I need help.
after Build I get this Error:
I need Help
/main/main.cpp:787:42: error: '%02d' directive output may be truncated writing between 2 and 11 bytes into a region of size between 9 and 16 [-Werror=format-truncation=]
snprintf(ts_buf, ts_bufsize, "%04d-%02d-%02dT%02d:%02d:%02dZ",
../main/main.cpp:787:42: note: directive argument in the range [-2147483647, 2147483647]
../main/main.cpp:787:21: note: 'snprintf' output between 21 and 73 bytes into a destination of size 21
utc_time.tm_year+1900,
utc_time.tm_mon+1,
utc_time.tm_mday,
utc_time.tm_hour,
utc_time.tm_min,
utc_time.tm_sec
cc1plus.exe: some warnings being treated as errors
Re: '%02d' directive output may be truncated writing between 2 and 11 bytes into a region of size between 9 and 16 [-Wer
I had the same problem and solved it with the following the solution.
Add the following command to CMakeLists on the corresponding components:
我遇到了同样的问题,并通过以下方案解决了此问题:
在对应组件的对应CMakeLists文件最后添加以下命令:
此外,你的年时间应该计算错了,struct tm结构体内的tm_year是基于1900开始计算的
target_compile_options(${COMPONENT_LIB} PRIVATE "-Wno-format")
Users browsing this forum: No registered users and 107 guests
