Unable to start debugging. Unexpected GDB output from command "- interpreter-exec console "target remote:3333""
I am new with the ESP and i am trying to work with VSCode and use the debugger, the setup is:
- ESP32-S3 -DevKitC1
- espressif-idf ver 1.4
- IDF 4.4
- blink example
I'm working by the documentation and the YouTube guide as reference (https://www.youtube.com/watch?v=uq93H7T7cOQ)
configure the launch.json as:
"version": "0.2.0",
"configurations": [
"preLaunchTask": "preRun",
"type": "cppdbg",
"name": "Esp32OpenOcd",
"request": "launch",
"cwd":"${workspaceFolder}/build",
"program": "${workspaceRoot}/build/${command:espIdf.getProjectName}.elf",
"miDebuggerPath": "${command:espIdf.getXtensaGdb}",
"setupCommands": [
{"text":"target remote :3333"},
{"text":"set remote hardware-watchpoint-limit 2"},
{"text":"monitor reset halt"},
{"text":"flushregs"},
{"text":"thb app_main"},
and the tasks.json as:
"version": "2.0.0",
"tasks": [
"label": "preRun",
"type": "shell",
"windows": {
"command": "clear '&' start openocd -c \"set ESP_RTOS none\" -f board/esp32s3-builtin.cfg '&' exit"
It look that it start when i try to connect manually:
openocd -f board/esp32s3-builtin.cfg
Open On-Chip Debugger v0.11.0-esp32-20211220 (2021-12-20-15:43)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Warn : Transport "jtag" was already selected
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 40000 kHz
Info : JTAG tap: esp32s3.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : JTAG tap: esp32s3.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Info : esp32s3.cpu0: Target halted, PC=0x40000400, debug_reason=00000001
Info : esp32s3.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : starting gdb server for esp32s3.cpu0 on 3333
but when i use the launch.json - the dbg fail, it look that it fail to parse => Unable to start debugging. Unexpected GDB output from command "- interpreter-exec console "target remote:3333"" .:3333 (undocumented errno138)
Anyone have any idea how to solve that ?
- IDF 4.4
- blink example
"version": "0.2.0",
"configurations": [
"type": "cppdbg",
"setupCommands": [
"version": "2.0.0",
"tasks": [
"label": "preRun",
"type": "shell",
"windows": {
Re: Unable to start debugging. Unexpected GDB output from command "- interpreter-exec console "target remote:3333""
Did you resolve this issue?
I have the same issue, also using ESP32-S3. (following the same video guide)
I need this because:
Debugging using the configuration from the ESP-IDF extension in VSCode doesn't allow me to place logpoints.
When hovering over the breakpoint in the debug menu it shows: "Breakpoints of this type are not supported by the debugger"
- evanescent_nacho
I'm stuck with the same issue. I had a different issue before, but after resolving that, I got stuck with this. Here is a link to that thread: viewtopic.php?f=13&t=30661.
I've used the command line successfully with OpenOCD / GDB, set a breakpoint and investigated a variable, but I have not gotten VSCode to launch and integrate with OpenOCB / GDB. It seems that something is not right with how VSCode hooks into GDB or OpenOCD.
- evanescent_nacho
I've been able to get it working, but I have to launch OpenOCD externally in a terminal. I type on the command line "openocd -c "set ESP_RTOS none" -f board/esp32c3-builtin.cfg". I need the folder above 'board' to be part of PATH. That is 'PATH_TO_SDK'\tools\openocd-esp32\v0.11.0-esp32-20220411\openocd-esp32\share\openocd\scripts in case you need that. I run that and leave the window open, then launch debugging. I have the preLaunchTask commented out in lauch.json. Sometimes is does drop the connection after it's done some connecting. I had it doe that after each partition while programming until it had programmed all 3 partitions. For now I have programming commented out in the setup commands. I also start the monitor first, so I get logs and I can reprogram before that step if I wish.
- evanescent_nacho
I've posted what worked for me here. Basically the preLaunchTask is not working for me to OpenOCD does not start. I have to start that in a terminal before starting a debug session, even though I followed the example for the preLaunchTask. Here is the other thread where I talk about it a little more: https://esp32.com/viewtopic.php?f=40&t= ... 77#p108677.
Has anyone managed to properly debug ESP32-S3 DevKitC-1. It's been over a year and I don't see a solution anywhere.
I followed the same example by Yuri-R video posted above for the ESP32-S2 but I also get the same problem shown in the screenshot.
I use VScode and esspresif extension + esp-idf latest versions.
If those step by step instructions and videos don't work for you or you miss a turn somewhere you usually end up in a loop where you waste too much time with no result. This is one, there is no step by step for this specific dev board and I don't really know what the problem is.
I can't help but to complain that we are 2023 and we type commands in command prompt like MS DOS. Instead of going forward we are going backwards. VScode might be a nice environment for combining many platforms but it's a nightmare to setup. I miss the specific compiler IDEs like Atmel Studio,Codevision etc. where you could debug easily. I'm tired of all those json files setup every time I do something, I wonder if I ditch VScode and try Eclipse if I could debug the dev kit. Has anyone tried that ?
Sorry for my complains prbly the wrong forum but I just wanted to get it out of me
- Screenshot_1.jpg (13.12 KiB) Viewed 92339 times
Have you followed our setup tutorial here:
https://github.com/espressif/vscode-esp ... install.md
And our debug tutorial:
https://github.com/espressif/vscode-esp ... bugging.md
If you have any problems share the troubleshooting information with us to understand better the problem:
https://github.com/espressif/vscode-esp ... leshooting
Thx for your answer ESP_bignacio,
I have already used the links you sent. After I press F5 to debug I get the error I select the USB-JTAG builtin option and I use the com port that says UART on the board (not the USB one)
Here is my settings.json.
Here is my launch.json
"idf.adapterTargetName": "esp32s3",
"idf.openOcdConfigs": [
"board/esp32s3-builtin.cfg"
"idf.portWin": "COM7",
"idf.flashType": "UART",
"C_Cpp.default.compilerPath": "c:\\Applications\\Programming\\ESP\\Tools/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe"
"version": "0.2.0",
"configurations": [
"name": "ESP32 OpenOCD",
"type": "cppdbg",
"cwd": "${workspaceRoot}/build",
"program": "${workspaceRoot}/build/SmartHome.elf",
"miDebuggerPath": "c:/Applications/Programming/ESP/tools/tools/xtensa-esp-elf-gdb/12.1_20221002/xtensa-esp-elf-gdb/bin/xtensa-esp32s3-elf-gdb.exe",
"setupCommands": [
{"text": "target remote 127.0.0.1:3333"},
{"text": "set remote hardware-watchpoint-limit 2" },
{"text": "monitor reset halt"},
{"text": "flushregs"}
Hi Jimis1,
Please follow the steps from the link https://github.com/espressif/vscode-esp ... leshooting Brian provided and attach the output of the Doctor's Command here, as well as the %USERPROFILE%\.vscode\extensions\espressif.esp-idf-extension-VERSION\esp_idf_vsc_ext.log file, after you've set the following:
NOTE: Use idf.openOcdDebugLevel configuration setting to 3 or more to show debug logging in OpenOCD server output.
NOTE: Use logLevel in your /.vscode/launch.json to 3 or more to show more debug adapter output.
Attaching the files
- esp_idf_vsc_ext.log
- (117.34 KiB) Downloaded 5899 times
- DoctorsCommand.txt
- (12.04 KiB) Downloaded 5713 times
Users browsing this forum: No registered users and 20 guests
