i need to create a 32bit Array with the maxium Size.
If i create a normal Array the maxium is uint32_t data[35000]. The DRAM was 162KiB and after creation it was 26KiB.
If i create the Array with malloc, the maxium is: data = (uint32_t *) malloc(27000 * sizeof(uint32_t));
Im new in Allocation of Memoy. Can anyone explain me how to maxium the Array Size. I need 50.000 or bigger.
Thank you!
How to create a maximum 32bit Array?
Re: How to create a maximum 32bit Array?
1. 50 000 x 4 = 200kB memory required for this array
2. you said you have only 162kB - not possible
3. memory should be in 1 consecutive memory block, you probably did not check it, just free memory, which is not the same amount
4. how about using PSRAM?
My Memory:
6KiB : DRAM
162KiB: DRAM
14 KiB: D/IRAM
111KiB: D/IRAM
47KiB: IRAM
If i create a Array[35000] it looks:
6KiB : DRAM
26KiB: DRAM
14 KiB: D/IRAM
111KiB: D/IRAM
47KiB: IRAM
Ok, how can i use the PSRAM?
6KiB : DRAM
162KiB: DRAM
14 KiB: D/IRAM
111KiB: D/IRAM
47KiB: IRAM
6KiB : DRAM
26KiB: DRAM
14 KiB: D/IRAM
111KiB: D/IRAM
47KiB: IRAM
I have a Wroom32. There is no PSRAM.
Is there a Module with PSRAM and 24 usable GPIO Outputs?
- 35000 elements
- each element is 4 bytes
- 4x35000 = 140000
- (162 - 26) * 1024 = 139264 bytes (assuming either 162kB or 26kB is approx, 140000 bytes used)
- 4x35000 = 140000
esp32 S3?Tobi82m wrote: Is there a Module with PSRAM and 24 usable GPIO Outputs?
ESP32 S3 looks good. PSRAM is usable for a really Big Array?
There are many Outputs. But how many of them are really usable as Output? PSRAM need GPIOs?
Users browsing this forum: Bing [Bot], Nikolay_Kichuokv and 75 guests
