GDB Issue, "Connection refused"
justinmreina
Postby justinmreina » Sat Aug 26, 2017 2:03 am
I am using the DevKitC with my Segger J-Link EDU and am having trouble establishing JTAG connection in GDB. OpenOCD works with this configuration.
Target: DevKitC
Debugger: Segger J-Link EDU
Method: JTAG (wiring example)
Setup: USB connected, JTAG wiring connected (see above)
Reference Used: JTAG-Debugging - Using the Debugger from the Command Line
Issue
When I try to run xtensa-esp32-elf-gdb, I get the following response -
erguser@ergdev-esp32:~/esp/hello_world$ xtensa-esp32-elf-gdb -x gdbinit build/hello-world.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-61-gab8375a) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/hello-world.elf...done.
gdbinit:1: Error in sourced command file:
:3333: Connection refused.
(gdb)
Why is the connection refused? Am I missing a step?
ESP_krzychb
Contact:
Re: GDB Issue, "Connection refused"
Postby ESP_krzychb » Sat Aug 26, 2017 8:06 am
Hi justinmreina,
- What is shown on OpenOCD console?
- What is your OS?
justinmreina
Postby justinmreina » Sat Aug 26, 2017 6:54 pm
Hey krzychb,
Great to hear from you, looking forward to debugging this.
OS:
  • Ubuntu 16.04 LTS (Virtualbox, Win10 Host)
Command:
  • ./src/openocd -s tcl -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Result: (file)
  • erguser@ergdev-esp32:~$ cd ~/esp/openocd-esp32
    erguser@ergdev-esp32:~/esp/openocd-esp32$ dmesg | grep tty
    [ 0.000000] console [tty0] enabled
    [ 1.721594] tty tty25: hash matches
    [ 848.465053] usb 2-3: cp210x converter now attached to ttyUSB0
    erguser@ergdev-esp32:~/esp/openocd-esp32$ ./src/openocd -s tcl -f interface/jlink.cfg -f board/esp-wroom-32.cfg
    Open On-Chip Debugger 0.10.0-dev-gcc5b0f7 (2017-08-25-18:11)
    Licensed under GNU GPL v2
    For bug reports, read
    adapter speed: 20 kHz
    force hard breakpoints
    Info : No device selected, using first device.
    Info : J-Link V9 compiled Dec 16 2016 15:34:10
    Info : Hardware version: 9.40
    Info : VTarget = 3.317 V
    Info : clock speed 20 kHz
    Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
    Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
    <justin pressed reset button (EN) on DevKitC>
    Info : esp32: Debug controller was reset (pwrstat=0xE5, after clear 0x5F).
Thoughts? Let me know if anything else is needed! :)
ESP_krzychb
Contact:
Postby ESP_krzychb » Sun Aug 27, 2017 10:22 am
Hey justinmreina,
You have provided very well organized logs :D
1. What part of OpenOCD log is shown before you attempt to connect gdb? My looks as follows:
krzysztof@TK-HP:~/esp/openocd-esp32$ src/openocd -s tcl -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev-gcc5b0f7a (2017-08-27-11:04)
none separate
adapter speed: 20000 kHz
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : Target halted. PRO_CPU: PC=0x400D17B3 (active)    APP_CPU: PC=0x400840A7
After running gdb, OpenOCD log shows the following:
Info : Use core0 of target 'esp32'
Info : Target halted. PRO_CPU: PC=0x40091D07 (active)    APP_CPU: PC=0x400D0DAC
Info : Auto-detected flash size 4194303 KB
Info : Using flash size 4194303 KB
Info : Target halted. PRO_CPU: PC=0x5000004B (active)    APP_CPU: PC=0x00000000
esp32: target state: halted
Info : esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x40000400 (active)    APP_CPU: PC=0x40000400
2. Since you are getting "Connection refused" maybe this is some permission issues.
Have you tried running gdb as a superuser "sudo xtensa-esp32-elf-gdb -x gdbinit build/hello-world.elf"?
3. If "sudo" does not help, then please post logs with increased debug level following http://esp-idf.readthedocs.io/en/latest ... ing-issues
4. Are you using the latest master of "esp-idf" to compile and load "hello-world" example or some previous version? Which one?
justinmreina
Postby justinmreina » Mon Aug 28, 2017 8:17 pm
I do not have 'interface/ftdi/esp32_devkitj_v1.cfg', does this perform JTAG over USB for the DevKitC? How might I get this file?
I will get to this later today, your help here is really appreciated, thanks!
ESP_krzychb
Contact:
Postby ESP_krzychb » Sat Sep 02, 2017 5:58 pm
justinmreina wrote:I do not have 'interface/ftdi/esp32_devkitj_v1.cfg', does this perform JTAG over USB for the DevKitC? How might I get this file?
No, this file is applicable for on board JTAG of ESP-WROVER-KIT. You can get it under https://github.com/espressif/openocd-es ... itj_v1.cfg
Users browsing this forum: Majestic-12 [Bot] and 50 guests
