.0
I (400) cpu_start: Max chip rev:     v3.99
I (405) cpu_start: Chip rev:         v1.0
V (409) memory_layout: reserved range is 0x3f43f98c - 0x3f43f9d4
D (415) memory_layout: Checking 9 reserved memory ranges:
D (421) memory_layout: Reserved memory range 0x3ff82000 - 0x3ff82000
D (427) memory_layout: Reserved memory range 0x3ffae000 - 0x3ffae6e0
D (434) memory_layout: Reserved memory range 0x3ffb0000 - 0x3ffb5868
D (440) memory_layout: Reserved memory range 0x3ffe0000 - 0x3ffe0440
D (446) memory_layout: Reserved memory range 0x3ffe3f20 - 0x3ffe4350
D (453) memory_layout: Reserved memory range 0x40070000 - 0x40078000
D (459) memory_layout: Reserved memory range 0x40078000 - 0x40080000
0x40080000: _WindowOverflow4 at /home/espidf521/esp/esp-idf-v5.2.1/components/xtensa/xtensa_vectors.S:2027
D (466) memory_layout: Reserved memory range 0x40080000 - 0x4008f9e4
D (472) memory_layout: Reserved memory range 0x50001fe8 - 0x50002000
D (479) memory_layout: Building list of available memory regions:
V (485) memory_layout: Examining memory region 0x3ffae000 - 0x3ffb0000
V (491) memory_layout: Start of region 0x3ffae000 - 0x3ffb0000 overlaps reserved 0x3ffae000 - 0x3ffae6e0
D (501) memory_layout: Available memory region 0x3ffae6e0 - 0x3ffb0000
V (508) memory_layout: Examining memory region 0x3ffb0000 - 0x3ffb8000
V (514) memory_layout: Start of region 0x3ffb0000 - 0x3ffb8000 overlaps reserved 0x3ffb0000 - 0x3ffb5868
D (524) memory_layout: Available memory region 0x3ffb5868 - 0x3ffb8000
V (530) memory_layout: Examining memory region 0x3ffb8000 - 0x3ffc0000
D (537) memory_layout: Available memory region 0x3ffb8000 - 0x3ffc0000
V (543) memory_layout: Examining memory region 0x3ffc0000 - 0x3ffc2000
D (550) memory_layout: Available memory region 0x3ffc0000 - 0x3ffc2000
V (557) memory_layout: Examining memory region 0x3ffc2000 - 0x3ffc4000
D (563) memory_layout: Available memory region 0x3ffc2000 - 0x3ffc4000
V (570) memory_layout: Examining memory region 0x3ffc4000 - 0x3ffc6000
D (576) memory_layout: Available memory region 0x3ffc4000 - 0x3ffc6000
V (583) memory_layout: Examining memory region 0x3ffc6000 - 0x3ffc8000
D (590) memory_layout: Available memory region 0x3ffc6000 - 0x3ffc8000
V (596) memory_layout: Examining memory region 0x3ffc8000 - 0x3ffca000
D (603) memory_layout: Available memory region 0x3ffc8000 - 0x3ffca000
V (609) memory_layout: Examining memory region 0x3ffca000 - 0x3ffcc000
D (616) memory_layout: Available memory region 0x3ffca000 - 0x3ffcc000
V (623) memory_layout: Examining memory region 0x3ffcc000 - 0x3ffce000
D (629) memory_layout: Available memory region 0x3ffcc000 - 0x3ffce000
V (636) memory_layout: Examining memory region 0x3ffce000 - 0x3ffd0000
D (642) memory_layout: Available memory region 0x3ffce000 - 0x3ffd0000
V (649) memory_layout: Examining memory region 0x3ffd0000 - 0x3ffd2000
D (656) memory_layout: Available memory region 0x3ffd0000 - 0x3ffd2000
V (662) memory_layout: Examining memory region 0x3ffd2000 - 0x3ffd4000
D (669) memory_layout: Available memory region 0x3ffd2000 - 0x3ffd4000
V (675) memory_layout: Examining memory region 0x3ffd4000 - 0x3ffd6000
D (682) memory_layout: Available memory region 0x3ffd4000 - 0x3ffd6000
V (689) memory_layout: Examining memory region 0x3ffd6000 - 0x3ffd8000
D (695) memory_layout: Available memory region 0x3ffd6000 - 0x3ffd8000
V (702) memory_layout: Examining memory region 0x3ffd8000 - 0x3ffda000
D (708) memory_layout: Available memory region 0x3ffd8000 - 0x3ffda000
V (715) memory_layout: Examining memory region 0x3ffda000 - 0x3ffdc000
D (722) memory_layout: Available memory region 0x3ffda000 - 0x3ffdc000
V (728) memory_layout: Examining memory region 0x3ffdc000 - 0x3ffde000
D (735) memory_layout: Available memory region 0x3ffdc000 - 0x3ffde000
V (741) memory_layout: Examining memory region 0x3ffde000 - 0x3ffe0000
D (748) memory_layout: Available memory region 0x3ffde000 - 0x3ffe0000
V (755) memory_layout: Examining memory region 0x3ffe0000 - 0x3ffe4000
V (761) memory_layout: Start of region 0x3ffe0000 - 0x3ffe4000 overlaps reserved 0x3ffe0000 - 0x3ffe0440
V (771) memory_layout: End of region 0x3ffe0440 - 0x3ffe4000 overlaps reserved 0x3ffe3f20 - 0x3ffe4350
D (780) memory_layout: Available memory region 0x3ffe0440 - 0x3ffe3f20
V (787) memory_layout: Examining memory region 0x3ffe4000 - 0x3ffe8000
V (793) memory_layout: Start of region 0x3ffe4000 - 0x3ffe8000 overlaps reserved 0x3ffe3f20 - 0x3ffe4350
D (803) memory_layout: Available memory region 0x3ffe4350 - 0x3ffe8000
V (809) memory_layout: Examining memory region 0x3ffe8000 - 0x3fff0000
D (816) memory_layout: Available memory region 0x3ffe8000 - 0x3fff0000
V (823) memory_layout: Examining memory region 0x3fff0000 - 0x3fff8000
D (829) memory_layout: Available memory region 0x3fff0000 - 0x3fff8000
V (836) memory_layout: Examining memory region 0x3fff8000 - 0x3fffc000
D (842) memory_layout: Available memory region 0x3fff8000 - 0x3fffc000
V (849) memory_layout: Examining memory region 0x3fffc000 - 0x40000000
0x40000000: _WindowOverflow4 in ROM
D (856) memory_layout: Available memory region 0x3fffc000 - 0x40000000
V (862) memory_layout: Examining memory region 0x40070000 - 0x40078000
V (869) memory_layout: Region 0x40070000 - 0x40078000 inside of reserved 0x40070000 - 0x40078000
V (878) memory_layout: Examining memory region 0x40078000 - 0x40080000
V (884) memory_layout: Region 0x40078000 - 0x40080000 inside of reserved 0x40078000 - 0x40080000
V (893) memory_layout: Examining memory region 0x40080000 - 0x40082000
0x40082000: heap_caps_alloc_failed at /home/espidf521/esp/esp-idf-v5.2.1/components/heap/heap_caps.c:89
V (900) memory_layout: Region 0x40080000 - 0x40082000 inside of reserved 0x40080000 - 0x4008f9e4
V (909) memory_layout: Examining memory region 0x40082000 - 0x40084000
0x40084000: uart_rx_intr_handler_default at /home/espidf521/esp/esp-idf-v5.2.1/components/driver/uart/uart.c:972
V (915) memory_layout: Region 0x40082000 - 0x40084000 inside of reserved 0x40080000 - 0x4008f9e4
V (924) memory_layout: Examining memory region 0x40084000 - 0x40086000
0x40086000: clk_ll_cpu_get_src at /home/espidf521/esp/esp-idf-v5.2.1/components/hal/esp32/include/hal/clk_tree_ll.h:569
 (inlined by) rtc_clk_cpu_freq_get_config at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_hw_support/port/esp32/rtc_clk.c:488
V (931) memory_layout: Region 0x40084000 - 0x40086000 inside of reserved 0x40080000 - 0x4008f9e4
V (939) memory_layout: Examining memory region 0x40086000 - 0x40088000
0x40088000: prvInitialiseMutex at /home/espidf521/esp/esp-idf-v5.2.1/components/freertos/FreeRTOS-Kernel/queue.c:651
V (946) memory_layout: Region 0x40086000 - 0x40088000 inside of reserved 0x40080000 - 0x4008f9e4
V (955) memory_layout: Examining memory region 0x40088000 - 0x4008a000
0x4008a000: vTaskRemoveFromUnorderedEventList at /home/espidf521/esp/esp-idf-v5.2.1/components/freertos/FreeRTOS-Kernel/tasks.c:4000 (discriminator 3)
V (962) memory_layout: Region 0x40088000 - 0x4008a000 inside of reserved 0x40080000 - 0x4008f9e4
V (970) memory_layout: Examining memory region 0x4008a000 - 0x4008c000
0x4008c000: spi_flash_encrypt_ll_plaintext_save at /home/espidf521/esp/esp-idf-v5.2.1/components/hal/esp32/include/hal/spi_flash_encrypted_ll.h:78
V (977) memory_layout: Region 0x4008a000 - 0x4008c000 inside of reserved 0x40080000 - 0x4008f9e4
V (986) memory_layout: Examining memory region 0x4008c000 - 0x4008e000
0x4008e000: block_insert at /home/espidf521/esp/esp-idf-v5.2.1/components/heap/tlsf/tlsf.c:389
 (inlined by) block_trim_used at /home/espidf521/esp/esp-idf-v5.2.1/components/heap/tlsf/tlsf.c:517
 (inlined by) tlsf_realloc at /home/espidf521/esp/esp-idf-v5.2.1/components/heap/tlsf/tlsf.c:1197
V (992) memory_layout: Region 0x4008c000 - 0x4008e000 inside of reserved 0x40080000 - 0x4008f9e4
V (1001) memory_layout: Examining memory region 0x4008e000 - 0x40090000
V (1008) memory_layout: Start of region 0x4008e000 - 0x40090000 overlaps reserved 0x40080000 - 0x4008f9e4
D (1018) memory_layout: Available memory region 0x4008f9e4 - 0x40090000
V (1024) memory_layout: Examining memory region 0x40090000 - 0x40092000
D (1031) memory_layout: Available memory region 0x40090000 - 0x40092000
V (1038) memory_layout: Examining memory region 0x40092000 - 0x40094000
D (1044) memory_layout: Available memory region 0x40092000 - 0x40094000
V (1051) memory_layout: Examining memory region 0x40094000 - 0x40096000
D (1058) memory_layout: Available memory region 0x40094000 - 0x40096000
V (1064) memory_layout: Examining memory region 0x40096000 - 0x40098000
D (1071) memory_layout: Available memory region 0x40096000 - 0x40098000
V (1078) memory_layout: Examining memory region 0x40098000 - 0x4009a000
D (1084) memory_layout: Available memory region 0x40098000 - 0x4009a000
V (1091) memory_layout: Examining memory region 0x4009a000 - 0x4009c000
D (1098) memory_layout: Available memory region 0x4009a000 - 0x4009c000
V (1104) memory_layout: Examining memory region 0x4009c000 - 0x4009e000
D (1111) memory_layout: Available memory region 0x4009c000 - 0x4009e000
V (1118) memory_layout: Examining memory region 0x4009e000 - 0x400a0000
D (1125) memory_layout: Available memory region 0x4009e000 - 0x400a0000
I (1131) heap_init: Initializing. RAM available for dynamic allocation:
D (1139) heap_init: New heap initialised at 0x3ffae6e0
I (1144) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
D (1150) heap_init: New heap initialised at 0x3ffb5868
I (1155) heap_init: At 3FFB5868 len 0002A798 (169 KiB): DRAM
I (1161) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1168) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
D (1174) heap_init: New heap initialised at 0x4008f9e4
I (1180) heap_init: At 4008F9E4 len 0001061C (65 KiB): IRAM
V (1186) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1192) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0x40E
D (1201) intr_alloc: Connected src 46 to int 2 (cpu 0)
V (1207) memspi: raw_chip_id: 164020
V (1210) memspi: chip_id: 204016
V (1213) memspi: raw_chip_id: 164020
V (1217) memspi: chip_id: 204016
D (1220) spi_flash: trying chip: issi
D (1224) spi_flash: trying chip: gd
D (1228) spi_flash: trying chip: mxic
D (1231) spi_flash: trying chip: winbond
D (1235) spi_flash: trying chip: generic
I (1239) spi_flash: detected chip: generic
I (1244) spi_flash: flash io: dio
D (1248) cpu_start: calling init function: 0x40147ac0
0x40147ac0: _GLOBAL__sub_I__ZNSt12ctype_bynameIwEC2ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEj at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/src/c++11/locale-inst.cc:160
D (1253) cpu_start: calling init function: 0x401430f4
0x401430f4: _GLOBAL__sub_I__ZNSt12ctype_bynameIcEC2ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEj at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/src/c++11/locale-inst.cc:160
D (1258) cpu_start: calling init function: 0x4013a3a4
0x4013a3a4: _GLOBAL__sub_I__ZNSt12ctype_bynameIwEC2ERKSsj at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/src/c++11/locale-inst.cc:160
D (1263) cpu_start: calling init function: 0x40132c88
0x40132c88: _GLOBAL__sub_I__ZNSt12ctype_bynameIcEC2ERKSsj at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/src/c++11/locale-inst.cc:160
D (1268) cpu_start: calling init function: 0x4012bc94
0x4012bc94: _GLOBAL__sub_I$00090__ZSt3cin at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/src/c++98/globals_io.cc:109
V (1273) pthread: pthread_once: call init_routine 0x3ffb08cc
V (1279) pthread: pthread_once: call init_routine 0x3ffb08c4
D (1287) cpu_start: calling init function: 0x4012af90
0x4012af90: _GLOBAL__sub_I__ZN17__eh_globals_init7_S_initE at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/libsupc++/eh_globals.cc:162
D (1290) cpu_start: calling init function: 0x4012ad04
0x4012ad04: _GLOBAL__sub_I__ZN9__gnu_cxx9__freeresEv at /builds/idf/crosstool-NG/.build/xtensa-esp-elf/src/gcc/libstdc++-v3/libsupc++/eh_alloc.cc:462
D (1295) cpu_start: calling init function: 0x400e96cc
0x400e96cc: esp_ipc_init at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_system/esp_ipc.c:114
D (1300) cpu_start: calling init function: 0x400e766c
0x400e766c: check_i2c_driver_conflict at /home/espidf521/esp/esp-idf-v5.2.1/components/driver/i2c/i2c.c:1652
W (1305) i2c: This driver is an old driver, please migrate your application code to adapt `driver/i2c_master.h`
D (1315) cpu_start: calling init function: 0x400d75e8
0x400d75e8: _GLOBAL__sub_I_axp at /home/espidf521/esp32-workspace/simple_cmux_client/main/simple_cmux_client_main.cpp:623
D (1321) cpu_start: calling init function: 0x400866fc
0x400866fc: enable_timer_group0_for_calibration at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_hw_support/port/esp32/rtc_time.c:197
D (1326) cpu_start: calling init function: 0x400d2e7c
0x400d2e7c: esp_app_format_init_elf_sha256 at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_app_format/esp_app_desc.c:68
D (1331) cpu_start: calling init function: 0x400d6334 on core: 0
0x400d6334: __esp_system_init_fn_esp_timer_startup_init at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_timer/src/esp_timer.c:578
V (1337) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1343) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xC02
D (1351) intr_alloc: Connected src 17 to int 3 (cpu 0)
D (1356) cpu_start: calling init function: 0x400d3fb0 on core: 0
0x400d3fb0: __esp_system_init_fn_init_components0 at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_system/startup.c:493
D (1362) cpu_start: Setting C++ exception workarounds.
V (1368) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1374) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0x40E
D (1382) intr_alloc: Connected src 24 to int 9 (cpu 0)
D (1388) app_start: Starting scheduler on CPU0
V (1392) intr_alloc: esp_intr_alloc_intrstatus (cpu 1): checking args
V (1392) intr_alloc: esp_intr_alloc_intrstatus (cpu 1): Args okay. Resulting flags 0x40E
 (1402) intr_alloc: Connected src 25 to int 2 (cpu 1)
D (1412) app_start: Starting scheduler on CPU1
;32mI (1392) main_task: Started on CPU0
D (1422) heap_init: New heap initialised at 0x3ffe0440
D (1422) heap_init: New heap initialised at 0x3ffe4350
V (1422) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1432) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (1442) intr_alloc: Connected src 16 to int 12 (cpu 0)
I (1442) main_task: Calling app_main()
System start
V (1952) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1952) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (1952) intr_alloc: Connected src 50 to int 13 (cpu 0)
I (1952) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:2
V (1962) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (1972) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (1982) intr_alloc: Connected src 22 to int 17 (cpu 0)
I (1992) cmux_example: Success init axp20x !!!
I (2002) cmux_example: DC2: 1800 mV
I (2002) cmux_example: DC3: 3300 mV
I (2002) cmux_example: LDO2: 3300 mV
I (2002) cmux_example: LDO3: 3300 mV
I (2012) cmux_example: LDO4: DISABLE
I (2012) cmux_example: Exten: ENABLE
I (2022) cmux_example: setChargeControlCur:15
I (2032) gpio: GPIO[4]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2032) gpio: GPIO[25]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (2242) cmux_example: Modem power has been setup
D (12242) event: running task for loop 0x3ffb9f44
D (12242) event: created task for loop 0x3ffb9f44
D (12242) event: created event loop 0x3ffb9f44
D (12242) esp_netif_lwip: LwIP stack has been initialized
D (12242) esp_netif_lwip: esp-netif has been successfully initialized
I (12252) uart: ESP_INTR_FLAG_IRAM flag not set while CONFIG_UART_ISR_IN_IRAM is enabled, flag updated
I (12262) uart: queue free spaces: 30
V (12262) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (12272) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0x40E
D (12282) intr_alloc: Connected src 35 to int 18 (cpu 0)
D (12292) esp_netif_lwip: check: remote, if=0x3ffb8c10 fn=0x400ebc0c
0x400ebc0c: esp_netif_new_api at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_netif/lwip/esp_netif_lwip.c:690
V (12292) esp_netif_objects: esp_netif_add_to_list_unsafe 0x3ffbf388
D (12302) esp_netif_objects: esp_netif_add_to_list_unsafe netif added successfully (total netifs: 1)
D (12312) esp-netif_lwip-ppp: esp_netif_new_ppp: PPP connection created: 0x3ffbf5b8
D (12312) esp-netif_lwip-ppp: Phase Dead
D (12322) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (12322) esp_netif_lwip: check: remote, if=0x3ffbf388 fn=0x400ec360
0x400ec360: esp_netif_ppp_set_auth_api at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_netif/lwip/esp_netif_lwip.c:2503
D (12332) esp_netif_lwip: call api in lwip: ret=0x0, give sem
I (12342) cmux_example: PPP auth set
V (12342) command_lib: set_flow_control
V (12342) command_lib: generic_command_common
V (12352) command_lib: generic_command
D (12352) command_lib: generic_command command AT+IFC=2,2
D (12362) command_lib: Response:
OK
I (12362) cmux_example: set_flow_control OK
V (12372) command_lib: set_echo
V (12372) command_lib: generic_command_common
D (12382) command_lib: generic_command command ATE0
D (12382) command_lib: Response:
OK
V (12392) command_lib: set_pdp_context
V (12392) command_lib: generic_command_common
D (12402) command_lib: generic_command command AT+CGDCONT=1,"IP","internet.mts.ru"
D (12422) command_lib: Response:
OK
V (12422) command_lib: set_data_mode
V (12422) command_lib: generic_command
D (12422) command_lib: generic_command command ATD*99#
D (12432) command_lib: Response:
CONNECT
D (12432) esp_netif_handlers: esp_netif action has started with netif0x3ffbf388 from event_id=0
D (12442) esp_netif_lwip: check: remote, if=0x3ffbf388 fn=0x400ebe7c
0x400ebe7c: esp_netif_start_api at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_netif/lwip/esp_netif_lwip.c:1068
D (12442) esp_netif_lwip: esp_netif_start_api 0x3ffbf388
D (12452) esp-netif_lwip-ppp: esp_netif_start_ppp: Starting PPP connection: 0x3ffbf5b8
D (12462) esp-netif_lwip-ppp: Phase Start
D (12462) esp-netif_lwip-ppp: Phase Establish
D (12472) esp_netif_lwip: check: local, if=0x3ffbf388 fn=0x400ec594
0x400ec594: esp_netif_update_default_netif_lwip at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_netif/lwip/esp_netif_lwip.c:316
D (12472) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3ffbf388
V (12482) esp_netif_lwip: esp_netif_is_netif_up esp_netif:0x3ffbf388
D (12482) esp_netif_lwip: call api in lwip: ret=0x0, give sem
E (12492) cmux_example: esp_modem_set_mode(ESP_MODEM_MODE_DATA) failed with 1
D (12502) esp_netif_handlers: esp_netif action stopped with netif0x3ffbf388 from event_id=0
D (12502) esp-netif_lwip-ppp: Phase Authenticate
D (12512) esp_netif_lwip: check: remote, if=0x3ffbf388 fn=0x400ec064
0x400ec064: esp_netif_stop_api at /home/espidf521/esp/esp-idf-v5.2.1/components/esp_netif/lwip/esp_netif_lwip.c:1167
D (12522) esp-netif_lwip-ppp: Phase Network
D (12522) esp-netif_lwip-ppp: esp_netif_stop_ppp: Stopped PPP connection: 0x3ffbf5b8
D (12532) esp-netif_lwip-ppp: Phase Terminate
D (12532) esp-netif_lwip-ppp: Phase Establish
D (12542) esp_netif_lwip: check: local, if=0x3ffbf388 fn=0x400ec594
D (12542) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3ffbf388
V (12552) esp_netif_objects: esp_netif_next_unsafe 0x0
V (12562) esp_netif_lwip: esp_netif_is_netif_up esp_netif:0x3ffbf388
V (12562) esp_netif_objects: esp_netif_next_unsafe 0x3ffbf388
D (12572) esp_netif_lwip: call api in lwip: ret=0x0, give sem
D (12572) esp-netif_lwip-ppp: Phase Disconnect
D (12582) esp-netif_lwip-ppp: Phase Dead
I (12582) esp-netif_lwip-ppp: User interrupt
D (12592) event: running post NETIF_PPP_STATUS:5 with handler 0x400dc994 and context 0x3ffc0930 on loop 0x3ffb9f44
0x400dc994: esp_modem::Netif::on_ppp_changed(void*, char const*, long, void*) at /home/espidf521/esp32-workspace/simple_cmux_client/managed_components/espressif__esp_modem/src/esp_modem_netif.cpp:22
I (12602) esp_modem_netif: PPP state changed event 5
V (12602) intr_alloc: esp_intr_free: Disabling int, killing handler
I (12612) main_task: Returned from app_main()
Users browsing this forum: Google [Bot] and 94 guests
