SD-Card performance very bad after upgrading from 1.0.6 core to 2.0.2
esp1979
Postby esp1979 » Sat Apr 16, 2022 12:55 pm
Hi all,
can you confirm that the SD-Card performance is very bad in core 2.0.2?
I have tried this example (from the examples folder):
 * Connect the SD card to the following pins:
 * SD Card | ESP32
 *    D2       -
 *    D3       SS
 *    CMD      MOSI
 *    VSS      GND
 *    VDD      3.3V
 *    CLK      SCK
 *    VSS      GND
 *    D0       MISO
 *    D1       -
#include "FS.h"
#include "SD.h"
#include "SPI.h"
void listDir(fs::FS &fs, const char * dirname, uint8_t levels){
    Serial.printf("Listing directory: %s\n", dirname);
    File root = fs.open(dirname);
    if(!root){
        Serial.println("Failed to open directory");
        return;
    if(!root.isDirectory()){
        Serial.println("Not a directory");
        return;
    File file = root.openNextFile();
    while(file){
        if(file.isDirectory()){
            Serial.print("  DIR : ");
            Serial.println(file.name());
            if(levels){
                listDir(fs, file.name(), levels -1);
            Serial.print("  FILE: ");
            Serial.print(file.name());
            Serial.print("  SIZE: ");
            Serial.println(file.size());
void createDir(fs::FS &fs, const char * path){
    Serial.printf("Creating Dir: %s\n", path);
    if(fs.mkdir(path)){
        Serial.println("Dir created");
        Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path){
    Serial.printf("Removing Dir: %s\n", path);
    if(fs.rmdir(path)){
        Serial.println("Dir removed");
        Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path){
    Serial.printf("Reading file: %s\n", path);
    File file = fs.open(path);
    if(!file){
        Serial.println("Failed to open file for reading");
        return;
    Serial.print("Read from file: ");
    while(file.available()){
        Serial.write(file.read());
    file.close();
void writeFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Writing file: %s\n", path);
    File file = fs.open(path, FILE_WRITE);
    if(!file){
        Serial.println("Failed to open file for writing");
        return;
    if(file.print(message)){
        Serial.println("File written");
        Serial.println("Write failed");
    file.close();
void appendFile(fs::FS &fs, const char * path, const char * message){
    Serial.printf("Appending to file: %s\n", path);
    File file = fs.open(path, FILE_APPEND);
    if(!file){
        Serial.println("Failed to open file for appending");
        return;
        Serial.println("Message appended");
        Serial.println("Append failed");
    file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2){
    Serial.printf("Renaming file %s to %s\n", path1, path2);
    if (fs.rename(path1, path2)) {
        Serial.println("File renamed");
        Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char * path){
    Serial.printf("Deleting file: %s\n", path);
    if(fs.remove(path)){
        Serial.println("File deleted");
        Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char * path){
    static uint8_t buf[512];
    size_t len = 0;
    uint32_t start = millis();
    uint32_t end = start;
    if(file){
        len = file.size();
        size_t flen = len;
        start = millis();
        while(len){
            size_t toRead = len;
            if(toRead > 512){
                toRead = 512;
            file.read(buf, toRead);
            len -= toRead;
        end = millis() - start;
        Serial.printf("%u bytes read for %u ms\n", flen, end);
        file.close();
    if(!file){
        return;
    size_t i;
    start = millis();
    for(i=0; i<2048; i++){
        file.write(buf, 512);
    Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
    file.close();
void setup(){
    if(!SD.begin()){
        Serial.println("Card Mount Failed");
        return;
    uint8_t cardType = SD.cardType();
    if(cardType == CARD_NONE){
        Serial.println("No SD card attached");
        return;
    Serial.print("SD Card Type: ");
    if(cardType == CARD_MMC){
        Serial.println("MMC");
    } else if(cardType == CARD_SD){
        Serial.println("SDSC");
    } else if(cardType == CARD_SDHC){
        Serial.println("SDHC");
        Serial.println("UNKNOWN");
    uint64_t cardSize = SD.cardSize() / (1024 * 1024);
    Serial.printf("SD Card Size: %lluMB\n", cardSize);
    listDir(SD, "/", 0);
    createDir(SD, "/mydir");
    removeDir(SD, "/mydir");
    listDir(SD, "/", 2);
    writeFile(SD, "/hello.txt", "Hello ");
    appendFile(SD, "/hello.txt", "World!\n");
    readFile(SD, "/hello.txt");
    deleteFile(SD, "/foo.txt");
    renameFile(SD, "/hello.txt", "/foo.txt");
    readFile(SD, "/foo.txt");
    testFileIO(SD, "/test.txt");
    Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
    Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
void loop(){
with core 1.0.6 is is very fast.
With core 2.0.2 very very very slow.
Is there a solution / reason for the lack of performance?
Best wishes
Daniel
esp1979
Re: SD-Card performance very bad after upgrading from 1.0.6 core to 2.0.2
Postby esp1979 » Sun Apr 17, 2022 11:46 pm
Really no one that can help?
It's really sad: Also on my last post i didn't get any answer ;-(
ESP_igrr
Postby ESP_igrr » Mon Apr 18, 2022 7:44 am
Hi, this issue will be fixed by the following PR: https://github.com/espressif/arduino-esp32/pull/6569. The fix will be part of the upcoming 2.0.3 release.
Users browsing this forum: No registered users and 43 guests
