ESP-IDF 4.4.1: A question about and a possible problem with data storage classes
MickPF
Postby MickPF » Fri Jun 17, 2022 12:43 pm
Does the gcc of the ESP-IDF store different storage classes in different address spaces?
Here are the relevant code fragments:
static const char *name_primitive = "Primitive";
static const char *name_date = "Date";
static const char *name_time = "Time";
static const char *name_sensor_value = "SensorValue";
static const char *name_rssi = "RSSI";
static const struct {
    field_type_t type;
    const char *name;
} field_type[] = {
    { FIELD_TYPE_PRIMITIVE, name_primitive },
    { FIELD_TYPE_TIME, name_time },
    { FIELD_TYPE_DATE, name_date },
    { FIELD_TYPE_SENSOR_VALUE, name_sensor_value },
    { FIELD_TYPE_WIFI_RSSI, name_rssi },
    { FIELD_TYPE_UNKNOWN, NULL }
The „standard“ gcc of linux does not generate neither warnings nor error messages for this code. The gcc of the ESP-IDF generates error messages and warnings for the same code:
settings.c:88:29: error: initializer element is not constant
settings.c:88:29: note: (near initialization for 'field_type[0].name')
settings.c:88:5: warning: missing initializer for field 'name' of 'const struct <anonymous>' [-Wmissing-field-initializers]
settings.c:86:21: note: 'name' declared here
     const char     *name;
Who makes mistakes at this place? Me or gcc?
Can somebody help me to solve this problem?
Thanks in advance,
Michael
Nobody is perfect!
My name is NOT Nobody...
Nobody lives forever to correct his mistakes someday in the future, if not right now!
Covid-19 is not responsible for any human failures!
gtjoseph
Re: ESP-IDF 4.4.1: A question about and a possible problem with data storage classes
Postby gtjoseph » Fri Jun 17, 2022 2:01 pm
What version of gcc are you running on your linux host? I tried 8.x, 9.x and 12.x and they all throw the same error. What options are you passing on the linux host.
In any case...
Change
static const char * name_primitive = "Primitive";
to
static char * const name_primitive = "Primitive";
See https://stackoverflow.com/questions/890 ... const-char
MickPF
Postby MickPF » Fri Jun 17, 2022 6:31 pm
Hello gtjoseph,
I use gcc-12.1 under openSUSE Tumbleweed without passing any special options to the compiler.
Many thanks for your help, your suggestion works.
Kind Regards,
Michael
Nobody is perfect!
Users browsing this forum: No registered users and 132 guests
