A "better" enviroment like arduino
gchini
Postby gchini » Wed Jun 08, 2022 2:09 pm
Hi at all....
I would like to know if there is a "better" enviroment then arduino to use with esp32.
What is "better" for me: simple and supported (i need to use BLE)
I need to use the BluetoothLE and compute some encryption functions thats require "plenty" of stack memory (arround 400k)
ESP_Sprite
Re: A "better" enviroment like arduino
Postby ESP_Sprite » Thu Jun 09, 2022 2:16 am
'Better' is a bit hard to define... what is the Arduino environment lacking, in your opinion?
gchini
Postby gchini » Thu Jun 09, 2022 5:33 am
I'm not able to understand the underline system and control the various stack option.
I have a problem with the size of stack, i would like to increase the size of stack for a particular task (As i written in another discussion). Then i look for the reply to my question in others forum like this.
"Better" form e is also a matter of how many documentation, support and examples there are for a particular enviroment
ESP_Sprite
Postby ESP_Sprite » Thu Jun 09, 2022 7:02 am
You could go for ESP-IDF. The Arduino environment is built on top of that.
gchini
Postby gchini » Thu Jun 09, 2022 7:09 am
Many thanks for the explanation
Then how is the stack of the architectrure?
Application
Arduino
freeRTOS
Espressif IDF
ESP32
Is the stack correct. I want just clarify to myself how it works the acrchitecture.
Many thanks
john11
Postby john11 » Sun Jun 12, 2022 8:14 pm
I would switch place with FreeRTOS & IDF
Users browsing this forum: aygh4266 and 88 guests
