at command MQTT
giulio
at command MQTT
Postby giulio » Sun May 15, 2022 3:10 pm
Hi everybody,
I'm trying to get connected to cloudMQTT using AT commands and as long as I simply connect using TCP it works just fine. When it comes to certificate I start having troubles.
I have three certificates tested using MQTT.fx therefore I consider them valid and correct.
The list of commands I'm using:
AT+MQTTUSERCFG=0,3,"publisher","user-id","password",0,0,"" (parameter "scheme" can be either 3,4 or 5)
AT+MQTTUSERCFG=0,3,"subscriber","user-id","password",0,0,"" (parameter "scheme" can be either 3,4 or 5)
AT+MQTTCONN=0,"m24.cloudmqtt.com",29768,1
I'm getting "error" message all the time.
The certificates have been loaded using
AT+SYSFLASH=2,"mqtt_cert",0,2054
AT+SYSFLASH=2,"mqtt_ca",0,2208
AT+SYSFLASH=2,"mqtt_key",0,3308
I have loaded the certificates either in plain text or converted in .bin using ATPKI.py with no success.
I also use these command to get date and time for certificate validity check
AT+CIPSNTPCFG=1,8,"ntp1.aliyun.com"
AT+CIPSNTPTIME?
I'm obviously missing something but after days of trial I can't figure out what is wrong.
Any bit of help will be appreciate.
ESP_Sprite
Re: at command MQTT
Postby ESP_Sprite » Mon May 16, 2022 1:17 am
Move -> AT forum
TiboRich
Re: at command MQTT
Postby TiboRich » Fri Jul 15, 2022 9:19 pm
I am using AT command FW 2.4.0 and I confirm that sending the certificate files with binary header via AT command AT+SYSFLASH does not work even when certificates are properly generated with atpki script.
This said, sending the private key file via UART AT command is a terrible practice for security.
A working solution that I tested is to program the certificates files to flash directly via flash download tool.
To find the right offset, you need to look into esp-at-release-2.4.0.0 github repo, and look for file module_config/module_esp32_default/at_customize.csv
ESP_Sun
Re: at command MQTT
Postby ESP_Sun » Mon Jul 18, 2022 4:14 am
Hi everybody,
AT+CIPSNTPTIME?
You may need to use
AT+SYSFLASH=0,"mqtt_cert"
to first erase the partition, then use
AT+SYSFLASH=1,"mqtt_cert",0,<actual length of the certificate>
to write the certificate, and finally use
AT+SYSFLASH=2, "mqtt_cert",0,2054
to query certificate.
Hope the above method works for you.
Users browsing this forum: No registered users and 9 guests
