Hi everybody,
I would like to have some clarification concerning the use of UART event example.
I read most part of the topic concerning UART and I have some trouble for running the uart event example,
as I define UART_NUM_2 concerning the port and the
uart_set_pin(EX_UART_NUM,17,16,UART_PIN_NO_CHANGE,UART_PIN_NO_CHANGE)
but it is not working so I tried an other configuration
UART_NUM_1
uart_set_pin(EX_UART_NUM,10,9,UART_PIN_NO_CHANGE,UART_PIN_NO_CHANGE)
and this configuration is not working neither ...
I read also that the pin 17,16 are not working with WROOM 32 breakout (the one I am using) and pins 10,9 are used by SPI flash so should not be used for uart.
I also tried an other configuration with "random" pins and it was not working neither.
So my question is : does someone has some example running over wroom 32 breakout with UART or some guru explanation why the example is not working over my board ?
btw I am using a USB/UART converter with HTerm to display the pin output
Thank you and have a nice week end
UART configuration from uart event example
Users browsing this forum: No registered users and 63 guests
