esp32+lan8720 ethernet cannot get ip address
Moderator: ESP_Bob
luhuaneda
Postby luhuaneda » Tue Jul 12, 2022 3:13 am
Hi:
There is a issuse: After esp32 run,blocking at。
  while (!((uint32_t)ETH.localIP()))
At the router web , i can find this device,but no ipaddress
Serial1 print :
11:11:22.438 -> rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
11:11:22.438 -> configsip: 0, SPIWP:0xee
11:11:22.438 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
11:11:22.438 -> mode:DIO, clock div:2
11:11:22.438 -> load:0x3fff0030,len:1184
11:11:22.438 -> load:0x40078000,len:12784
11:11:22.438 -> load:0x40080400,len:3032
11:11:22.438 -> entry 0x400805e4
11:11:22.741 ->
11:11:22.741 -> Start
11:11:22.741 ->
GPIO :ETH_CLOCK_GPIO0_IN can get 50MHz from lan8702a.
Lan8720 can ouput 1.2V.
Hardware:esp32_wroom_32u + lan8720a
platform io
- framework-arduinoespressif32 @ 3.20003.220626 (2.0.3)
Dependency Graph
|-- Ethernet @ 2.0.0
| |-- WiFi @ 2.0.0
|-- WiFi @ 2.0.0
#ifdef ETH_CLK_MODE
#undef ETH_CLK_MODE
#endif
#define ETH_NRST 17
#define ETH_CLK_MODE    ETH_CLOCK_GPIO0_IN//ETH_CLOCK_GPIO17_OUT
// Pin# of the enable signal for the external crystal oscillator (-1 to disable for internal APLL source)
#define ETH_POWER_PIN   -1
// Type of the Ethernet PHY (LAN8720 or TLK110)
#define ETH_TYPE        ETH_PHY_LAN8720
// I²C-address of Ethernet PHY (0 or 1 for LAN8720, 31 for TLK110)
#define ETH_ADDR        1
// Pin# of the I²C clock signal for the Ethernet PHY
#define ETH_MDC_PIN     23//15
// Pin# of the I²C IO signal for the Ethernet PHY
#define ETH_MDIO_PIN    18//2
#include <Arduino.h>
#include <ETH.h>
#include <WiFiUdp.h>
WiFiUDP Udp;
unsigned int localUdpPort = 2333;
void printETHInfo(void)
  Serial.print("ETH MAC: ");
  Serial.print(ETH.macAddress());
  Serial.print(", IPv4: ");
  Serial.print(ETH.localIP());
  if (ETH.fullDuplex())
    Serial.print(", FULL_DUPLEX");
  Serial.print(", ");
  Serial.print(ETH.linkSpeed());
  Serial.println("Mbps");
void WiFiEvent(WiFiEvent_t event)
  switch (event)
  case SYSTEM_EVENT_ETH_START:
    Serial.println("ETH Started");
  case SYSTEM_EVENT_ETH_CONNECTED:
    Serial.println("ETH Connected");
  case SYSTEM_EVENT_ETH_GOT_IP:
    Serial.println("ETH GOT IP");
    printETHInfo();
  case SYSTEM_EVENT_ETH_DISCONNECTED:
    Serial.println("ETH Disconnected");
  case SYSTEM_EVENT_ETH_STOP:
    Serial.println("ETH Stopped");
  default:
void setup()
  Serial.println();
  WiFi.onEvent(WiFiEvent);
  Serial.println("Start\n");
  pinMode(ETH_MDC_PIN, OUTPUT);
  pinMode(ETH_NRST, OUTPUT);
  digitalWrite(ETH_NRST, 0);
  delay(10);
  digitalWrite(ETH_NRST, 1);
  delay(50);
  delay(50);
  delay(20);
  ETH.begin(ETH_ADDR, ETH_POWER_PIN, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_TYPE, ETH_CLK_MODE);
  Serial.println("Connected");
  Serial.print("IP Address:");
  Serial.println(ETH.localIP());
  Udp.begin(localUdpPort);
void loop()
  int packetSize = Udp.parsePacket();
  if (packetSize)
    char buf[packetSize];
    Udp.read(buf, packetSize);
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.println(Udp.remoteIP());
    Serial.print("From Port: ");
    Serial.println(Udp.remotePort());
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.print("Received: ");
    Udp.write((const uint8_t*)buf, packetSize);
    Udp.endPacket();
Users browsing this forum: No registered users and 13 guests
