AT+BTA2DPINIT with I2S
pedroATsms
Postby pedroATsms » Thu Apr 07, 2022 2:11 am
Hi all,
I have a couple of questions about A2DP.
Using a ESP32 with AT, I have enabled A2DP support, which gives 3 I2S pins. My questions are -
1) is the I2S a master or slave?
2) What difference will the +BTA2DPINIT sink or source make to the I2S function?
Thanking you
Pedro
ESP_Sun
Re: AT+BTA2DPINIT with I2S
Postby ESP_Sun » Tue Apr 12, 2022 2:32 am
1) I2S is the master.
2) AT+BTA2DPINIT is source without I2S, AT+BTA2DPINIT is sink will use I2S to control peripherals to play audio.
Hope this helps you.
pedroATsms
Postby pedroATsms » Thu Apr 14, 2022 5:51 am
Thank you for your reply ESP_Sun.
If I understand your reply correctly, then:-
BT Sink -> I2S Master
BT Source -> No I2S
If BT Source has no I2S, how do I give it the audio?
Kind regards
Pedro
ESP_Sun
Postby ESP_Sun » Thu May 19, 2022 8:02 am
BT Source -> No I2S
Kind regards
Pedro
Yes, BT source does not have I2S. It executes the AT+BTA2DPSRC command and provides audio for it through the URL, but there is a issue with the current version of the AT+BTA2DPSRC command.
Users browsing this forum: No registered users and 47 guests
