functions from other files are undefined to main.c
Ali_Makhlouf
Postby Ali_Makhlouf » Wed Mar 30, 2022 12:14 pm
I am trying to make LCD project based on i2s driver then I faced a problem that the functions are undefined. Then I made a simple main.c file and a another .h/.c files that contain a sum functions and still tells me the function is undefined.
main.c code:
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include "sdkconfig.h"
#include "esp_heap_caps.h"
#include "../components/components.h"
void app_main(void)
	uint8_t x = 3, y = 4, z = 0;
	z = sumq(x, y);
	while(1);
components.h code:
#ifndef   __temp_H__
#define   __temp_H__
#include <stdio.h>
uint8_t sumq(uint8_t s1, uint8_t s2);
#endif
components.c code:
#include "components.h"
	return s1 + s2;
the project structure below (img1)
and the error is as below (img2)
then I moved the function(sumq) definition and prototype to main.c file and it compiled, but they didn't compile in the components.h/.c files. Looks like it's a linker problem
can you help me solve this problem?
Thanks.
Ali_Makhlouf
Re: functions from other files are undefined to main.c
Postby Ali_Makhlouf » Wed Mar 30, 2022 1:02 pm
I found the problem.
it was the CMakeList.txt
It should contain all the .h/.c files that should be built within the main.c
the Cmakelists.txt was modified to the following:
# Edit following two lines to set component requirements (see docs)
set(COMPONENT_REQUIRES )
set(COMPONENT_PRIV_REQUIRES )
set(COMPONENT_ADD_INCLUDEDIRS "")
idf_component_register(
    SRC_DIRS
        "../components"
    INCLUDE_DIRS
        "../components"
But Why should do this every time a file is added. Shouldn't this be automatically implemented?
Users browsing this forum: ElectricThanhTung and 122 guests
