[SOLVED] Arduino 1.8.19 compile error : ImportError: no module named serial [Raspberry Pi]
EdtheWino
Postby EdtheWino » Sun Mar 13, 2022 12:58 am
Using a Raspberry Pi platform I am getting a "no module named serial" error on compile of ESP32 sketch under 1.8.19 Arduino IDE.
The Espressif library is installed. Does anyone know what causes this error generation or how to correct it? I have installed python3.
  File "/home/pi/.arduino15/packages/esp32/tools/esptool_py/3.1.0/esptool.py", line 38, in <module>
    import serial
ImportError: No module named serial
Multiple libraries were found for "WiFi.h"
 Used: /home/pi/.arduino15/packages/esp32/hardware/esp32/2.0.2/libraries/WiFi
 Not used: /home/pi/Arduino/libraries/WiFiNINA
 Not used: /opt/arduino-1.8.19/libraries/WiFi
exit status 1
Error compiling for board ESP32 Dev Module.
EdtheWino
Re: [SOLVED] Arduino 1.8.19 compile error : ImportError: no module named serial [Raspberry Pi]
Postby EdtheWino » Fri Mar 18, 2022 1:02 am
Solution:
sudo apt install python-is-python3
Users browsing this forum: No registered users and 63 guests
