Issue with changing the sleep mode
By default when querying with AT+SLEEP? it shows 2. I want to make it to 0. How should I do that?
Re: Issue with changing the sleep mode
Which version is this? Execute AT+SLEEP? Is the default value not 1?
Yes when querying after AT+RESTORE, it shows as 1. How do I make it to 0? I suspect my module is going to sleep, that is why it is disconnecting.
You can execute AT+SLEEP=0 command, but disabling sleep mode will increase power consumption.
How do I execute that? It doesn't take that command generally. Should I give any other configuration before giving that?
Okay thanks. It worked.
Users browsing this forum: No registered users and 51 guests
